Hello!
Im still new at this but would appreciate some help with this.
I have created a Flash banner with Actionscript 3.
Within the banner I would like to make an animated button that when clicked will open
another swf file within a pop up window with specified dimensions.
I have found java codes that work with Actionscript 2,
and also with Flash player 5 and lower.
But my banner uses effects that require me to export the clip no lower than Flash player 10.
Can I still create a pop up window with specific dimensions?
Thank you very much in advance for your help!!!
Kindest regards,
Coz
First, thank you for your help!
Actually, the plan is..
The header is an SWF.. within this clip I made a button..
When clicking on this button, a separate window must open with containing an swf file that is much bigger than the header.
For this separate swf file, I have already embedded it within an HTML page. But I want this HTML page to open with the dimensions
900 x 800 exactly.
I hope I explained this well enough.. Any ideas?
Hi there, Thank you also for your help! I think you basically said the same as the other answer. But I dont think I have enough background
to understand completely what was said..
What I do understand is I can use an Externalinterface.call() command (first time I heard of that) to call a javascript function to open that external html
file containing the swf. Is this correct?
I think I will need to use AS3 because it will need to be exported in no less than flashplayer 10.
I have found some java codes on line that might work to open the external html, like this one...
var jscommand:String = "window.open('http://www.adobe.com','win','height=200,width=300,toolbar=no,scrollbars=yes');"; var url:URLRequest = new URLRequest("javascript:" + jscommand + " void(0);"); navigateToURL(url, "_self");
though I am not sure if it is good.
And when I am done with all the coding, I can just add it with the actionscript tab?
Hi relaxatraja,
I just tried using your code. I like that you gave me that. Im sure I did NOT use it well. I got an error in flash that reads...
(1100: syntax error XML does not have matching begin or end tags.)
So I think I forgot alot..
May I attach this code to the button using the actionscript tab?
(really new at this)..
Open your html version that you used to embed your flash:
Add this script within the head tag:
<SCRIPT LANGUAGE=JavaScript>
function openNewWindow(URLtoOpen, windowName, windowFeatures) {
newWindow=window.open(URLtoOpen, windowName, windowFeatures);
</SCRIPT>
Open flash and write the below code for the button:
test.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler);
function fl_MouseClickHandler(event:MouseEvent):void
var url:URLRequest = new URLRequest("javascript:openNewWindow('http://www.macromedia.com','thewin','height=400,width=400,toolbar=no,s crollbars=yes')");
navigateToURL(url,"_self");
Tested it! works!
Flash code
m1.addEventListener("click", openNew);
function openNew(e:Event) {
ExternalInterface.call("openWin");
Javascript code
<script language="javascript">
function openWin(){
window.open('popup.htm','Popup','width=1004,height=657,scrollbars=no, resizable=no,status=no');
</script>
Just copy and paste this
Ok did it..
I took first code, and placed it within the html page with my swf file in it. (between the head tags) .. just copied and pasted.
then I took the second code, copied it and pasted it within the flash button.
What I got was this error...
1120: Access of undefined property test.
did I forget something?
Im doing my best. whew.. not easy! ![]()
I think you mean in place of (test) I have to replace that with the name of the instance of the button itself right?
So this is what I have now...
manual_btn.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler);
The header I made is called (Header_actionscript3_extrabtn). There is an animated button in this header that when clicked will open a pop up
window with an on-line users manual. That users manual is the swf file that is embedded in the html file which is called (OnlineManual-test.html).
The actual button to click has an instance name of (manual_btn) for manula button.
- so I put this new code with the instance name like you said in the button.
I still get an error 1120: access of undefined property manual_btn.
I am sure the buttons instance name is manual_btn.
Im lost...
any ideas?
Hello fellow brother!
thank you for your time and for being cool about this. Yes, the movie clip that I am using as a button is tweened.
So I made sure to include all of it from the beginning to the end.
When I use your code:
function openWin(){
</script>
---------------------------and I change the instance name of the button to 'm1', thats good right?
this code is now the action for the movieclip.
when I click on it, I receive this error:
1084: syntax error: expecting right brace before semicolon.
Any ideas?
(thanks in advance..)
Coz
Dear
This code needs to be in your fla
And this is not the part of fla below code needs to be in which you swf is embeded
function openWin(){
</script>
popup.htm is the html page you want to open on click
And I think relaxatraja example code should also work (i didnt test that) just give the instance name to the button on start and end frame of tween
Im lucky you are there! Thanks!
Ok, let me see if I understand ok?
This code:
------------------------ will be the action of the movieclip to be clicked...
And the movieclip to be clicked has an instance name m1 .. is that good?
this code:
function openWin(){
</script>
-------------------------------- goes with the other swf file that is embedded in the html page I made.
So I need to name the html page (popup.htm).
and place this code between the head tags?
Is this all correct?
first one is right
but second one is not
this code
function openWin(){
</script>
needs to in your html page head tag . HTML Page which holds the swf file having button to click to open popup.
U can giv me your mail id so that i can send u running sample. if its still not working.
popup.html and the embeded swf in popup html does not contain any of my code.
Hi there,
Ok, I tried it,.. made an html to hold the swf with the button.
I put the java code between the head tags.
Made sure all files are in the same location..
nothing happens..
Here is my mail address
I would love to view your example files so I can duplicate it exactly and hopefully
finally I can get this to work!!!
I will be waiting ok?
Thank you very much!!
Coz
If it possible send your files to the following id:relaxatraja@aol.com
Please send your files to the id even with flash cs5 format, so that we can sort it out easily : relaxatraja@aol.com
Hi ,
I got the file, and opened the maln html file. nothing happened,. checked it on another mac and still nothing.
I will go test it on a PC now.. do you think it is not working on macs? I am sure I dont have pop up blockers active.
I really dont know what the problem is. I believe you that it works with you.
I will go see if it works on PC... ok?
I sent you the mail, hope this is your id coz@familycards.nl
Hey, Anil!
Great! Finally u got it. Thats very pleasuring. Sorry dear dont have any idea about that component but I will try to search if I found let u know.
No I dint lost on you I was not in ofc coz of health reason. I came in today and just check your post and asked you about the situation.
COZ Programming is about keep digging. Deep you can dig far u can go.
North America
Asia Pacific
