aarongabbard
Premiere cs5 will not open PRPROJ!
May 9, 2011 5:35 PM
Ok I don't know what happen I use to have cs3 but I deleted it and since then my new cs5 won't open up my session files when I double click... For example I right click and select open with, I browse into the adobe scroll down and select adobe premiere pro from the cs5 folder and it does nothing, it wont even link the open with up, If I open cs5 from the start menu and look for my file to open it will open but as far as double clicking the session i want to open on the desktop it wont do it. Someone help me out here another thing i just ened up doing on accedent is now my computer wants to open the folder session file using Photoshop cs5 uhhg this is getting frustrating!
  • joe bloe premiere
    Dec 6, 2009
    May 9, 2011 5:46 PM   in reply to aarongabbard
    I'd re-install CS3 and make sure the project isn't corrputed.
    But first, I would back up everything.
    Good information about drive image backups can be found here:
    http://forums.adobe.com/message/3664060#3664060
  • joe bloe premiere
    Dec 6, 2009
    May 9, 2011 6:00 PM   in reply to aarongabbard
    You could try:
    Deactivate
    Uninstall CS
    Clean Script (at least twice, three is better)
    Reinstall
  • joe bloe premiere
    Dec 6, 2009
    May 9, 2011 6:06 PM   in reply to aarongabbard
    You could try:
    Launch Premiere
    Navigate to your project
    Open
  • joe bloe premiere
    Dec 6, 2009
    May 9, 2011 6:15 PM   in reply to aarongabbard
    That's a Windows "File Association" problem.
    You need to fix that in the OS.
  • joe bloe premiere
    Dec 6, 2009
    May 9, 2011 6:26 PM   in reply to aarongabbard
    Right-click your project file
    Select: Open with > Choose default program...
    Browse to:
    C:\Program Files\Adobe\Adobe Premiere Pro CS5\Adobe Premiere Pro.exe
    Check:
    Always use the selected program to open this type of file.
    Click ok.
    May 9, 2011 9:12 PM   in reply to aarongabbard
    Why not just choose the PRPROJ file from PrPro? That is not a lot of steps, should the file association fail.
    May 9, 2011 9:48 PM   in reply to Bill Hunt
    +1 Absolutely agree.
    Especially when all current projects are right in your face when PPRO loads up
  • joe bloe premiere
    Dec 6, 2009
    May 10, 2011 4:39 AM   in reply to shooternz
    Ours is not to reason why, Ours is but to answer; try.
    May 10, 2011 8:17 AM   in reply to aarongabbard
    I bet that you'll only have to open that project from within Premiere once. Then if you save it, we'll be able to open it directly next time.
    One of the issues with legacy projects is the need for CS5 to convert them.
    Aug 7, 2011 11:29 AM   in reply to aarongabbard
    Glad that you got it sorted out.
    Many programs will seize file type associations for themselves, so one must be very careful, when installing them. Going back some version, Apple's QT Player used to do this, upon install. It would associate itself with almost any media file type, even if it could not Open those file types. It has gotten better lately, as it allows the user to limit which files it would associate to itself. Others are not so good, and still grab every possible file type for themselves, regardless of what the user had chosen, or what earlier programs had done.
    Always look behind any program install, to make sure that the file type associations have not been changed.
