Noel Carboni 20,984 posts
Dec 23, 2006
How to Retrieve the Default Photoshop Color Spaces?
Apr 1, 2011 12:19 PM
Specifically, I would like to be able to access the actual color profiles the user has chosen as the default RGB and Grayscale color spaces, so I can do the same things as Photoshop with untagged images.  I'm defining functionality to be similar to that of Photoshop itself when Photoshop does not provide a pointer to a document color profile via gFilterRecord->iCCprofileData.
I'm thinking along these lines:
1.  Detect if Photoshop is the host, and if not, stop and use internal defaults (e.g., sRGB).
2.  Use the property suite to ask Photoshop what the user's prefs for the appropriate color category is, depending on the image mode received.
What I don't know are the specifics, nor whether Photoshop is likely to provide a pointer to the profile in memory or whether I'll have to go open it myself (either way would be no problem).
Do you know any of the specific callbacks I'll need to code?
Meanwhile I'll be scouring the documentation.
Thanks.
-Noel
    Apr 10, 2011 3:00 PM   in reply to Noel Carboni
    I don't think that information is available.  Normally it should not matter to a plugin (which just has to deal with an existing file or document).
    Apr 11, 2011 10:33 PM   in reply to Noel Carboni
    Hmm, we'd have to add something to the API to support getting the default colorspace profiles (and policies).
    Probably easiest if you just file a feature request and explain what you're trying to do.
    Jun 24, 2012 2:38 PM   in reply to Noel Carboni
    From an automation plugin, you can get the 'colorSettings' out of the application descriptor, and at least see the name of the 'workingRGB' space, etc.
