DEloise41
Flash Player and facebook not working...
Mar 23, 2011 9:56 AM
Hello,  My computer was having all kinds of problems, so I took it in to get it fixed.  I got it back home and had to re-download all Adobe products.  I get onto Facebook and it tells me over and over again to download the latest version of Flash Player.  No matter what, it still doesn't work.  Anybody got any ideas?
    Mar 23, 2011 10:09 AM   in reply to DEloise41
    Hi, I don't have any idea what was fixed, so can't address that. You need to furnish your Operating System info/32bit OS or 64bit OS. Browser(s) used and versions are needed also.  However due to Facebook/games a site that appears to pick up Viruses/Malware, you need to do the following:
    Go to this thread and follow these instructions: http://forums.adobe.com/thread/782435?tstart=0
    open the registry editor: Start | Run | type regedit.exe
    navigate to this registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\ActiveX Compatibility\{D27CDB6E-AE6D-11CF-96B8-444553540000}
    if that key does not exist, then the "kill-bit" for Flash Player is not set
    if it contains a DWORD entry with the name Compatibility Flags that has any value other than 0x00000000, then the "kill-bit" for Flash Player may be set
    Read this carefully.
    If you do find that the Kill-bit is set, use the zipfile method at the bottom of Post#4
    eidnolb
    Mar 23, 2011 1:13 PM   in reply to DEloise41
    Hi, ok. Post#4 is in that same thread, just page down a little and you'll see it. Or: http://forums.adobe.com/message/3434922#3434922
    eidnolb
    Mar 23, 2011 4:05 PM   in reply to DEloise41
    Hi, You have to follow the instructions for the removal of the Kill-bit because it does work. Read it over again to make sure you are doing it correctly.
    eidnolb
