lingxue3769 Calculating status...
I want to display some real-time data on flex client. Originally, we got those data by accessing the database every about 1 seconds. But that method gave large heavy to the database. So I decided to push data to the flex client by BlazeDS, and the data are published to a JMS topic. I use ActiveMQ as JMS server, and the jboss as web server. But I failed to get data at flex client.
Some code of the configuration files as follows:
message-config.xml
<adapters>
<adapter-definition id="actionscript" class="flex.messaging.services.messaging.adapters.ActionScriptAdapter" default="true" />
<adapter-definition id="jms" class="flex.messaging.services.messaging.adapters.JMSAdapter"/>
</adapters>
<destination id="data-push-jms">
<properties>
<server>
<allow-subtopics>true</allow-subtopics>
<subtopic-separator>.</subtopic-separator>
</server>
<jms>
<destination-type>Topic</destination-type>
<message-type>javax.jms.TextMessage</message-type>
<connection-factory>java:/activemq/QueueConnectionFactory</connection-factory>
<destination-jndi-name>activemq/topic/inbound</destination-jndi-name>
<delivery-mode>PERSISTENT</delivery-mode>
<message-priority>DEFAULT_PRIORITY</message-priority>
<acknowledge-mode>AUTO_ACKNOWLEDGE</acknowledge-mode>
</jms>
</properties>
<channels>
<channel ref="my-streaming-amf" />
</channels>
<adapter ref="jms"/>
</destination>
service-config.xml
<channel-definition id="my-streaming-amf" class="mx.messaging.channels.StreamingAMFChannel">
<endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/streamingamf" class="flex.messaging.endpoints.StreamingAMFEndpoint"/>
<properties>
<idle-timeout-minutes>0</idle-timeout-minutes>
<max-streaming-clients>10</max-streaming-clients>
<server-to-client-heartbeat-millis>5000</server-to-client-heartbeat-millis>
<user-agent-settings>
<user-agent match-on="MSIE" kickstart-bytes="2048" max-streaming-connections-per-session="5"/>
<user-agent match-on="Firefox" kickstart-bytes="2048" max-streaming-connections-per-session="5"/>
</user-agent-settings>
</properties>
</channel-definition>
Publisher.java
public class TopicPublisher {
public static void main(String[] args) throws JMSException {
ActiveMQConnectionFactory factory = new ActiveMQConnectionFactory("tcp://localhost:61616");
Connection connection = factory.createConnection();
connection.start();
Session session = connection.createSession(false, Session.AUTO_ACKNOWLEDGE);
Topic topic = session.createTopic("data-push-jms");
MessageProducer producer = session.createProducer(topic);
producer.setDeliveryMode(DeliveryMode.NON_PERSISTENT);
while(true) {
ObjectMessage objMessage = session.createObjectMessage();
ArrayCollection aCollection = new ArrayCollection();
HashMap map = new HashMap();
map.put("name", "Sun490");
map.put("cup_use_rate", Math.random());
map.put("borad_temp", ((int)(Math.random()*10000))/100.00);
aCollection.add(map);
map.put("name", "Org10g");
objMessage.setObject(aCollection);
producer.send(objMessage);
try {
Thread.sleep(2000);
} catch (InterruptedException e) {
e.printStackTrace();
main.mxml
<mx:Script>
<![CDATA[
import mx.messaging.events.MessageFaultEvent;
import mx.controls.Alert;
import mx.rpc.events.ResultEvent;
import mx.messaging.Consumer;
import mx.messaging.Channel;
import mx.messaging.ChannelSet;
import mx.messaging.events.MessageEvent;
import mx.collections.ArrayCollection;
public function submsg():void
var consumer:Consumer = new Consumer();
consumer.destination = data-push-jms;
consumer.channelSet = new ChannelSet([my-streaming-amf]);
consumer.addEventListener(MessageEvent.MESSAGE, messageHandler);
consumer.addEventListener(MessageFaultEvent.FAULT,handleFaults);
consumer.subscribe();
private function handleFaults(event:MessageFaultEvent):void
Alert.show(event.faultString);
private function messageHandler(event:MessageEvent):void
var tick:ArrayCollection = ArrayCollection(event.message.body);
dg.dataProvider = tick;
</mx:Script>
<mx:DataGrid id="dg" x="25" y="29" width="397" height="170">
<mx:columns>
<mx:DataGridColumn dataField="name" headerText="设备名称"/>
<mx:DataGridColumn dataField="cup_use_rate" headerText="CPU使用率"/>
<mx:DataGridColumn dataField="borad_temp" headerText="主板温度"/>
</mx:columns>
</mx:DataGrid>
The activemq-jms-ds.xml file for integration of jboss and ActiveMQ is as follows:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE connection-factories
PUBLIC -//JBoss//DTD JBOSS JCA Config 1.5//EN
http://www.jboss.org/j2ee/dtd/jboss-ds_1_5.dtd>
<connection-factories>
<tx-connection-factory>
<jndi-name>activemq/QueueConnectionFactory</jndi-name>
<xa-transaction/>
<track-connection-by-tx/>
<rar-name>activemq-ra.rar</rar-name>
<connection-definition>javax.jms.QueueConnectionFactory</connection-definition>
<ServerUrl>vm://localhost</ServerUrl>
<!-- <ServerUrl>tcp://localhost:61616</ServerUrl> -->
<UserName>sa</UserName>
<Password></Password>
<min-pool-size>1</min-pool-size>
<max-pool-size>200</max-pool-size>
<blocking-timeout-millis>30000</blocking-timeout-millis>
<idle-timeout-minutes>3</idle-timeout-minutes>
</tx-connection-factory>
<jndi-name>activemq/TopicConnectionFactory</jndi-name>
<xa-transaction/>
<connection-definition>javax.jms.TopicConnectionFactory</connection-definition>
<mbean code="org.jboss.resource.deployment.AdminObject" name="activemq.queue:name=outboundQueue">
<attribute name="JNDIName">activemq/queue/outbound</attribute>
<depends optional-attribute-name="RARName">jboss.jca:service=RARDeployment,name='activemq-ra.rar'</depends>
<attribute name="Type">javax.jms.Queue</attribute>
<attribute name="Properties">PhysicalName=queue.outbound</attribute>
</mbean>
<mbean code="org.jboss.resource.deployment.AdminObject" name="activemq.topic:name=inboundTopic">
<attribute name="JNDIName">activemq/topic/inbound</attribute>
<attribute name="Type">javax.jms.Topic</attribute>
<attribute name="Properties">PhysicalName=topic.inbound</attribute>
</mbean>
</connection-factories>
Expected for your help!
Thanks very much!
