Hi folks,
I'm using DW CS4 and PHP. I've got a php page with a dynamic table and repeating region that I built for my client. This table lists our entire active member list. Initially I built the dynamic table to show only 50 records at a time because 300+ records made an overly long page. Now my client wants all the records on a single page, because he doesn't like clicking through the recordset paging of First - Next - Previous - Last list to find who he is looking for. I tried changing the Repeating Region behavior to All Records (rather than 50) but it still displays only 50. I'm sure this is because initially when I set up the dynamic table, I limited it to 50 there. Is there an easy way to change the dynamic table from 50 to All Records, without rebuilding the entire page? I've looked in several places and can't find a way to edit this. Thanks for your help,
Gail
There is probably gone something wrong in your code.
You must be able to find it.
With me it sometimes occurs that a code is placed twice
where the old one is shown last and therefore overwrites the newly placed code.
I am not really a programmer so there are people around here that can help you better.
But maybe it is worth while to look if this has occurred.
Jos
If the page in question is - apart from the table - not overly complex, the probably most straight forward way is to...
a) copy the table *code* to the clipboard and paste it into, say, a simple text editor such as NotePad
b) rename the current document to something else for backup purposes
c) create a new document and insert a simple Recordset (needs to be named identically to allow for an easy transition)
d) paste the table code back in here
Gunter,
Thanks for your continued help on this forum. You have made people's
work a lot easier and stuck with them through some thorny issues.
If I may redirect you to an issue I had a few months back - the initial
posting was here at:
http://forums.adobe.com/thread/767154?tstart=300
I couldn't turn the answers I received into a workable solution. Would
you be willing to take a look at this?
Thanks again for your help,
Gail
I believe the answer is a recordset paging document. If I can do A,B,C
navigation to our member list, then we don't have to have that ugly full
page of all 300+ members. This is what I was originally trying to do
(not list them all on a single page as you have helped me with), but I
couldn't accomplish it. My recordset consists of firstname, lastname,
userID and email. Then I have a separate column we can link on, where we
can either Edit each member, or Delete them.
Thanks.
Message was edited by: Günter Schenk. Reason: Contact details removed at the request of the OP
North America
Asia Pacific
