Installing TCS3 Errors
Apr 21, 2011 7:54 AM
I'm installing the TCS3 Upgrade and am getting errors when trying to install Acrobat X. The install stops with an Exit Code 6 error stating we don't have the 64 bit versions installed, then the Acrobat Payload failure. Any suggestions as to how we can get past this?
Will
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 4 error(s), 7 warning(s)
WARNING: The payload: Adobe Photoshop CS5 Core  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} requires a UI parent with following specification:
Family: Photoshop
ProductName: Adobe Photoshop CS5 Core_x64
This parent relationship is not satisfied, because this payload is not present in this session.
WARNING: The payload with AdobeCode:  {8E355243-1A34-4EE8-A743-C166E68CF5C0} has recommended dependency on:
WARNING:  Family: Adobe Web Suite CS5
WARNING:  ProductName: Adobe Media Encoder CS5 X64
WARNING:  MinVersion: 0.0.0.0
WARNING:  This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
WARNING:  Removing this payload from the dependency list.
ERROR: Error 2753.The File 'trialencoder.dll.70DBED24_B579_40CB_AB0B_F1221A3E9EC5' is not marked for installation.
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 2753.The File 'trialencoder.dll.70DBED24_B579_40CB_AB0B_F1221A3E9EC5' is not marked for installation.
ERROR: The following payload errors were found during install:
ERROR:  - Acrobat Professional: Install failed
    Apr 26, 2011 11:18 PM   in reply to Wkugelman
    how do you install TCS3 Upgrade? From DVD or thru a build as an Enterprise Deployment?
    However, if Acrobat X Pro or older is installed the setup (or msi) cannot install Acrobat X Pro.
    Please deinstall older Acrobat at first.
    - Maike
