Cannot import MPEG-2 files into AME.
Error message reads "Error while decompressing the source file"
Other formats seem to work OK
Thanks for responding.
Running W7Pro/64 Bit/ SP1
Intel I5/760
I've tried MPEG2 files from various sources, but most were rendered with
Sony Vegas 10 Pro. at NTSC DV 720x480, 29.97fps, .9091 pixel aspect ratio.
It seems as though the software is performing as a trial version, which
precludes importing any MPEG files. This is new software, but it is properly
licensed.
I appreciate any feedback you might have, and will gladly provide any other
info you may need to help me.
Thanks again
RJS
In stall this codec pack:
http://www.codecguide.com/download_k-lite_codec_pack_full.htm
We really need to know
1. Which version of AME you have.
2. With which application bundle AME was installed
The codecs you get depends on what parent application installed AME or is on your system.
If you have AME because you purchased and installed Flash, you get less supported formats compared to if AME was installed via Premiere Pro or one of the Production Premium suite.
> I feel a bit let down by Adobe on this. Nowhere in any promo, help
file, tutorial, or third party manual, is this mentioned. Some might call it
deceptive.
from "File formats supproted for export":
"Adobe Media Encoder is used both as a standalone application and as a component of Adobe Premiere Pro, After Effects, Flash Professional, Soundbooth, and Encore. The formats that Adobe Media Encoder can export depend on which of these applications are installed. The version of Adobe Media Encoder that is installed with Flash Professional can export to Flash video formats. To export to other video formats, you need the version that comes with the Production Premium or Master Collection edition, or with After Effects or Premiere Pro."
You're right that there isn't a similar note in the Help document for importing. That was an oversight. There's now a comment on that page of the Help document that makes this more clear.
Hi
I'm having the same problem - using a trial version of Media Encoder 5.5 on Win 7 Professional 64bit.
I tried renaming the extension to AVI like Alec Baldwin suggested, and - Media Encoder FINALLY added the file to the queue.
I then configured my encoding options but the encoding failed with the following error:
So that doesn't work either.
Supefan, I also installed k-lite codec pack for 64 bit and it doesn't work.
Todd_Kopriva - do you have any suggestion as to how we might fix this ?
You can't fake out AME that way.
Changing a file extension from AVI to MPG or vice versa might work to get past the quick check for file type support to add it to the queue but as soon as it goes to render or preview it's gonna crash. <...snip... technical reasons ...snip...>
If you want MPEG support (or AVC for that matter) you need to be licensed for it.
1: The trial doesn't have that license
2: The Flash bundle doesn't either.
So you have to purchase Premiere Pro or Professional Bundle.
You 're trying to do something you're not licensed for.
Even if you DO manage to hack the importing or exporting to work with codec packs you'll be in license violation of the patent holders if you render to MPEG or AVC so your video will be illegal (in the law sense vs the standards complying sense)
Hmmm...
your file looks fine.
tibineagu are you on a non-trial version now? As I stated above it won't work for the Trial version.
btw, installing a codec to decode mpeg2 won't help. Adobe uses an internal decoder that wins the vote as to who gets to do the work. So even if you have an mpeg2 decoder codec installed it won't win.
This is a matter of royalties. Adobe pays a royalty for every installation that supports MPEG2 (as well as formats that use other codecs). So management for each point product that installs AME decides whether to include the full set of formats or only a limited set of non-royalty bearing codecs.
If you have one of products that installs only the limited set, then there's currently no way to add codecs--short of buying a product or suite with the full set (Premiere Pro, After Effects, Production Premium, and Master Collection). I'll submit a feature request to provide a way for customers with the limited format set to purchase the royalty-bearing codecs.
This is bug of AME. I capture sample by eMPIA USB 2.0 Video Devices EM28xx.
Sample file: https://docs.google.com/open?id=0B2clLm5uvDqTWHdxclRWU29HODA
I have Flash CS5.5. (I can convert other mpeg to flv. Not license problem.)
Vista x64
North America
Asia Pacific
