Photoshop to Illustrator: background not transparent
Mar 18, 2011 10:03 AM
Hello everyone,
Can someone tell me why this happens and how to fix or get around or tell me the proper method?  When transferring from Photoshop to Illustrator by copy/paste or directly dragging an image, object, etc., the background in not transparent.  My workaround is to save as .psd and place in Illustrator, which is a pain.  I thought there was "seamless" integration.
Thanks a bunch,
Gustavo
Santa Fe, NM
Owl Design Studios
    Mar 18, 2011 11:14 AM   in reply to El Gu man
    Drag and drop from the document window in Photoshop to Illustrator always works for me.
    I'd consider using the Place command seamless integration as well.
    Mar 18, 2011 12:01 PM   in reply to El Gu man
    The .psd file must contain layers with the object on an upper layer and a transparent background layer. I wrong about multiple layers It can have only a single layer but that cannot be listed as a background layer nor can it be flattened.
    Mar 18, 2011 12:03 PM   in reply to El Gu man
    Your original workaround of placing .psd files is the way to work. If you work with hi res images, then you want to link to the files, so that your computer does not slow down. You also have better control over color profiles that way, so each printer can swap in their profiles, for each time you use that image.
    Mar 18, 2011 12:13 PM   in reply to Larry G. Schneider
    And, if you uncheck the Link option and get the next dialogue... make sure you check the Convert Layers to Objects...
    Mar 18, 2011 1:35 PM   in reply to El Gu man
    Using copy/paste is done by means of the OS and will flatten the file. You can drag the file from the desktop and have it retain the transparency.
Bookmarked By (1)
