bryanloveless
works with GUI, not in CMD
Apr 13, 2011 3:21 PM
I am trying to setup the server to start encoding as soon as the server boots. I have followed the instructions described at: http://help.adobe.com/en_US/FlashMediaLiveEncoder/3.0/Using/WS5b3ccc51 6d4fbf351e63e3d11c104babd5-7ff6.html
I successfully "registered" it as described in the link above.  When I start the FMELauncher.exe, I get the errors:
ed Apr 13 2011 15:06:35 : Selected video input device: Osprey-230 Video Device 1
Wed Apr 13 2011 15:06:35 : Selected audio input device: Unbalanced 1 (Osprey-2X0)
Wed Apr 13 2011 15:06:35 : Failed with error 80040154:CoCreateInstance(CLSID_NullRenderer, 0, (CLSCTX_INPROC_SERVER|CLSCTX_INPROC_HANDLER), IID_IBaseFilter, pFilterVideoRenderer.ppv())
Wed Apr 13 2011 15:06:35 : Failed with error ffffff97:SetupInputVideoPreview(pFilter, pguidCategory)
Wed Apr 13 2011 15:06:35 : Failed with error ffffff97:SetupVideoPreview(pFilterSource)
Wed Apr 13 2011 15:06:35 : Error: Problem with video capture device. Please verify that the video capture device is working correctly and is not already in use.
Wed Apr 13 2011 15:06:35 : Failed with error 80040154:CoCreateInstance(CLSID_NullRenderer, 0, (CLSCTX_INPROC_SERVER|CLSCTX_INPROC_HANDLER), IID_IBaseFilter, pFilterRenderer.ppv())
Wed Apr 13 2011 15:06:35 : Error: Problem with audio capture device. Please verify that the audio capture device is working correctly and is not already in use.
Wed Apr 13 2011 15:06:35 : Closing Application.
When I start up the GUI, using the same XML settings and the same user, it works just fine.  This machine is a Windows 2008 R2 64 bit machine.
I have tried:
making this user an admin
changing "compatibility mode" on the executable
different users
different XML files
changing permissions on where the XML file and Log files exist.
Any ideas?
--Bryan
    Apr 13, 2011 3:40 PM   in reply to bryanloveless
    Hey Bryan.  I've worked with Osprey cards for eons.  Make sure you have the proper drivers for the 230 card.  You may have to download the "beta" drivers from Viewcast.  Lastly...if the drivers dont load properly, or are being "shared" with other apps on your server.....you will be SOL. I'd also clear out the default.xml in the FLME script!
    If you do the same sort of setup on a 32bit will it work?
    Lastly...try FLME3.1
    Good Luck
    KC
