Hi to everyone
As you Know my AS3 Knowledge it's pretty basic ... I'm re-building my web site and I will like to add a Fliping clock, a few days a go i found this images that would help me to the create the clcok. How can I create (or found) this fliping clock.
PD: I will like to write the code to learn more AS3
http://www.skpepublicidad.com/
http://resources.bloguite.com/png/arrivals-board-letters-psd-png
You'd need two separate skills for this:
1. Create a clock with Timer and Date classes.
2. Display the time using split-flap display animation
1. Create a Timer and on each timeout create a new Date object and read the current time from it.
2. Well, this is AS3 forum, so this topic is not in the scope of the discussion but once you create a linear animation of 0 to 9 (and back to 0), you can just gotoAndPlay() according to the time you get from above.
Hi and thaks.
Thanks for your instructions, searching the web found this user that create the fliping clock that I need but it's in AS2 and the re-building site is in AS3.
Check it out.
http://www.ffiles.com/flash/clocks_and_date/flip_clock_before_digital_2205.html
Thanks a lot.
