How can I merge even and odd pages of a PDF?
May 9, 2011 6:01 AM
I've got a document scanner that only scans one side
This is a problem when I have 2 sided documents
Let's say I have 20 pages - all double sided
I can scan all odd pages first in one go - I get one pdf generated pages 1, 3, 5, 7, 9, 11, 13, 15, 17, 19
Then I can scan all even pages 2, 4, 6, 8, 10, 12, 14, 16, 18, 20
Is there any quick way I can merge both pdfs to give me 1, 2, 3, 4, 5, 6, 7, 8, 9, 10... 20?
Thanks a lot
Micro
    May 9, 2011 6:33 AM   in reply to microsd-210
    I've created a tool that does just that. Have a look here:
    http://try67.blogspot.com/2008/12/acrobat-combine-even-odd-pages.html
    May 9, 2011 7:50 AM   in reply to microsd-210
    In the scan dialog of Acrobat you can specify double sided scanning.
    May 12, 2011 4:40 AM   in reply to microsd-210
    i just think adobe are silly not to provide it as standard??
    You can scan double sided pages with Adobe Acrobat.
    Jul 11, 2011 2:32 AM   in reply to microsd-210
    Exit Acrobat, and put the following in a file in your Javascripts path somewhere, e.g. C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Javascripts\CollatePages.js
    // Complements: Planet PDF (http://www.planetpdf.com/)
    // Modified by Jeff Baitis for Acrobat 9 compatibility
    // Improved Collate function with status bar.
    // Add a menu item to reverse all pages in the active document
    app.addMenuItem({  cName: "Reverse", cParent: "Document", cExec: "trustedReversePages();",  cEnable: "event.rc = (event.target != null);", nPos: 0 });
    app.addMenuItem({  cName: "Collate", cParent: "Document", cExec: "trustedCollatePages();",  cEnable: "event.rc = (event.target != null);", nPos: 0 });
    trustedReversePages = app.trustedFunction(function()
      app.beginPriv(); // Explicitly raise privileges
      var t = app.thermometer;
      t.duration = this.numPages;
      t.begin();
      for (i = this.numPages - 1; i >= 0; i--)
        t.value = (i-this.numPages)*-1;
        this.movePage(i);
        t.text = 'Moving page ' + (i + 1);
      t.end();
      app.endPriv();
    // Collating pages
      Title: Collate Document
      Purpose: User is prompted to select document to insert/collate.
      Author: Sean Stewart, ARTS PDF, www.artspdf.com
    trustedCollatePages = app.trustedFunction(function()
      // create an array to use as the rect parameter in the browse for field
      var arRect = new Array();
      arRect[0] = 0;
      arRect[1] = 0;
      arRect[2] = 0;
      arRect[3] = 0;
      // create a non-visible form field to use as a browse for field
      var f = this.addField("txtFilename", "text", this.numPages - 1, arRect);
      f.delay = true;
      f.fileSelect = true;
      f.delay = false;
      // user prompted to select file to collate the open document with
      app.alert("Select the PDF file to merge with")
      // open the browse for dialog
      f.browseForFileToSubmit();
      var evenDocPath = f.value;
      var q = this.numPages;
      t.duration = q;
      t.begin();
      // insert pages from selected document into open document
      for (var i = 0; i < q; i++) {
          var j = i*2;
          this.insertPages(j, evenDocPath, i);
          t.value = i;
          t.text = 'Inserting page ' + (i+1);
      t.end();
      // remove unused field
      this.removeField("txtFilename");
      app.endPriv();
    For those looking to apply this script in Adobe Acrobat X. Replace two instances of "Document" with "Edit". They are in the top lines that start with app.addMenuItem.
    Aug 30, 2011 9:27 AM   in reply to jbaitis
    I have a similar problem, except I cannot scan my doc.  I had to create it for book printing in MSWord with image/watermark.  I am under deadline and working on less than ideal software. What I have is -- Odd and even pages = different image background w/text flowing over them.
    It looks like my options are either pay $50 for the script --and although I agree with previous post that someone should be paid for their script, 50 bucks is a bit much, don't you think? My opinions aside, I can't afford it.
    or Learn scripting. The instructions above kindly provided are gibberish to me. The software files on this pc are locked anyway.
    or break up one of them and insert the 20 pages, one at a time.
    Are these really all the options?
    M.Maher
    Aug 30, 2011 10:06 AM   in reply to Miranda M
    Collating PDFs using JavaScript by Sean Stewart.
    You will still need to run the script through the Acrobat JS console.
    This assumes you  have a full version of Acrobat and not just Reader.
    Sep 29, 2011 10:48 AM   in reply to jbaitis
    Here is the latest version of this script, compabible with Acrobat X. The functions have been moved into the "Edit" menu because there is no tools menu in Acrobat X. It still maintains compatibility with Acrobat 9. Unfortunately, you'll have to manually copy and paste this into a file because Adobe has disabled the file attachment feature on Jive Forums .
    // Modified by Jeff Baitis for Acrobat 9 and Acrobat X compatibility
    app.addMenuItem({  cName: "Reverse", cParent: "Edit", cExec: "trustedReversePages();",  cEnable: "event.rc = (event.target != null);", nPos: 0 });
    // Add a menu item to collate with another document on the filesystem
    app.addMenuItem({  cName: "Collate", cParent: "Edit", cExec: "trustedCollatePages();",  cEnable: "event.rc = (event.target != null);", nPos: 0 });
      t.begin();
        this.movePage(i);
      t.end();
      app.endPriv();
    // Collating pages
      arRect[0] = 0;
      arRect[1] = 0;
      arRect[2] = 0;
      arRect[3] = 0;
      f.delay = true;
      f.delay = false;
      t.duration = q;
      t.begin();
          var j = i*2;
          t.value = i;
      t.end();
      app.endPriv();
    Nov 16, 2011 9:52 AM   in reply to jbaitis
    Thank you so much.  I love this solution on my PC.  Does it also work with Adobe on the Mac?  If so, how?
