I encountered some unexpected behavior for theaccess modifiers I cannot explain; maybe someone can help me out:
There are two classes:
"Player" und "Table" - both inherit from the same class and are located in the same package in the same directory.
"Player" wants to call function "deletePlayer" in "Table" but this seems to only work when I have the access modifier set to "protected" - if the function "deletePlayer" is public I receive an error:
Player.as, Line 34 1118: Implicit coercion of a value with static type modules.room:Player to a possibly unrelated type Player.
Why does public not work?
public class Player extends UIObject
private var table : Table;
public function Player()
public override function init($table : MovieClip) : void
table = Table($table);
public function deletePlayer() : void
table.deltePlayer(this); // This calls the function in Table
delete this;
package modules.room
import flash.display.MovieClip;
import flash.events.MouseEvent;
import modules.room.Room;
import modules.room.Player;
import modules.UIObject;
public class Table extends UIObject
private var players : Array = new Array();
private var timer : Timer;
private var room : Room;
public function Table()
public override function init($room : MovieClip) : void
trace("init Table" + $room);
room = Room($room);
initBtnCreateTable();
private function initBtnCreateTable() : void
btnCreatePlayer.addEventListener(MouseEvent.CLICK, createPlayer);
public function createPlayer($event : MouseEvent) : Player
trace("creating player");
var player : Player = Player(addChild(new Player()));
players.push(player);
player.name = "Player" + players[players.length - 1];
player.init(this);
return player;
public function deltePlayer($player : Player) : void // This will throw an error until I set access modifier to protected
for (var i : int = 0; i < players.length; i++)
if (players[i] == $player)
players.splice(i, 1);
trace(players);
If you are using Flash IDE, search in Library for symbols that has defined Class property as "Player" or "Table" and change to something different, for example "_Player" and "_Table". Setting deletePlayer() to protected may cause RTE.
Perfect!
Many thanks
