Eclipse update site for FlexUnit 4.1?
Mar 23, 2011 4:41 PM
Is there an update site that I can point Eclipse at to update the FlexUnit plugin to FlexUnit 4.1?
If not, then how are people updating Eclipse?
    Mar 23, 2011 4:46 PM   in reply to Wrataxas
    Hi FlexUnit does not have an eclipse plugin. The eclipse plugin that you are likely thinking of is part of Flash Builder, not part of FlexUnit.
    So, any updates to that will be provided by Adobe if it is ever updated.
    FlexUnit is just an actionscript library,
    Mike
    Mar 24, 2011 7:18 AM   in reply to Wrataxas
    Hi-
    Okay, so, you are looking at the eclipse pieces in Flash Builder for FlexUnit. A few things you need to understand. First, that code is part of Flash Builder. It is produced by Adobe. It is not open source. It is not part of the FlexUnit project. Anyone is free to write an eclipse plugin that calls the FlexUnit library. That is what Adobe did in this case. There is no update available for the FlexUnit window in Flash Builder that I know of. If there were an update, it would likely be sold as part of the next Flash Builder.
    FlexUnit is an actionscript library. So, it is not Java and it doesn't live in Eclipse. It is really just a SWC file. The FlexUnit view inside of Flash Builder just shows the result information produced by FlexUnit and provides a semi-convenient way to launch FlexUnit in a web browser.
    In the 4.0 version of Flash Builder, Adobe did provide an easy mechanism to update the FlexUnit library. They changed this in the beta for the next version, but if you are running 4.0, there is no automated way.The easiest mechanism is just to grab the latest flexunit library and drop it in your library path and all will work.
    If you want to update it across all projects, you can  hunt in the Flash Builder installed files, you will eventually find a file named flexunit-(version info).swc. Just replace this file with an updated one from the flexunit site and all will work.
    I hope that clarifies things and I am trying to help, but these pieces aren't maintained by the FlexUnit team, so it really comes down to Flash Builder questions.
    Mike
    Oct 24, 2011 8:25 AM   in reply to Michael Labriola
    Thanks for the description.  Maybe you can answer this as well since it's related. I'm currently using Flash Builder 4.0 with the built-in Flex Unit 4.0.  I'm using the eclipse plugin which I find very convenient to easily control what tests are run and to run them again. I find myself focusing on individual or groups of tests when things go bad and I rather not run all the other ones while debugging.  Prior to Flash Builder 4, I was using the stand alone for Flex Unit 4.0 and the only way I could figure out how to just run individual tests were to comment my code which wasn't optimal.
    My problem right now is that I would really love to use the Parameterized Testing feature, but that's not part of 4.0.  Does anyone know of a hack to get the 4.1 version of Flex Unit to work in this environment?  This way I can take advantage of the plugin, but still have the latest Flex Unit features.
    If not, is there an easy way to control which tests get run when using Flex Unit 4.1 stand alone?
    Oct 24, 2011 8:42 AM   in reply to markdemi
    All you need to do is add the FlexUnit 4.1 swc to your library path. So, if your project already has a libs folder, you can drop the flexunit swc in there, or from the projet properies add the swc to the library path regardless of where it is at on your drive.
    You will then be using the 4.1 library
    Oct 24, 2011 10:19 AM   in reply to Michael Labriola
    I had tried that with no luck.  Just in case I made a mistake I tried again and still no luck.  Here's what I did.
    1.  I dropped all SWCs from flexunit 4.1 distribution into my libs folder.  This includes the following files.
    flexunit-cilistener-4.1.0-8-4.1.0.16076.swc
    flexunit-flexcoverlistener-4.1.0-8-4.1.0.16076.swc
    flexunit-4.1.0-8-as3_4.1.0.16076.swc
    flexunit-4.1.0-8-flex_4.1.0.16076.swc
    flexunit-aircilistener-4.1.0-8-4.1.0.16076.swc
    fluint-extensions-4.1.0-8-4.1.0.16076.swc
    flexunit-uilistener-4.1.0-8-4.1.0.16076.swc
    When I right-click on the Project and select "Execute Flex Unit Tests".  I get the following errors.
