How to set up subscript and superscript to the same word
Apr 18, 2011 2:41 AM
Hi, everyone. I use Adobe Illustrator CS4 in a MAC. I want to establish a chemical formula MO3- with Illustrator. It seems that I can only first type NO3, and then set 3 as subscript, afterwards I input -, and set it as superscript. But in this case 3 and – are not consistent in the horizontal position.
So I am wondering how to set up subscript and superscript to the same word at the same time? Thank you very much.
    Apr 18, 2011 2:59 AM   in reply to hys3o3@gmail.com
    hys3o3,
    You may cheat and apply Character>Baseline Shift to individual characters (to move up/down).
    Apr 18, 2011 3:10 AM   in reply to Jacob Bugge
    Jacob,
    (hys3o3, correct me if I'm wrong) I think that the problem is that the 3 and the - should have the same vertical axis. I was about to go to bed, and haven't worked this out yet.
    Peter
    Edit: I don't think you can do this in a single text object, but I'd be happy to be overruled.
    Apr 18, 2011 3:14 AM   in reply to tromboniator
    I will correct myself: set the cursor between the 3 and the -, then  in the Character Panel set the kerning to something like -400, and you should get what you want.
    Peter
    Apr 18, 2011 3:28 AM   in reply to tromboniator
    Peter,
    I hope we shall find out whether the - should be moved up/down and/or back/forth.
    Apr 18, 2011 4:24 AM   in reply to Jacob Bugge
    Jacob,
    I haven't dealt with chemistry in a long time; I think it used to be that the superscript - was after the subscript number, but Wikipedia shows them over-and-under. I thought at first it was the vertical placement we were looking for. This time I am going to bed.
    Peter
    Apr 18, 2011 6:25 AM   in reply to tromboniator
    Did you try a character style?
    Apr 19, 2011 2:22 AM   in reply to hys3o3@gmail.com
    Seems to be not too much trouble.
    With type as 12 pt, here are the settings:
    NO = normal
    3 = Subscript, track –500, baseline shift 1 pt (optional)
    _ = Superscript, baseline shift 4 pt.
    But I've never seen formulae set up like that. What does the overscore over the 3 mean? Long time since I did chemistry, maybe they've changed something.
    Apr 19, 2011 3:26 AM   in reply to Steve Fairbairn
    That's a negative sign, for the valence, or electronegativity, or what ever term they're using these days. The charge of the ion is -1. I couldn't get the tracking to do what I wanted, so I got it with kerning.
    Edit: According to Wikipedia, it's formal charge, not a term that was in use when I was studying chemistry. Sounds more like a legal term, to me.
    Apr 19, 2011 3:31 AM   in reply to hys3o3@gmail.com
    So it was both up/down and back/forth as mentioned in post #4.
    Apr 19, 2011 3:39 AM   in reply to hys3o3@gmail.com
    I would explore Illustrator's Warichu options.
    See mordy Golding's tutorial at http://rwillustrator.blogspot.com/2007/12/ask-mordy-movie-credits-text .html.
    Apr 19, 2011 4:21 AM   in reply to Mike Sargent
    Excellent, Mike, thank you.
    Apr 19, 2011 4:39 AM   in reply to tromboniator
    Nor when I was studying chemistry either. But that was nearly 50 years ago. We learned about valencies but I think negative valencies hadn't been invented then. Probably best left to the boffins anyway.
    "Oh, you should never, never doubt what nobody is sure about." (Hilaire Belloc on microbes)
    Apr 20, 2011 3:14 PM   in reply to hys3o3@gmail.com
    Read my first posting.
    I said track –500, not kern.
    Apr 20, 2011 8:09 PM   in reply to Steve Fairbairn
    Steve,
    I said kern, but I figured out the sequence to make tracking work.
    hys3o3,
    To use kerning, don't select the characters, but put the cursor between the letters you want to adjust, then set the kerning value.
    Peter
    Apr 29, 2013 11:43 AM   in reply to Steve Fairbairn
    Steve's method (using tracking) isn't working for me. I can adjust the tracking but it doesn't seem to have any effect. When I highlight the subscript character (0 in the screengrab) and set the tracking number to –500 nothing happens. The character does become very hard/impossible to select after changing the tracking (why?) hence the vertical black band in the screengrab. Any help would be appreciated as I have several charts to edit/switch into a different typeface and outlining and placing every single character will take me forever!
    Apr 29, 2013 2:21 PM   in reply to weakened vampire
    To move the subscript 0, select the superscript 3, then adjust the tracking. Tracking affects placement of the character following the selected one/ones.
