How many RAID 0's can I support?
Mar 17, 2011 10:34 AM
Hi All,
I've got an ASUS Sabertooth MB, Core i7 950, 12gb Tri Channel 1600 mhz ram, 850 watt corsair power supply,a nd GTX 470.
My boot drive is a 300gb Velociraptor, and I have 2 Samsung 1 TB in a RAID 0.
Question:  Can my setup support another RAID 0?  I only ask cause I can get 2 Western Digital 500 gb drives for $50 each and I think it would compliment my system nicely.
Any feedback would be greatly appreciated.
    Mar 17, 2011 10:46 AM   in reply to Adamousman
    Sure. no problem you can Also mare 1 more Raid0 3x Western Digital 500 gb you will gain as well reading and writing speed.
    Mar 18, 2011 6:39 AM   in reply to Adamousman
    I tellyou my config:
    1t caviar black OS, 3x300 w.d. Raptors for proyect and 1tb for backup.
    BASE on the PPBM5 http://ppbm5.com/  even with only 2 x300 w.d. raptors I have the best Disk I/O test for raid0 taking out the SSD and the pc's whiot raid controllers, so I will tell you to get 1 raptor more and use that for proyect disk.
    Trusme I hav try maaaaanyyyyy configuration without raid controlers.
    B.R.
    Cristobal.
    Mar 18, 2011 10:57 AM   in reply to Adamousman
    Adamousman,
    Your system sounds solid and also pretty balanced to me as described already. Before I would comment where to add a small investment to improve on what you have already, I would like to see your PPBM5 score broken down by category. Have you run PPBM5 yet?
    Also, in another one of your threads, Cristobal suggested you overclock your 950 to 4 GHz. If you still have your stock cooler, ditch it for something better and overclock you CPU at least some, even if not up to 4.0.
    If you have not seen my thread on how changes to various PC components impacted my PPBM5 score, check it out to get a feel for how CPU speed, RAM size, and drive setup changed how fast Premiere Pro performed on a single system:
    http://forums.adobe.com/message/3465135#3465135
    You will see that drive improvements past a 2xRAID 0 like you already have were pretty subtle.
    Harm and Bill preach the importance of a good Premiere Pro system being a sum of all of the parts and that is so true!
    Regards,
    Jim
