nathan@techniks
Book Synchronization Issues: Swatches
Mar 24, 2011 12:57 PM
I have updated my Swatch panel in one document and want to update to the entire book. I have made sure that no docs. are selected in the Book panel and that Swatches is selected in the Book Synchronization dialog box, but my other docs'. Swatch panels do not update.
    Mar 24, 2011 1:05 PM   in reply to nathan@techniks
    And you actually told the book to synchronize and picked the correct file as the source, right?
    Synching may or may not be obvious. What it would do for swatches is redefine any that had the same name and add any that were not already present from the source doc, but it would not remove any extras in the destination that don't appear in the source.
    Mar 24, 2011 1:28 PM   in reply to nathan@techniks
    Well you mightn ot really want to delete a swatch or style that appears in only one file in a book if it's actually in use. Someone over in scripting might have a script to step through all the files in a book and do the "Select All Unused" commands and delete in all the various panels that would apply.
  • John Hawkinson
    Jun 25, 2009
    Mar 24, 2011 8:15 PM   in reply to Peter Spier
    Well you might not really want to delete a swatch or style that appears in only one file in a book if it's actually in use. Someone over in scripting might have a script to step through all the files in a book and do the "Select All Unused" commands and delete in all the various panels that would apply.
    OK, I was dumb enough to volunteer, but it turns out this is a bit harder than it looks.
    There's not actually a command in scripting-land to "Select All Unused," so the trick becomes figuring out "what's an unused paragraph style?
    What's an unused swatch?"
    So, cribbing heavily from some previous threads: Delete Unused Paragraph Styles, [CS3][VBS] Delete Unused Swatches ALSO clears Gradient Swatches!, and Deleting unused swatches change the gradient, here's a solution that might work. But it might also cause problems for your gradients, if you have any. And it doesn't bother with Character Styles, because the method I've chosen (not necessarily the best) for finding paragraph styles looks at every paragraph. And looking at every character can be too slow (but you can uncomment that section if you like).
    If you have a fixed list of swatches you want to remove (you could generate one by, for instance, selecting all unused swatches, exporting them to an ASE file, loading the ASE file in a new document, and then either using a quick script to print out the names of all the current swatches, or exporting the document to IDML and pulling them out of Resources/Graphic.xml or whatever), and the current implementation doesn't work, it'd be easy enough
    to modify it to handle that.
    Anyhow, this script opens each document of the book in turn, removes paragraph styles and swatches, pops up an alert telling you how many it removed, and moves on to the next document. It doesn't save anything, deliberately so.
    As always with scripts, paste it into a text file (such as cleanBook.jsx), and then follow the instructions at How to Install InDesign Scripts.
    // Return an object whose keys are all the unique values of
    // property prop among the elements of array arr.
    function uniqProp(arr, prop) {
        var
          i, o = {};
        for (i=arr.length-1; i>=0; i--) {
            o[arr[i][prop]] = 1;
        return o;
    // Call the .remove() method on all objects in array all
    // such that their property prop does not exist as a key
    // in used.
    function removeUnused(used, all, prop) {
        var i;
        for (i=all.length-1; i>0; i--) {
            if (!used.hasOwnProperty(all[i][prop])) {
                all[i].remove();
    // Remove unused paragraph styles and swatches from doc
    function cleanDoc(doc) {
        var
            pstyles = uniqProp(app.activeDocument.stories.everyItem().
                paragraphs.everyItem().
                appliedParagraphStyle, "name"),
            // cstyles = uniqProp(app.activeDocument.stories.everyItem().
            //    characters.everyItem().
            //    appliedCharacterStyle, "name"),
            i, p1, p2, s1, s2;
        p1 = doc.allParagraphStyles.length;
        removeUnused(pstyles, doc.allParagraphStyles, "name");
        p2 = doc.allParagraphStyles.length;
        // removeUnused(cstyles, doc.allCharacterStyles, "name");
        s1 = doc.swatches.length;
        for (i=doc.unusedSwatches.length-1; i>=0; i--) {
            doc.unusedSwatches[i].remove();
        s2 = doc.swatches.length;
        alert("Removed "+(p1-p2)+" paragraph styles, "+
            (s1-s2)+" swatches from doc "+doc.name);
    // Call cleanDoc on all documents in the book.
    function main() {
        var
            docs = app.activeBook.bookContents.everyItem().fullName,
            i;
        for (i=0; i<docs.length; i++) {
            cleanDoc(app.open(docs[i]));
    main();
    No warranty :-)
