Remove Spider Web
Apr 26, 2011 1:50 PM
I have an AVI file converted from 8mm film showing an aircraft landing on a runway and offloading passengers.  There is a spider web visible on the top left corner of the frame.  So far, I have not been able to determine the most convenient way to replace the spider web with the background.  The problems I face are as follows:
- the background is visible through the thin, lacey web
- the web is fixed while the background moves
- initially, the web sits on a moving background of sky and tops of a heavily treed area
- when offloading passengers, the web sits on parts of the fixed aircraft
It may be possible to replace the top corner of the frame with the top corner of following frames.  However, the moving background is not fixed vertically.
As I am new to rotoscoping and replacing forground images with backgrounds when editing video, how should I proceed without wasting time on frame by frame editing, training and looking in the wrong direction?
    Apr 26, 2011 2:39 PM   in reply to John Ratard
    Can you send your project for open?
    thanks.
    Cristian
    Motion Graphics Argentina
    Apr 26, 2011 4:03 PM   in reply to John Ratard
    You could give multiple instances of CC Simple Wire Removal a shot.  I don't hold out a lot of hope for it, though.
    Apr 26, 2011 8:15 PM   in reply to John Ratard
    you can try rapidshare.com , megaupload.com, they are sites for uploading and share big files!
    Cristian
    Bijouterie por Mayor
    Apr 26, 2011 10:40 PM   in reply to Dave LaRonde
    This is where a screen shot would really help. There are several options including tracking, cloning, masking, background replacement. There's just not quite enough info in your description to give me any idea of which approach to suggest. A screen shot or even 10 frames of the video at half size would do.
    Apr 27, 2011 2:13 AM   in reply to John Ratard
    Just post a screenshot or two here in the forum. There's no need to send or attach an entire movie file.
    Apr 27, 2011 2:07 PM   in reply to John Ratard
    Oh, that's quite bad. Depending on motion in the shot, you may be able to use the Clone Stamp tool with a temporal offset to clone in pixels from preceding or subsequent frames.
    But, were I in your situation, I might try to take a more drastic approach: The spider web is already doing about a quarter of the job of a vignette for you. I'd go the rest of the way, and create a strong vignette, blurring and darkening the corners of the image to focus attention on the center, where the action is. If you've got a heavy vignette, at least it will look like a deliberate choice.
    Apr 27, 2011 3:19 PM   in reply to Todd_Kopriva
    I think the same, just trying to make a vignette as a good solution.
    the face behind the spider you´ll never make it visible.
    Cristian
    www.6pixel.tv
