• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
INSERT INTO statement contains following unknown field name
New Here ,
Apr 11, 2011 Apr 11, 2011
I’m using Coldfusion 9,0,0,251028 on Windows 7 64-bit, with a Microsoft Access 97 database.
When I run this query:
<cfquery name="put_in_info" datasource="#db#">
      insert into news
                  (is_current, display, mes_dat,mes_tim,mes_sub,mes_text,scrollshow,exp_dat)
      values
  (1,1, #createodbcdate(now())#, #createodbctime(now())#, '#subject#', '#message#',1, #session.expdate#)
</cfquery>
I get this error:
Error Executing Database Query.
[Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver] The INSERT INTO statement contains the following unknown field name: 'exp_dat'. Make sure you have typed the name correctly, and try the operation again.   The error occurred in H:\Inetpub\pvalert.com\listserver\admin\templates\post_breaking.cfm: line 26
Called from H:\Inetpub\pvalert.com\listserver\admin\new_process.cfm: line 54
Called from H:\Inetpub\pvalert.com\listserver\admin\templates\post_breaking.cfm: line 26
24 :      (is_current, display, mes_dat,mes_tim,mes_sub,mes_text,scrollshow,exp_dat)
25 :   values
26 :   (1,1, #createodbcdate(now())#, #createodbctime(now())#, '#subject#', '#message#',1, #session.expdate#)
27 :    </cfquery>
28 :
VENDORERRORCODE
  -1507
SQLSTATE
  HYS22
SQL
   insert into news (is_current, display,   mes_dat,mes_tim,mes_sub,mes_text,scrollshow,exp_dat) values (1,1, {d   '2011-04-11'}, {t '17:49:09'}, 'Test message - please ignore', 'This is a   test message, please ignore. ',1, {ts '2011-05-15 00:00:00'})
DATASOURCE
  rpv_list
Exp_dat is an expiration date column in a table that I need to update.
I've tried removing the "session." on the expdate variable, and that did nothing.  Likewise for removing the any spaces around line 24's "exp_dat".
Views
4.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Please make sure 'exp_dat' is a valid column name in the 'news' table.
Votes
Translate
Translate
Report
Report
Guide ,
1) Why are you using Access?
2) Why are you not using cfqueryparams?
3) Completely agree, it looks simply like you've gotten the name "exp_dat" wrong.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 12, 2011 Apr 12, 2011
The place I'm working for refuses to upgrade .
Votes
Translate
Translate
Report
Report
New Here ,
Yes, here is a screenshot of the design view of the news table: http://i.imgur.com/INiNg.png
Votes
Translate
Translate
Report
Report
Explorer ,
      insert into news
                  (is_current,display,mes_dat,mes_tim,mes_sub,mes_text,scrollshow,exp_dat)
      values
        <cfqueryparam value="1" cfsqltype="cf_sql_numeric">,
        <cfqueryparam value="#DateFormat(now(),'yyyy-mm-dd')#" cfsqltype="cf_sql_date">,
        <cfqueryparam value="#TimeFormat(now(),'hh-mm-ss')#" cfsqltype="cf_sql_date">,
        <cfqueryparam value="#subject#" cfsqltype="cf_sql_varchar">,
        <cfqueryparam value="#message#" cfsqltype="cf_sql_varchar">,
        <cfqueryparam value="#DateFormat(session.expdate,'yyyy-mm-dd')#" cfsqltype="cf_sql_date">
</cfquery>
Can you please confirm this by checking?
Votes
Translate
Translate
Report
Report
New Here ,
I tried this and got:
The  cause of this output exception was that:  coldfusion.runtime.locale.CFLocaleBase$InvalidDateTimeException:  05-58-46 is an invalid date or time string..
The error occurred in H:\Inetpub\pvalert.com\listserver\admin\templates\post_breaking.cfm: line 30
Called from  H:\Inetpub\pvalert.com\listserver\admin\templates\post_breaking.cfm: line 30
28 :         <cfqueryparam value="1" cfsqltype="cf_sql_numeric">,
29 :         <cfqueryparam value="#DateFormat(now(),'yyyy-mm-dd')#" cfsqltype="cf_sql_date">,
30 :         <cfqueryparam value="#TimeFormat(now(),'hh-mm-ss')#" cfsqltype="cf_sql_date">,
31 :         <cfqueryparam value="#subject#" cfsqltype="cf_sql_varchar">,
32 :         <cfqueryparam value="#message#" cfsqltype="cf_sql_varchar">,
Votes
Translate
Translate
Report
Report
Explorer ,
I guess there is typo..
must be
<cfqueryparam value="#TimeFormat(now(),'hh-mm-ss')#" cfsqltype="cf_sql_time">
Can you please try with this and let me know if you still find any issues there.
Votes
Translate
Translate
Report
Report
LEGEND ,
Apr 13, 2011 Apr 13, 2011
LATEST
"hh-mm-ss" doesn't look like a valid time-format string to me.
However CF should just extract the time part of a CF date object anyhow, shouldn't it, before passing it to JDBC?  One shouldn't need to use dateFormat() in a CFQUERYPARAM..?
Adam
Votes
Translate
Translate
Report
Report
Enthusiast ,
We can help you more if you do the following:  write a piece of code that does a SELECT
from your table, and then displays the contents of the .ColumnList variable. Copy/paste that info into a posting.
-reed
Votes
Translate
Translate
Report
Report
New Here ,
Reed Powell wrote:
...do the following:  write a piece of code that does a SELECT
DISPLAY,EXP_DAT,ID,IS_CURRENT,MES_DAT,MES_SUB,MES_TEXT,MES_TIM,SCROLLSHOW
Votes
Translate
Translate
Report
Report
Resources
Documentation
