Is this a PrintDataGrid bug / restriction / my lack of understanding?
Apr 8, 2011 11:13 AM
Hi!
I'm trying to implement PrintDataGrid in my application  and I'm encountering a peculiar problem. The printout is skipping last several  rows in the printout of each page.
I have narrowed down to what's causing this issue. My  application-level custom skin provides Flex scrolling capability to the entire  application. Presence of this scrollbar in the custom skin is causing  PrintDataGrid to skip last rows. In fact, number of rows skipped depends on the  height of the browser. If you reduce the browser height, you skip more  rows!
Is this a bug PrintDataGrid or a restriction (cannot  have PrintDataGrid within Scroller) or I'm missing something?
Please help as I'm struggling with this for several  days!
Here is simple code to reproduce the issue:
Main Application:
<?xml version="1.0"?>
<!-- printing\MultiPagePrint.mxml -->
<s:Application
    xmlns:fx="http://ns.adobe.com/mxml/2009"
    xmlns:mx="library://ns.adobe.com/flex/mx"
    initialize="initData();"
    skinClass="ApplicationSkinCustom"
    <s:states>
        <s:State name="displayState" />
        <s:State name="printState" />
    </s:states>
    <fx:Script>
        <![CDATA[
            import mx.collections.ArrayCollection;
            import mx.printing.*;
            [Bindable]
            public var dgProvider:ArrayCollection;
            public var prodIndex:Number;
            // Data initialization, called when the application initializes.
            public function initData():void {
                // Create the data provider for the DataGrid control.
                dgProvider = new ArrayCollection;
            // Fill the dgProvider ArrayCollection with the specified items.
            public function setdgProvider(items:int):void {
                // First initialize the index and clear any existing data.
                prodIndex=1;
                dgProvider.removeAll();
                // Fill the ArrayCollection, and calculate a product total.
                // For simplicity, it increases the Index field value by
                // 1, and the Qty field by 7 for each item.
                for (var z:int=0; z<items; z++) {
                    var prod1:Object = {};
                    prod1.Qty = prodIndex * 7;
                    prod1.Index = prodIndex++;
                    dgProvider.addItem(prod1);
            // The function to print the output.
            public function doPrint():void {
                currentState = "printState";
                // Create a FlexPrintJob instance.
                var printJob:FlexPrintJob = new FlexPrintJob();
                // Start the print job.
                if (printJob.start()) {
                    // Set the print view properties.
                    vGroup.width=printJob.pageWidth;
                    vGroup.height=printJob.pageHeight;
                    // Set the data provider of the FormPrintView
                    // component's DataGrid to be the data provider of
                    // the displayed DataGrid.
                    printDataGrid.dataProvider = dgProvider;
                    printJob.addObject(vGroup);
                // Send the job to the printer.
                printJob.send();
    </fx:Script>
    <s:VGroup
        excludeFrom="printState"
        width="100%"
        horizontalAlign="center"
        paddingTop="10"
        paddingBottom="10"
        paddingLeft="10"
        paddingRight="10"
        gap="10"
        <!-- The form that appears on the user's system.-->
        <mx:Form id="myForm" width="80%">
            <mx:FormHeading label="Product Information"/>
            <mx:DataGrid id="myDataGrid" dataProvider="{dgProvider}">
                <mx:columns>
                    <mx:DataGridColumn dataField="Index"/>
                    <mx:DataGridColumn dataField="Qty"/>
                </mx:columns>
            </mx:DataGrid>
            <mx:Text width="100%"
                     text="Specify the number of lines and click Fill Grid first.
                     Then you can click Print."/>
            <mx:TextInput id="dataItems" text="35"/>
            <mx:HBox>
                <mx:Button id="setDP"
                           label="Fill Grid"
                           click="setdgProvider(int(dataItems.text));"/>
                <mx:Button id="printDG"
                           label="Print"
                           click="doPrint();"/>
            </mx:HBox>
        </mx:Form>
    </s:VGroup>
    <s:VGroup
        id="vGroup"
        includeIn="printState"
        width="100%"
        paddingTop="10"
        paddingBottom="10"
        paddingLeft="10"
        paddingRight="10"
        gap="10"
        <mx:PrintDataGrid id="printDataGrid" width="60%" height="100%">
            <!-- Specify the columns to ensure that their order is correct. -->
            <mx:columns>
                <mx:DataGridColumn dataField="Index" />
                <mx:DataGridColumn dataField="Qty" />
            </mx:columns>
        </mx:PrintDataGrid>
    </s:VGroup>
</s:Application>
Application custom skin class:ApplicationSkinCustom.mxml
ADOBE SYSTEMS INCORPORATED
Copyright 2008 Adobe Systems Incorporated
All Rights Reserved.