    DescriptionResourcePathLocationType
    1046: Type was not found or was not a compile-time constant: [flash.events]::IEventDispatcher.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: [org.flexunit.internals.runners.statements]::IAsyncHandlingStatement.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: [org.flexunit.internals.runners.statements]::IAsyncStatement.UnitTestsUnknown
    Flex Problem
    On top of this, I noticed that inside FlexUnitApplication.mxml, it adds another <flexui:FlexUnitTestRunnerUI> tag.  I'm not sure why.
    Keep in mind that flashbuilder 4.0 keeps on adding back the old library references as well.  So technically, I have both of them in there.  THe old ones are in the project settings and the new ones are in the libs folder.
    If you can help me sort this out, I would really appreciate it.
    Oct 24, 2011 10:21 AM   in reply to markdemi
    yes, there are different options in that zip and you put mutually exclusive ones together
    see the names:
    flexunit-4.1.0-8-as3_4.1.0.16076.swc and flexunit-4.1.0-8-flex_4.1.0.16076.swc
    One of those is if you want a Flex version, one of those if you want an AS version. Given the errors, you probably want to delete the -as3 version for your particular setup. You really don't need the rest of those.
    Basically, just put flexunit-4.1.0-8-flex_4.1.0.16076.swc in that path and I think you will be good.
    Mike
    Oct 24, 2011 10:41 AM   in reply to Michael Labriola
    Still not good (sorry).  I tried the flex one alone, and when that didn't work, I add the following.
    To be honest, I'm a bit confused as to how this all fits together.  I'm assuming that when I run "Execute FlexUnit Tests" from the Navigator, that the Adobe plugin will interrogate the code and set up the main test application called FlexUnitApplication.mxml.  Then it just runs that.
    To normalize my results I did this.
    1.  Cleaned Unit Test project.
    2.  Ran Execute Flex Unit Test from navigator.  This time it ran, but the Test method I had using a dataProvider, similar to the example on the website, gave the following error.
         "Error: Method badFormTest should have no parameters.
    Here's a portion of the code.
    public static function badFormTests():Array {
                return [
                    /* Testing comment 17110 */
                    ["-9*r+27*s+63*t","-9*r--27*s--63*t"],
                    ["-9*r+27*s+63*t","-9*r+--27*s+--63*t"],
                    ["x+3","x--3"],
                    ["x+3","x++3"],
                    ["x+3","x+--3"] ,
                    ["x+3","++3+x"],
                    ["x-3","x---3"],
                    ["5x-3","--5x+-3"],
                    ["5x-3","-3--5x"],
                    ["5x+3","5x--3"],
                    ["5x+3","5x++3"],
                    ["5x+3","5x+--3"],
                    ["5x+3","++3+5x"],
                    ["5x-3","5x---3"],
                    ["5x-3","--5x+-3"],
                    ["5x-3","-3--5x"],
                    ["5x-3","--5x+-3"],
                    ["5x-3","-3--x5"],
                    ["5x+3","x5--3"],
                    ["5x+3","x5++3"],
                    ["5x+3","x5+--3"],
                    ["5x+3","++3+x5"],
                    ["5x-3","x5---3"],
                    ["5x-3","--x5+-3"],
                    ["5x-3","-3--x5"],
                    ["x+3","x-(-3)"]
                    /* End comment 17110 */
            [Test(dataProvider="badFormTests")]
            public function badFormTest(correctExpr:String, responseExpr:String ):void
                Assert.assertEquals(
                    TDXEvaluatorStatus.NAMES[TDXEvaluatorStatus.BADFORM],
                    evaluate(TDXAnswerRules.ACCEPTSIMILARFORM,
                        correctExpr,
                        responseExpr
    On top of this, if edit any one of my source files (i.e., add and remove a space and save it) and build the project again, I get many errors.  Here they are.
