Believe it or not, I had the same problem with Frame10 and couldn’t create PDFs. The answer for me was to remove some of the fonts I didn’t use from the system Fonts directory. I remembered a similar problem with Frame 6 or 7 (I have slept since then) years ago, and thought, “What the heck, I’ll try it!” It worked. Linda Hume
Problem solved! The manual that I was working on had a small PDF inserted as a graphic on the master pages for the logo. When we replaced the logo with a TIF, everything now works fine! We have been using the same templates for at least 7 years with no problem, but some combination of the new software and hardware tripped us up. Thanks for everyone’s help.
Clint Owen | Sr. Technical Writer | Crane Aerospace & Electronics | +1 425 743 8674 | Fax: +1 425 743 8113
> ... had a small PDF inserted as a graphic on the master pages for the logo.
Hmmm. So Frame still has problem with PDF import at FM10?
(FM7 is highly unstable for that.)
> When we replaced the logo with a TIF, ...
If the logo was vector PDF, you might want to re-save the PDF as EPS, and import that (and preserve the vectorness of it). If you don't have Illustrator, I think Acrobat Pro can save a PDF as EPS.
I have just upgraded to TCS 3.5 from TCS 2 on a Win 7 64 machine. Since I also have CS6 running, I deselected the Acrobat Pro installation (this is already installed).
I applied the 10.0.2 update and restarted the machine. But I can't get pdfs from Framemaker. I have tried Save As..., Save As PDF, Print to file (using Adobe PDF as printer) but still no result.
The Distiller appears briefly in the Windows taskbar but Frame doesn't seem to be communicating properly. Any ideas as to the solution?
The root of our PDF printing problem was that we were using a small PDF as a referenced graphic for the logo on our master pages. After we replaced the logo with a TIF the problem was solved. I corresponded with another person who was using a PDF as a graphic that had the same problem.
HTH,
Clint
I am having a somewhat similar issue with Distiller crashing. I don't even have to attempt to create a PDF from FM 11; all I have to do is start acrodist.exe and it crashes upon startup. I recently installed TCS 4.0 (an update to 3.0) on a 32-bit Win 7 Pro system and did not replace my already installed version of Acrobat X Pro application (which was working fine prior to installing 4.0). Since Acrobat had not been upgraded, I chose to not install it.
Do you remember which fonts you deleted to get distiller to work?
Coming to this thread after it's been running for a while, because I've just moved to a new client with FM 10.0.2.419 on Windows 7. Neither Save as PDF nor the round-the-houses Print to PDF works. Forum postings seem to suggest this is an installation-specific bug, and best addressed by upgrading to FM 11 – "throwing good money after bad" is one saying that springs to mind! Can anyone tell me how to set about diagnosing this problem, so I can hand over a maximum of information to IT – it's a closed PC, so up to them to chase Adobe Support and get solutions – and start delivering the work I'm paid for? Thanks in advance.
If you are having problems with both Save as PDF and print to PDF, you
might have a messed up Acrobat installation. I know that Acrobat X has
given me enough fits on Windows 7 64-bit to almost make me an eX-Acrobat
user! Something, including updates, seems to break Acrobat X regularly.
The fix is to delete the Adobe PDF printer, then go into Control Panel
to where you uninstall programs and choose the repair option.
You might test to see if PDF creation is also broken when creating PDF
from non-FrameMaker programs.
Are you using any PDFs as graphics? Specifically, PDF graphics which contain rastor images. We solved our original issue by replacing a PDF logo with a TIF version. Recently I imported some screen captures from a PDF of a Word document to use as graphics and the no-printing problem reared it's ugly head again. When I replaced the images with PNG versions everything worked again. PDFs that only contain vector and text data seem to work OK as imported graphics.
Niels,
Does this PC also have a full Acrobat installation? It's quite possible that if IT did the installation using the FM defaults, a copy of the PDFCreator add-on was also installed - which hoses the initial Acrobat Distiller installation. If a Repair operation from within Acrobat (Help > Repair) doesn't fix it, then you may have to re-install both Acrobat and FM making certain that the PDFCeator add-on isn't installed and that admin privileges (or account) are used to do the installation. Don't forget to then install all of the FM & Acrobat patches/updates in order of release.
North America
Asia Pacific
