Rrrrazorfish
Adobe Connect 8: 3rd Party VoIP integration - how?
Mar 15, 2011 7:03 AM
Hello all,
as far as i know there is a possibility to integrate 3rd Party VoIP into Connect 8. Which finally should mean default Adobe VoIP channel is replaced by the service from the 3rd Party VoIP provider so that when one clicks the microphone button in the meeting room, this is the 3rd Party VoIP channel which is activated, not the default VoIP channel of Connect 8.
If i am right, could someone please kindly provide with some manual, which describes technical details of how this should be done and what are the technical requirements to the VoIP provider, so that we can discuss these details with our current VoIP partner. Unfortunately the standard Help gives only the overview of this functionality, no technical details and the only document which i got from the local Adobe office is this one (and it is also just a general information)..
Thanx, folks!
    Mar 22, 2011 1:17 AM   in reply to Rrrrazorfish
    Yes, Adobe Connect can integrate with any SIP provider:
    Adobe Connect Universal Voice uses a component called Flash Media Gateway to send and receive audio from a SIP
    server. Install Flash Media Gateway and configure it to communicate with a SIP server. The SIP server can be hosted
    by a third-party or part of your company’s infrastructure. (SIP providers are also called VoIP providers.)
    See the installation documentation: http://help.adobe.com/en_US/connect/8.0/installconfigure/connect_8_ins tall.pdf
    Mar 22, 2011 3:49 AM   in reply to Rrrrazorfish
    That is truly available today in Connect!
    When the HOST begins the meeting, they start the audio session via the menu. They have three options:
    1. Use the computer (VOIP...hands-free....speakers/mike from PC/Mac...or use PC/Mac headset like Skype would)
    2. Dial into the audio conference provider
    3. Receive a call from the audio provider
    Once they choose their option, the audio is begun.
    If they want to start broadcasting VOIP then they go back to the audio menu and use the start broadcasting option which then allows attendees to use VOIP.
    So, it is ultimately in the hands of the HOST to use VOIP or not.  Some hosts choose not to use VOIP for obvious reasons:
    1. bandwidth may be very low and using VOIP can increase the need for bandwidth
    2. past network troubles may indicate an unstable or poorly created network infrastructure which has caused poor VOIP experiences
    3. Desire to use telephonic voice grade audio provider rather than an unpredictable VOIP quality audio option
    I frequently do not turn on VOIP if I do not know what the network condition is with attendees or if a large number of people will be on the call. More people on the call using VOIP will increase bandwidth requirements and some people may not have the bandwidth available to have a good experience.
    The use of VOIP versus an audio provider depends on the country one resides in and the audio providers chosen. In some countries VOIP is better than some audio providers but in others it is the opposite. Your mileage may vary depending on so many factors.
    Mar 22, 2011 4:54 AM   in reply to Rrrrazorfish
    Understand, that the default audio used in Adobe Connect uses whatever third party SIP provider the installer used when they installed Adobe Connect Server. There is no VOIP in C8 unless you provide a third party SIP server address when installing Connect. AC does not provide SIP or VOIP unless an outside provider is integrated following the install guide.
    See this on page 39-40 of the install guide:
    "Adobe Connect Universal Voice uses a component called Flash Media Gateway to send and receive audio from a SIP server. Install Flash Media Gateway and configure it to communicate with a SIP server. The SIP server can be hosted by a third-party or part of your company’s infrastructure. (SIP providers are also called VoIP providers.)"
    Understand, I have always been talking about Adobe Connect On-Premise or Licensed as we call it where you install your own server yourself and you maintain and control it completely. We have many customers that have their own servers so they can control everything to fit their needs.
    If what you are really asking is can a customer of an Adobe Hosted server replace the provided SIP provider and replace that with one of their choosing, then the answer is no.  Why? Because all customers on the one server cluster are using the server together and there is no way to separate the SIP/FMG server. Each Connect server is using one FMG and one SIP interface and that is all included inside the Connect Server. You cannot have any more than one FMG server with Connect. When you opt for using any hosted type service you give up a lot in the options for customization as well as flexibility of when you are upgraded to the next release or what features you want turned off or on. You are sharing that server with many other customers.
    I hope that clarifies the issue.
    Apr 2, 2011 6:59 AM   in reply to Rrrrazorfish
    Yes, you can use any VOIP phone device or use a headset or use the PC/Mac speakers/microphone in Connect easily. I do this all the time. You have the option to use any SIP provider you want when you install Connect.
    The picture is using a phone picture but it can be ANY audio device connected to your computer.
    If you have further questions on this topic, please let's take this offline and trade emails directly. I would be happy to help you or further explain options.  My direct email is:  hdrummon@adobe.com
    Thank you.
