I've had no problem at all launching my Android AIR app on my Samsung Vibrant phone.
However, I just downloaded installed the new AIR 2.6 SDK, updated my application descriptor to 2.6 and can test without issue on the desktop; however, attempting to either Run or Debug on my phone avails the following error:
An internal error occurred during: "Launching Rhuz - Mobile".
com.adobe.air.apk.APKPackager.setDebugHost(Ljava/lang/String;)V
If I switch my compiler settings back to 2.5 and revert the descriptor, I can still test on desktop and phone. The issue only appears with the 2.6 SDK.
Google is no help at all, so I'm giving it a shot here. I'm running Flash Builder Burrito on Win 7 x64.
FB 4.0.1 does not support mobile application development. If you would like to build AIR applications for Android platform, FB Burrito Preview Release is pretty much the only option until the final product, which supports AIR SDK 2.6, gets released.
Another option is to build your application using Burrito and package output swf and assets with AIR SDK 2.6 command line tools.
-Sedat
Same problem here. On OS X 10.6.6.
Hi guys,
Thanks for the report. I'll look into this and get back to you asap.
Chris
Hi, i have the same problem on:
- Win Vista,
- AIR 2.6
- FB Burrito
- Motorola Droid
regards
Lucas
For those interested in using 2.6 with Flash Builder 4, please check out Christian Cantrell's blog where he describes a compiler argument that can be added to your project that will allow you to work around the problem:
How to Use AIR 2.6 with Flash Builder 4
Chris
Hi drekfeddon
Thank you for reporting your issue. I am a QA in AIR Android team and would like to investigate your issue further but I will need your help. Could you provide us your zipped source code and your Android AIR application?
Regards,
Hiroko
Hi Hiroko,
Sure, where should I send the .zip file?
If you'd like, you can email them to ccampbel@adobe.com and I'll forward them along to Hiroko.
Chris
Flash Builder Burrito (Preview release) does not support AIR SDK 2.6 because some APIs have changed in the AIR SDK 2.6 and Flash Builder Burrito does not aware of those changes. Therefore, what you are seeing is an expected behavior.
Please let me know if you have any other questions.
Sedat Akkus
Computer Scientist, Flash Builder
Thanks for the update.
Just so I'm clear here: should I then simply ditch Burrito altogether and instead use FB4.01 for my AIR/Android app?
-Sedat
Got it. Many thanks!
i got a same problem, too.
On Mac OS X 10.6.7
