Action Script Error # 2099 when flash context menu is opened in fullscreen
Apr 26, 2011 9:53 PM
I have created a MJPG/MJPEG component by using multiple image components. This component is working fine as far motion jpeg stream is concerned but when flex application is in fullscreen and user tries to open the flash context menu error 2099 occurs. This error is shown in the image below.
How can i stop this error?
I am using
Flex Framework 3.5.1
Flash Runtime   10.2.152.32
My MJPG Component is shown below
<mx:Canvas
  xmlns:mx="http://www.adobe.com/2006/mxml"
  initialize="onInit(event)"
  creationComplete="onCreation(event)"
  width="640" height="480"
  backgroundAlpha="0"
  resize="resizeImages(event)"
<mx:Script><![CDATA[
  import mx.core.UIComponentCachePolicy;
  import mx.collections.ArrayCollection;
  import mx.logging.Log;
  import mx.logging.ILogger;
  import mx.controls.Image;
  private static var log:ILogger = Log.getLogger(MJPG);
  private var maxImages:uint = 4;
  private var imgBuf:ArrayCollection = new ArrayCollection();
  private var idleQue:ArrayCollection = new ArrayCollection();
  private var _playing:Boolean = false;
  private var _actualSize:Boolean = false;
  private var imgWidth:uint = 0;
  private var imgHeight:uint = 0;
  // Statistics Variables
  private var sTime:Number = 0;
  private var decTime:uint = 0;
  private var _fRecCount:uint = 0;
  private var _fDecCount:uint = 0;
  private var _fps:Number = 0.0;
  private function onInit(e:Event):void
    for (var i:uint = 0; i < maxImages; i++)
      var loader:Image = new Image();
      loader.id = "loader" + i;
      loader.name = "loader" + i;
      loader.setStyle("horizontalAlign", "center");
      loader.setStyle("verticalAlign", "middle");
      loader.setStyle("horizontalCenter", 0);
      loader.setStyle("verticalCenter", 0);
      loader.width = width;
      loader.height = height;
      loader.cacheAsBitmap = false;
      loader.autoLoad = false;
      loader.cachePolicy = UIComponentCachePolicy.OFF;
      loader.data = {loading:false, loadTime:0.0, inQue:false, frame:0}
      loader.addEventListener(Event.COMPLETE, onLoadComplete);
      this.addChild(loader);
  private function onCreation(e:Event):void
    log.info("Using {0} Loaders", maxImages);
  private function resizeImages(e:Event):void
    var arr:Array = getChildren();
    for each(var loader:Image in arr)
      loader.width = (actualSize && width > imgWidth) ? imgWidth : width;
      loader.height = (actualSize && height > imgHeight) ? imgHeight : height;
  [Bindable(event='framesDecChanged')]
  public function get framesDecoded():uint { return _fDecCount; }
  private function updateDecFrames(v:uint):void
    _fDecCount = v;
    dispatchEvent(new Event(framesDecChanged));
  [Bindable(event='playingChanged')]
  public function get playing():Boolean { return _playing; }
  private function updatePlaying(v:Boolean):void
    _playing = v;
    dispatchEvent(new Event(playingChanged));
  [Bindable(event='fpsChanged')]
  public function get fps():Number { return _fps; }
  private function updateFps(v:Number):void
    _fps = v;
    dispatchEvent(new Event(fpsChanged));
  private function loadImage(loader:Image, obj:Object):void
    loader.data.loading = true;
    loader.data.inQue = false;
    loader.data.loadTime = new Date().getTime();
    loader.data.frame = obj.frame;
    loader.source = obj.data as ByteArray;
    loader.load();
    //log.debug(Frame: {0}, Loader: {1}, Size    : {2}, Time: {3}, obj.frame,
    //  loader.name, obj.data.length, loader.data.loadTime);
    obj = null;
  public function load(image:ByteArray):void
    if(imgBuf.length >= maxImages+3)
      var obj:Object = imgBuf.removeItemAt(0);
      log.warn(Frame: {0}, Dropped, TotalDropped: {1}, obj.frame, _fRecCount-framesDecoded);
      obj = null;
    _fRecCount++;
    imgBuf.addItem({frame:_fRecCount, data:image});
    //log.debug(Frame: {0}, Size: {1}, _fRecCount, image.length);
    if(!playing)
      log.info(Starting Stream);
      sTime = new Date().getTime();
      decTime = 0;
      _fRecCount = 1;
      updateDecFrames(0);
