freevryheid
Burrito fails to start
Mar 31, 2011 10:02 AM
Fresh install on WinXP - no problems with install. I have an older FB4 installed on the same box. Any ideas? Here's the error log:
!SESSION 2011-03-28 07:40:38.054 -----------------------------------------------
eclipse.buildId=M20110210-1200
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 4 0 2011-03-28 07:40:47.695
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
    at org.eclipse.swt.SWT.error(SWT.java:4109)
    at org.eclipse.swt.SWT.error(SWT.java:3998)
    at org.eclipse.swt.SWT.error(SWT.java:3969)
    at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
    at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)
    at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)
    at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)
    at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)
    at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
    at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)
    at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)
    at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(Bas icSplashHandler.java:159)
    at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandle r.java:265)
    at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplas hHandler.java:86)
    at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782)
    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java: 798)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:664)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashB uilderApplication.java:102)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:369)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
!SESSION 2011-03-31 11:44:28.335 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2011-03-31 11:44:53.273
!STACK 1
!SESSION 2011-03-31 11:57:18.944 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2011-03-31 11:57:24.803
!STACK 1
    Mar 31, 2011 2:17 PM   in reply to freevryheid
    Sounds like the same problem discussed here:
    http://forums.adobe.com/thread/795958
    If you hit this after updating eclipse to a newer service release, there are some workarounds posted down toward the bottom of that thread.
    If not, please send some additional details:
    - running with the version of eclipse bundled with Burrito, or plugged into your own copy?
    - using our bundled JRE, or a system JDK/JRE?
    Perhaps try increasing the default memory settings a little in FlashBuilder.ini, and let us know whether that helps.
    -Chris
