PDF opens in AI with text changed to gibberish
May 5, 2011 4:49 PM
I'm trying to import some labelled pie charts I made, in Excel 2011, into AI CS5. I want to edit the art and text in Illustrator (vectors, natch). The pies and lines come in just fine, but the text is garbled.
If I do any of the following, the text from Excel comes in as garbled, scrambled gibberish:
  • Copy a chart in Excel, then paste into AI
  • Save Excel Spreadsheet as PDF, then Place it in AI
  • Save Excel Spreadsheet as PDF, then drag & drop it into AI
  • Print just a selected "Print Area" in Excel to PDF, then Place it in AI
  • Print just a selected "Print Area" in Excel to PDF, then drag & drop it into AI
Have you ever solved this problem, or a similar one?
Do you have any ideas that might help me?
    May 5, 2011 4:58 PM   in reply to mapsnmad
    Change the font used in the Excel chart to something else on your  machine. Right-click on the chart and select Format Chart Area. Go to  the Font atb (at the bottom) and change it from Calibri (Theme Body) [Or  whaterver it says] to something like Arial. Then recopy and paste the  chart.