NOTICE: Adobe permits you to use, modify, and distribute this file
in accordance with the terms of the license agreement accompanying it.
<!--- The default skin class for the Spark Application component.
@see spark.components.Application
@langversion 3.0
@playerversion Flash 10
@playerversion AIR 1.5
@productversion Flex 4
<s:Skin
    xmlns:fb="http://ns.adobe.com/flashbuilder/2009"
    alpha.disabled="0.5" alpha.disabledWithControlBar="0.5"
    <fx:Metadata>
        <![CDATA[
        * A strongly typed property that references the component to which this skin is applied.
        [HostComponent("spark.components.Application")]
    </fx:Metadata>
    <fx:Script fb:purpose="styling">
        <![CDATA[
             *  @private
            override protected function updateDisplayList(unscaledWidth:Number,
                                                          unscaledHeight:Number) : void
                bgRectFill.color = getStyle('backgroundColor');
                super.updateDisplayList(unscaledWidth, unscaledHeight);
    </fx:Script>
    <s:states>
        <s:State name="normal" />
        <s:State name="disabled" />
        <s:State name="normalWithControlBar" />
        <s:State name="disabledWithControlBar" />
    </s:states>
    <!-- fill -->
    A rectangle with a solid color fill that forms the background of the application.
    The color of the fill is set to the Application's backgroundColor property.
    <s:Rect id="backgroundRect" left="0" right="0" top="0" bottom="0"  >
        <s:fill>
            <s:SolidColor id="bgRectFill" color="#FFFFFF"/>
        </s:fill>
    </s:Rect>
    <s:Scroller left="1" top="1" right="1" bottom="1" id="scroller">
        <s:Group left="0" right="0" top="0" bottom="0">
            <s:layout>
                <s:VerticalLayout gap="0" horizontalAlign="justify" />
            </s:layout>
            @private
            Application Control Bar
            <s:Group
                id="topGroup"
                minWidth="0"
                minHeight="0"
                includeIn="normalWithControlBar, disabledWithControlBar"
                <!-- layer 0: control bar highlight -->
                <s:Rect left="0" right="0" top="0" bottom="1" >
                    <s:stroke>
                        <s:LinearGradientStroke rotation="90" weight="1">
                            <s:GradientEntry color="0xFFFFFF" />
                            <s:GradientEntry color="0xD8D8D8" />
                        </s:LinearGradientStroke>
                    </s:stroke>
                </s:Rect>
                <!-- layer 1: control bar fill -->
                <s:Rect left="1" right="1" top="1" bottom="2" >
                    <s:fill>
                        <s:LinearGradient rotation="90">
                            <s:GradientEntry color="0xEDEDED" />
                            <s:GradientEntry color="0xCDCDCD" />
                        </s:LinearGradient>
                    </s:fill>
                </s:Rect>
                <!-- layer 2: control bar divider line -->
                <s:Rect left="0" right="0" bottom="0" height="1" alpha="0.55">
                    <s:fill>
                        <s:SolidColor color="0x000000" />
                    </s:fill>
                </s:Rect>
                <!-- layer 3: control bar -->
                <!--- @copy spark.components.Application#controlBarGroup -->
                <s:Group id="controlBarGroup" left="0" right="0" top="1" bottom="1" minWidth="0" minHeight="0">
                    <s:layout>
                        <s:HorizontalLayout paddingLeft="10" paddingRight="10" paddingTop="7" paddingBottom="7" gap="10" />
                    </s:layout>
                </s:Group>
            </s:Group>
            <!--- @copy spark.components.SkinnableContainer#contentGroup -->
            <!--<s:Group id="contentGroup" width="100%" height="100%" minWidth="0" minHeight="0" />-->
            <s:Group id="contentGroup" left="0" right="0" top="0" bottom="0" />
        </s:Group>
    </s:Scroller>
</s:Skin>
    Apr 8, 2011 11:51 AM   in reply to DilipShah
    I think you may want to put the PrintDataGrid in a Canvas so you can give it
    any height you want.  Size it so it is tall enough (and maybe call
    validateNow) before submitting the page.
    Apr 11, 2011 9:20 AM   in reply to DilipShah
    Last time I checked, I am from adobe.  Post a 20-line test case.
    Apr 11, 2011 3:20 PM   in reply to DilipShah
    It is a bug in the Flash Player.  I will bring it to their attention.  You
    will have to parent your print view outside of the scroller.
