efg5
Determining dpi using Adobe 9 Standard
Mar 4, 2011 5:02 PM
Using Adobe 9 Standard, how can I find out the dpi of a pdf someone sent me?
Thanks!
    Mar 5, 2011 2:34 AM   in reply to efg5
    PDF files do not have "a DPI" - every pixel-based page element can be different, and the text and some graphics are vector-based (so have no pixels to count).
    Mar 5, 2011 4:24 PM   in reply to efg5
    You may be able to get some of the information on individual items by using preflight to check the document.
    Mar 6, 2011 1:09 AM   in reply to efg5
    So you're saying that although I tell my scanner to scan at 600 dpi or 300 dpi, the resulting PDF has no characteristic resembling dpi?
    You can check resolution of images in PDF documents with the preflight tool of Acrobat Pro.
    Mar 6, 2011 11:30 AM   in reply to Bernd Alheit
    Images are stored in a block in a PDF and have their own resolution. There is no native resolution to the PDF itself, but is set in the parts. You should be able to determine the resolution of scans and such by using Extract All Images. Those extracted images should be identical to what is stored in the PDF to my understanding. You can then check them in a graphics editor or tool like IrfanView.
    Mar 6, 2011 10:28 PM   in reply to efg5
    If you got the PDF from a scanner, then you should have pages of images (one image per page). If you do not, then you probably ran OCR on the result. If you used ClearScan, then the images are replaced by fonts and you can check the font properites. Otherwise, you should have a collection of images that can be exported.
    Mar 9, 2011 8:40 PM   in reply to efg5
    We've told you - there is *no such thing* as "the DPI of a PDF". Each page element has an independent value (or none at all) and they can be, and often are, widely-different between elements on the same page.
    Even if your file is a scan without OCR, so it contains a single image of each scan, one per page - the PAGE has no resolution. The image ON the page does, but that's an entirely different concept. Acrobat Standard does not allow you to inspect page elements to see their individual properties; that's a feature of Acrobat Pro.
