kbpowers
Sounds not syncing with frames
Mar 29, 2011 7:47 AM
I'm working on adding sound effects to a short animation. The first few sounds are syncing perfectly, however when I test the movie in Flash Player, at about the middle part of the animation, the sounds no longer sync; they play ahead of where they are supposed to. Testing the movie right in Flash, though, the sounds are fine. Exporting to a SWF file as well as a MPEG-4 also plays the unsynched sounds where they are not supposed to be.
The sounds were all created the same way, so I'm rather confused as to why these particular sounds are not doing what they are told in the timeline!
Thanks for your help.
  • kglad
    Jul 21, 2002
    Mar 29, 2011 7:49 AM   in reply to kbpowers
    if your sounds are attached to a timeline, in the properties panel, make sure the sync property is "stream", not "event".
  • kglad
    Jul 21, 2002
    Mar 29, 2011 8:09 AM   in reply to kbpowers
    then they'll stay in sync with your timeline even if that requires frames to be dropped from your display.
  • kglad
    Jul 21, 2002
    Mar 29, 2011 8:33 AM   in reply to kbpowers
    you can't attach files here. (and, most of us don't download and correct files unless hired.)
    Apr 15, 2012 11:33 PM   in reply to kbpowers
    I am having the EXACT same problem with my project.
