I have two tables:
Ads
Articles
I've created a way to link specific ads to specific articles so that relevant ads are shown to whoever is reading an article. However, I think my method is going to require a lot of upkeep. I thought about entering keywords for the ads and articles, but I wanted it to be more specific so the results were more relevant.
How would you go about it?
I would design a normalized database for this information.
The data is very efficiently laid out. I'm not sure I see how normalizing it would help.
Don't you just need a link table to implement a many-to-many relationship between those two tables?
Adam
Correct. The problem I'm having with the entire thing is that when a new ad comes in, you have to go back through every old article to link the relevant articles to that ad. I'm not sure there's a way around that though, unless I go back to using keywords instead.
If you did go back and link old articles to new ads, what criteria would you use?
Good question. The criteria right now is my estimation of how relevant I believe the ad is to any given article. Ads for pool builders naturally link to articles about re-doing your backyard, for instance. Using keywords to link those types of ads/editorials that clearly have something in common would be a simple and organic process, but when you have advertisers like lawyers or photographers, it's likely that they'll never get any eyeballs unless they're manually linked to an article.
