Ed.Macke 644 posts
Mar 17, 2006
What the heck is this AVI file?
Apr 19, 2011 5:51 AM
The orignal source is from a security camera DVR (Lorex, if it matters).
Lorex supplied a utility to convert the original source to AVI, but when I tried using it in PrE it choked. I've attached the gspot screen grab.
Any hope for using this? Any other conversion utility you can recommend to get it into DV-AVI?
    Apr 19, 2011 5:56 AM   in reply to Ed.Macke
    It's an MP4 disguised as an AVI, Ed. You can try changing the suffix to .mp4 -- but that probably won't make it go either.
    It also appears to be a PAL tv format file with an odd frame rate.
    I would be very surprised if this file worked at all in Premiere Elements.
    I'd give Vegas Movie Studio HD a try. Or Ulead's Video Studio. You should be able to download free trials of each.
    Apr 19, 2011 6:03 AM   in reply to Ed.Macke
    Ed,
    That is a PAL file, with the H.264 CODEC, wrapped in an AVI container. Note: there are several variations of the H.264 CODEC, plus several suppliers of those. Some, like Apple's, Lead's and MainConcept, for example, are virtually identical, but some do deviate, within the H.264 specs. AVCHD is a version of H.264 - a sub-set, if you will.
    If you have a recent version of Apple's QT Player installed, you have the Apple version of H.264. The "CODEC not installed" indicates that either this version is not close enough to Apple's version, that Apple's is not installed properly or that G-Spot cannot find it, which seems unlikely.
    I would also run that file through MediaInfo, to see if you can get more information on the exact CODEC. If you have Apple's QT Pro, you can also Open that file (do a test play, to see if QT can read the file), and then hit Ctrl+J to view the Properties. QT Player probably has a Properties panel, but I would assume that it might be somewhat limited, and do not know if Ctrl+J brings it up. As I only have copies of Pro, I cannot even test for you.
    Apr 19, 2011 6:59 AM   in reply to Ed.Macke
    Ed,
    Platypus is an apt description.
    As for converters, some contain, or install, their CODEC's. Seems that Super does, but as I have never used it, am not sure. Others here will know. My chosen conversion program, DigitalMedia Converter 2.7, will not install any CODEC's, and does not have any of its own, so one MUST have the proper CODEC installed on the system.
    VLC Player contains its own CODEC's, so that is why it can play the file, though you do not have the necessary CODEC installed, per G-Spot. This ability to play so much "stuff" really fools a lot of people, as they cannot understand why VLC can play a file, but other programs cannot. It is because those other programs only use system CODEC's.
    Not sure which other NLE's might work (you will still probably need to install the H.264 CODEC, unless the NLE does so), but besides Steve's suggestions, also take a look at Magix MovieEdit Pro (also have/had a trial). It, like CyberLink, seem to handle a wider range of source files, than does PrE, or PrPro.
    My security system also did some funny stuff with the AVI files. I forget the details now, but there were several conversions involved to get that stuff into PrPro, when I needed to work with them. I hope to replace the unit soon, and will try to get a more edit-friendly output with the new unit. You don't need it often, but when you do, having to jump thru four flaming hoops, is not fun, especially when the police want the footage quickly!
    Good luck, and to satisfy my curiosity, please update this thread with what you do, and what you do it in.
    Apr 19, 2011 9:07 AM   in reply to Ed.Macke
    Ed,
    I have never used VLC Player to convert, so cannot comment on how well/poorly, it might perform the task.
    As for the trials, I have zero experience in them. I cannot remember the last time that I downloaded a trial of anything, but it was years ago.
    Sorry that I cannot help more here,
    More good luck,
    Apr 19, 2011 9:35 AM   in reply to Ed.Macke
    VLC can convert files:
    You could also look at the VLC wiki: http://wiki.videolan.org/VLC_HowTo
    Cheers,
    Neale
    Apr 20, 2011 3:27 AM   in reply to Ed.Macke
    Weird. I also note that the WMV -> AVI is now an NTSC file. I'll be interested to hear about the final rendered result as 720x576 -> 352x240 -> 720x480 will be doing a fair amount of re-rendering (original down rez. to WMV and then an up rez. to AVI).
    Regardless if it works for you and you're satisfied with the results that's what's most important.
    Cheers,
    Neale
    Sep 4, 2011 2:08 PM   in reply to Ed.Macke
    Downloading from my Lorex Eco, I found either recording straight to the computer through the network or transferring the files over either through the network or on USB, I come up with either .avi files (direct record) or .264 files. Lorex's utility converts the .264 files to their .avi, as you have seen, but the ones recroded direct to the computer are also their format/codec (even in D1 at 29 or 30fps). My favorite utility, though slightly clunky, for reconverting these to .mpg (MPEG-II) files - which PrPro is fine with - is AnyVideoConverter, a freebie you can Google but I get either directly from them or another reliable download service. It has dealt with a lot of weird files I've never seen before. Just make sure you give it some kind of audio so Premiere can recognize it.
    A note: I tried converting it to another .avi file with this utility and all PrPro saw was a (rather flat!) audio file. Are you capturing with audio or just video? (It's nice to sync the audio and video but nearly impossible using seperate audio from the DVR because of time-code differences.)
    I think I may be doing some similar type of work to you. I don't know if you can PM me on these forums but if so, please do.
    -Steve
