ddsbleton 30 posts
Oct 26, 2010
Show applicable markers by selecting body text?
May 11, 2011 1:37 PM
Hi folks,
The Markers Pod allows you to view markers in a number of ways, and show their position within the text's body when selected via the pod.  But there seems to be no way to do the opposite - select a marker within the body, and have it be highlighted in the pod.
Am I missing something fundamental here?  Isn't this a much more common real-world need?
Thanks.
    May 11, 2011 1:48 PM   in reply to ddsbleton
    Not quite following you - you've got your Text Symbols turned on, right? So you can see where the marker is located (in my case I even set a colour & size character style to make them more noticeable & distinguish between them) & when you select it, the marker pod shows what's in the marker text. Am I missing something?
    May 11, 2011 1:55 PM   in reply to ddsbleton
    What version of FM are you using? I'm on 10 and it seems to be working fine for me. I can post a screenshot if it would help.
    May 11, 2011 2:27 PM   in reply to ddsbleton
    Ok, here's an example of one of my documents - it's a heading that has 3 different marker types associated with different spots in the text. Each of them is colour coded so that I can tell which one is which:
    I've got the Marker Pod open, and have selected one of the markers in the text.
    I hope it shows up well enough to see.
    May 12, 2011 6:50 AM   in reply to ddsbleton
    So are you still having an issue? If so, maybe posting a screenshot of what you're seeing would me understand what you're looking for?
