DW CS3 Insert Record/Update Record: Record Form Wizard Error
Jun 24, 2007 7:38 AM
I have just bought Dreamweaver CS3 and I am running into some problems. I also have Dreamweaver MX 2004. When I use the Insert Record: Record Insertion Form Wizard on my Dreamweaver MX 2004 I have no problems using the Insert Record function. However, when I use the Dreaweaver CS3, I am running into errors. The error I am getting is the following..."Apache HTTP Server has encountered a problem and needs to close. We are sorry for the inconvenience."
As well, when I use the update form wizard, when you place all your settings and place a redirection after updating to a page it does not do it, it stays on the same page and gives me the following error..."Warning: Cannot modify header information - headers already sent in C:\wamp\www\edit.php on line 50".
This happens on all internet browsers when I want to insert a new record. It takes a long time to load the page and then it finally gives me an error which I stated above. I never had a problem before. I thought maybe I installed the application wrong, so I unistalled and reinstalled the DW CS3. I still get the same issue. I became so frustrated that I formatted my hard drive thinking make I have a adware or spyware, so to be cautious I formatted my computer and installed everything with a fresh install and still I get this error. Now my testing server that I use is called WAMP. I never had problems with it before using DW MX 2004 or when I used the trial of DW 8. So now I am out of options. Is there a glitch in the new CS3 Web Premium that includes DW CS3 upgrade software and if there is, is there a download. Can anyone help me, please.
    Jun 24, 2007 10:40 AM   in reply to AdonaiEchad
    > Is there a glitch in the new DW CS3 and if there is, is there
    > a download.
    None that I am aware of. I have been using CS3 for a very long time
    without problems. The code that it generates for Insert Record is
    identical to Dreamweaver 8.0.2.
    David Powers, Adobe Community Expert
    Author, "Foundation PHP for Dreamweaver 8" (friends of ED)
    Author, "PHP Solutions" (friends of ED)
    http://foundationphp.com/
    Jun 24, 2007 1:41 PM   in reply to AdonaiEchad
    The OP was using DMX 2004, though, correct? The server behaviors were
    significantly changed in 8.02 and beyond for ASP. Is the same true for PHP?
    Nancy Gill
    Author: Dreamweaver 8 e-book for the DMX Zone
    Co-Author: Dreamweaver MX: Instant Troubleshooter (August, 2003)
    Technical Editor: DMX 2004: The Complete Reference, DMX 2004: A Beginner''s
    Guide, Mastering Macromedia Contribute
    Technical Reviewer: Dynamic Dreamweaver MX/DMX: Advanced PHP Web Development
    "David Powers" <david@example.com> wrote in message
    news:f5mab9$3fk$1@forums.macromedia.com...
    >> Is there a glitch in the new DW CS3 and if there is, is there a download.
    Jun 24, 2007 2:34 PM   in reply to AdonaiEchad
    Yes. That's what I said. The server behaviors in CS3 are the same as in
    8.0.2.
    Jun 24, 2007 2:53 PM   in reply to Newsgroup_User
    AdonaiEchad wrote:
    > For example. In the insert page in MX2004 I do not need to
    > make a recordset, however, for the CS3 insert page I noticed when I use the
    > insert record form wizard it does not work unless I make a recordset where in
    > MX2004 I did not need to do this.
    You don't need a recordset to insert a new record.
    > I noticed that in the following code difference in...
    > MX2004 = <?php echo $row_rsTest['test']; ?>
    > CS3 = <?php echo htmlentities($row_rsTest['test'], ENT_COMPAT, 'utf-8'); ?>
    > There is a big difference.
    No there isn't. Read the PHP manual for htmlentities():
    http://www.php.net/manual/en/function.htmlentities.php
    All that the extra code is doing is making your code safer.
    > MX2004 - add.php
    > <?php require_once('../Connections/conTest.php'); ?>
    > CS3 - add.php
    > <?php virtual('/Connections/conTest.php'); ?>
    The preceding two lines are the most important change. It means that you
    have set your site definition to use links relative to the site root in
    CS3, instead of relative to the document in MX 2004. The virtual()
    function works only if you are using PHP as an Apache module.
    Try switching your site definition back to using document-relative
    links, get rid of all existing files in your Connections folder, and
    start again.
    Jun 25, 2007 4:44 AM   in reply to Newsgroup_User
    AdonaiEchad wrote:
    > Thank you David, that really helped. My links relative to was set on Site Root
    > rather than Document. It works now. I am trying to learn and I thank you for
    > your patience on this matter specially being a novice at this stuff.
    Glad the answer was so simple. Unfortunately, the code used for
    site-root-relative links isn't universally supported. I've tried to
    persuade Adobe to change this, but so far without success.