      updatePlaying(true);
      var loader:Image = null;
      for each(loader in arr)
        loader.data.inQue = true;
        idleQue.addItem(loader);
    if(idleQue.length > 0)
      loader = idleQue.removeItemAt(0) as Image;
      //log.debug(Using {0} From Idle Que, Length: {1}., loader.name, idleQue.length);
      loadImage(loader, imgBuf.removeItemAt(0));
  private function onLoadComplete(event:Event):void
    if(!playing) return;
    var loader:Image = event.currentTarget as Image;
    var bitmap:Bitmap = loader.content as Bitmap;
    if (bitmap != null) bitmap.smoothing = true;
    loader.data.loading = false;
    if(imgWidth == 0)
      imgWidth = loader.contentWidth;
      imgHeight = loader.contentHeight;
      resizeImages(null);
    var curTime:Number = new Date().getTime();
    decTime += curTime - loader.data.loadTime;
    //var avgDecTime:Number = decTime / framesDecoded;
    //log.debug(Frame: {0}, Loader: {1}, DecTime : {2}, AvgDecTime: {3}, loader.data.frame,
    //  loader.name, curTime - loader.data.loadTime, avgDecTime.toFixed(2));
    if(arr[arr.length-1].data.loadTime > loader.data.loadTime)
      log.warn(Frame decoded out of sequence, {0}, {1},
        arr[arr.length-1].data.frame, loader.data.frame);
    else
      removeChild(loader);
      addChild(loader);
      updateDecFrames(framesDecoded+1);
      updateFps((framesDecoded * 1000) / (curTime - sTime));
    arr = getChildren();
    for (var i:uint = 0; i < arr.length-1; i++)
      loader = arr[i] as Image;
      //log.debug("{0}, Loading  : {1}, inQue : {2}", loader.name, obj.loading, obj.inQue);
      if(loader.data.inQue == true || loader.data.loading) continue;
      if(imgBuf.length == 0)
        //log.debug("Sending {0} to Idle Que, Length: {1}.", loader.name, idleQue.length);
      else
  public function reset():void
    updatePlaying(false);
    idleQue.removeAll();
    imgWidth = 0;
    imgHeight = 0;
      loader.source = null;
      if(loader.data.loading)
      loader.data.loadTime = 0.0;
    while(imgBuf.length != 0)
      _fRecCount--;
      log.info("Frame: {0} removed frome the image buffer.", obj.frame);
      obj = null;
    updateFps((framesDecoded * 1000) / (new Date().getTime() - sTime));
    var recvFps:Number = (_fRecCount * 1000) / (new Date().getTime() - sTime);
    log.info("Resetting, AvgRendered : {0}fps, AvgReceived: {1}fps, FramesDropped: {2}",
      fps.toFixed(2), recvFps.toFixed(2), _fRecCount - framesDecoded);
  public function getCurrImage():ByteArray
    var loader:Image = arr[arr.length-1] as Image;
    if(loader.source is ByteArray)
      return loader.source as ByteArray;
    return new ByteArray();
  [Bindable]
  public function get actualSize():Boolean { return _actualSize; }
  public function set actualSize(v:Boolean):void
    _actualSize = v;
    resizeImages(null);
]]></mx:Script>
</mx:Canvas>
Publish Settings are
<noscript>
     <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
          id="${application}" width="${width}" height="${height}"
          codebase="http://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab">
          <param name="movie" value="${swf}.swf" />
          <param name="quality" value="high" />
          <param name="bgcolor" value="${bgcolor}" />
          <param name="allowScriptAccess" value="sameDomain" />
          <param name="allowFullScreen" value="true" />
    <param name="menu" value="false" />
    <param name="wmode" value="opaque" />
          <embed src="${swf}.swf" quality="high" bgcolor="${bgcolor}"
               width="${width}" height="${height}" name="${application}" align="middle"
               play="true"
               loop="false"
               quality="high"
               allowScriptAccess="sameDomain"
               allowFullScreen="true"
               menu="false"
               wmode="opaque"
               type="application/x-shockwave-flash"
               pluginspage="http://www.adobe.com/go/getflashplayer">
          </embed>
     </object>
</noscript>
Note : Before adding menu and wmode parameters in publish settings this error was occuring without fullscreen.
