my fp version: 10,2,153,1
browser: firefox 3.6.15
operating system: windows 7 ultimate sp1 x86
problem:
the settings manager panel does not show
unistalled and reinstalled fp quite a few times, rebooted, used the unistall_flash_player.exe as well, no errors appear during installation or uninstallation, videos on youtube and other sites play just fine and noticed no other problems, also tried firefox in safe mode with all addons disabled etc nothing helps
I'm having the same problem. I use shockwave and can't open the online Daily Jigsaw Puzzle...shockwave gave me a link to adobe to delete saved files using the setting manager panel...but the panel won't show...hope we can get an answer! BTW...all of the other games I try to play load just fine! I'm really thinking it's shockwave's problem, but it MIGHT help to get rid of these files!!
Can you try the following:
%appdata%\Adobe
%appdata%\Macromedia
Now try the Settings Manager again.
Tried deleting those directories, also ran CCcleaner to remove ALL cache files.
Still can't open global settings manager - ANY screens.
I was trying to block an annoying popup ad on a site that I'd already closed about 70 times in the past hour. I tried everything. In I.E. it worked by not being a trusted site. But in Firefox, the ONLY thing that worked was using Settings Manager to block all storage of 3rd party websites.
Only NOW, I can never again access my flashplayer settings!!! It's a catch-22.
Having been an IT professional since 1980, and seen so much over the years, my honest opinion is that Adobe Flash Player's implementation sucks!
P.S. Can't open it in IE or Firefox.
And by what wild form of imagination does this forum software judge this question to be "Possibly Answered"?
also tried the thing with deleting the folder suggested but also had no luck
i found though that by trying this:
https://www.macromedia.com/support/flashplayer/sys/settingsmanager2.swf?defaultTab=g_security
it doesn't work but if you try the settings panel afterwards, it might work,
i also found that going through the pages of adobe.com or google to find the settings panel the address looks like that:
http://macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.html
and if the settings panel is empty
then you can add "www." before macromedia.com, i.e. like that:
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.html
and at least in my case it works!!!
clone767 wrote:
http://www.macromedia.com/support/documentation/en/flashplayer/help/se ttings_manager02.htmland at least in my case it works!!!
That is the Global Settings Manager; where else did you try before...?
like i said, the exact same address but without www cause through adobe pages but also through google the settings panel page address is the same but without "www"
But that's not where it takes you when you invoke the Global Settings Manager through a Flash object, e.g. from http://www.adobe.com/software/flash/about/ - you will always be taken to the www site.
i don't know why but whenever i tried to find the settings panel to review my settings either through adobe.com or through google i ended up at
and the settings panel is empty
when you add the "www" up front, magically the panel apeared!!!!
I have the same problem with settingsmanager but in IE 9. I
can´t see anything. And the "www" or not didn´t help
I can play any game EXCEPT Daily Jigsaw!!! I just gave up and downloaded the 'off line' program and it works fine. I really think this is an Adobe problem and not a problem with our computers!
Well anyone??
I haven´t solved this problem.
Using IE9 in different machines with Win 7 (32 and 64-bit).
When I´m going to the settings manager I can´t see anything. I have tried with or whithout ActiveX-filteringe. Checked security and they are right.
If I uninstalls IE 9 and "rolls back" to IE 8 everything is OK.
I can use FP, fore exampel in Youtube but not! in Facebook.
Regards
Anders