    1046: Type was not found or was not a compile-time constant: [org.flexunit.async]::IAsyncTestResponder.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: [org.flexunit.internals.runners.statements]::IAsyncStatement.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: AsyncResponseEvent.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: AsyncTestResponder.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: FlexEnvironmentBuilder.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: FlexMXVisualTestEnvironment.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: ISequenceAction.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: ISequencePend.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: ISequenceStep.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: SequenceBindingWaiter.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: SequenceCaller.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: SequenceDelay.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: SequenceEventDispatcher.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: SequenceRunner.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: SequenceSetter.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: SequenceWaiter.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: TextListener.UnitTestsUnknownFlex Problem
    1046: Type was not found or was not a compile-time constant: VisualTestEnvironmentBuilder.UnitTestsUnknownFlex Problem
    I appologize if I'm doing something bad. I really appreciate your help.
    Oct 24, 2011 10:50 AM   in reply to markdemi
    No problem, I am glad to help. It seems FlashBuilder is in a weird state, but lets try to work through it. There have been some other reports in the forums of issues like yours, however, I don't know if there were resolutions as of yet.
    I would like to try to start by simplifying things, so, first, lets make sure you have just that flexunit-4.1.0-8-flex_4.1.0.16076.swc in the library path.
    Here is an overview of the others:
    -for use with continuous integration servers... not needed now
    -for us with code coverage, not needed now
    -flexunit but specifically compiled without any flex extensions
    -flexunit but compiled with flex extensions
    -for use with continuous integration servers when testing air apps
    -for use by people using sequences and other concepts originally from fluint. This may or may not be needed by you, can't tell yet but we will get there
    -for us when you need a UI to see test results. not needed with flash builder
    After that, I would delete the two files in the main package that Flash Builder creates. They get out of sync sometimes. Then just choose one test in your package explorer. Right click on it and choose Execute FlexUnit Test. Let's see the result from that and then we can debug more.
    Mike
    Oct 24, 2011 11:32 AM   in reply to Michael Labriola
    Ok, as a first step in simplifying things, I created a new project with a  single test class with a single test and got it working with the built-in stuff.
    I then added flexunit-4.1.0-8-flex_4.1.0.16076.swc to the libs folder and right-clicked on the Test Class and selected Execute FlexUnit Test and it seemed to work.
    Now here's something odd, I went to the Project node in the Navigator and selected Execute FlexUnit Test and got all those errors from my previous post.  Then I noticed something very interesting.  If I modify any file (in this case my Test Class by adding a space, removing it and saving the file), then I select Project Builder (my automatic build is turned off), it will compile with errror every other time.  It's very repeatable.
    Then I noticed that my prject had an option checked to "Automatically determine library ordering based on dependencies".  For the heck of it I turned that off and tried again.  Same response.  Then I moved the libs folder reference to the end of the list (after the Flash Bulder 4 flex unit folders) and tried again and still the same response.
    Since my project is small, I could package it up in a zip if that helps?
    Oct 24, 2011 11:34 AM   in reply to markdemi
    Sure. If you can post it somewhere and give me a link else, email it to me.
    I will send you a private forum message with my email address.
    Mike
    Dec 16, 2011 11:52 AM   in reply to Michael Labriola
    Mike,
    I'm still unable to get the latest Flex Unit 4.1 working with Flash Builder 4.  Any chance on getting any info on this.  I searched around and couldn't find any new info.  I did find this explanation for Flashbuilder 4.5 (http://workflowflash.com/105879/flash-builder-4-5-tip-use-a-custom-fle xunit-sdk.php), but i'm using Flash builder 4.0, with flex sdk 4.1.
    I've created a simple test project and can attempt to isolate the issue with a little guidance if you have time.
    Mark
