dontripi
Web Root Flash Builder 4.5 mobile + PHP
May 20, 2011 9:12 AM
hello everyone, i just want to know how to add the address of the web root when i do a flex mobile project, when i work locally in my server i put C:\xampp\htdocs, but when when i work remotelly how can i put this address.
for example if mi server is 200.100.1.12, and my root URL is http://200.100.1.12, how can i write de web root for this server, please help me, i dont know if i have to configure something else in the server or what i need to do, pleas any answer will be welcome.
    May 24, 2011 7:34 PM   in reply to dontripi
    I've been searching everywhere for the answer to this myself.  I'm hosted on Register.com, with awesome PHP / MYSQL hosting that I pay for, and I can't access it through Flash Builder CS 4.5.  Someone help us confused developers?
  • Chriszzzzzzzzzzzz
    Jul 7, 2011
    Jul 7, 2011 7:00 AM   in reply to Log Home
    This problem has been going on for years, with hundereds of threads and still no one has come up with a solution. HEEEEEEELLLLLLLLLPPPPPPP!!!!!
    I have done everything asked of me ands still 'The selected web root folder does not exist.'
    Jul 7, 2011 7:21 AM   in reply to Chriszzzzzzzzzzzz
    yeah, its not the easiest thing to work out. Took me a while
    when you connect to a service FB generates 2 classes, the service and a super class. You need to override the class, not the super (the super class gets regenerated so any changes will be lost)
    for instance I have a service called HypService, so in services.hypservices.HypService.as I repoint the endpoint, like this
    protected override function preInitializeService():void
            super.preInitializeService();
            // Initialization customization goes here
            this._serviceControl.endpoint = "http://www.hyperiums.co.uk/services/gateway.php";
    next you will have to change the amf_config.ini file that FB generates, set the web root and amf.directories (and maybe the path to zend framework depending where it is)
    hope that helps
  • Chriszzzzzzzzzzzz
    Jul 7, 2011
    Jul 7, 2011 9:18 AM   in reply to kokorito
    Thanks for the reply. I have updated my Service.as like the example. The  amf_config.ini is fully updated and the Service.php but still no luck, it wont recognise the web root.
    Any other suggestions would be welcome
    Jul 7, 2011 9:31 AM   in reply to Chriszzzzzzzzzzzz
    try pointing the browser at your gateway.php file
    if its configured properly then you should get <p>Zend Amf Endpoint</p>
    the web root isnt just the url, you will need to get what the root actually is from the server provider or should show you on cpanel
    Jul 7, 2011 9:45 AM   in reply to kokorito
    here is my ini file
    [zend]
    webroot =/home/hyp/public_html
    [zendamf]
    amf.production = false
    amf.directories[]=services
    note there is also a path to the zendframework, but I dont need it as its in the web root anyway
    zend_path =/home/hyp/public_html/ZendFramework/library
    it depends on where you have installed your framework if you need to set it
  • Chriszzzzzzzzzzzz
    Jul 7, 2011
    Jul 7, 2011 10:05 AM   in reply to kokorito
    Yes i get Zend Amf Endpoint from gateway.php in browser.
    I am using the full web root from the service provider.
    so it looks like ths
    Web root: ...fullwebroot.../apps/
    Root URL: http://....co.uk/
    reply - The selected web root folder does not exist.
    Jul 7, 2011 10:27 AM   in reply to Chriszzzzzzzzzzzz
    thats a bit cryptic
    what do you mean by fullwebroot? Its NOT the url, its the path that the server directs the url to
    and why do you have /apps at the end, thats not the root
    if apps is where you have your classes then you set that in the amf.directories[] = apps
  • Chriszzzzzzzzzzzz
    Jul 7, 2011
    Jul 7, 2011 10:44 AM   in reply to kokorito
    Yes im not using the url but the path i recieved from service provider. I have removed /apps (was subdirectory for project)
    [zendamf]
    amf.directories[] = apps/services
    which contains only the service.php file
    [zend]
    webroot ="full path  (webroot) not url"
    still no luck
    Jul 7, 2011 10:47 AM   in reply to Chriszzzzzzzzzzzz
    I really can't connect to PHP / MYSQL in FB 4.5.
    Everything works perfect in Dreamweaver for years now.
    I think Adobe would much rather you buy a ColdFusion license.  CF gave me lots of problems too, especially with the new CF Builder, where plugins didn't work for me, like CFC Generator, on Mac OS X.  Generally disappointed in FB and CF Builder because none of the fun stuff that's supposed to make it easy works for me.
    Jul 7, 2011 11:01 AM   in reply to Log Home
    FB works fine with php
    in fact Adobe funded Zend in including amf in the framework
    you just need to know how your server is configured, and you can hardly blame Adobe for that
  • Chriszzzzzzzzzzzz
    Jul 7, 2011
    Jul 8, 2011 8:32 AM   in reply to kokorito
    Finally got it working on my test device. Follow all the steps above listed by kokorito. I left the web root as the development server and changed the root url to the hosted server, then it let me press ok without validating. It now runs on my test device. Still having problems loading images even though i changed the image urls, but its a step in the right direction. Thanks again kokorito
    Jul 20, 2011 2:09 PM   in reply to dontripi
    Even though I spent a lot time, still my flex app on a mobile device cannot access to db on the remote server.
    I made changes on the following files. Can you point out what was wrong? Thanks
    .flexProperties file:
    serverRoot="/var/www/vhosts/mydomain.com/httpdocs/public" serverRootURL="http://mydomain.com"
    Web host's document root is /var/www/vhosts/mydomain.com/httpdocs/public
    MyService.as file:
              this._serviceControl.endpoint = "http://mydomain.com/gateway.php";
    MyService.php
    class MyService
        public $username = "root";
        public $password = "pwd_2";
        public $server = "xx.xx.xxx.xx";
        public $port = "3306";
        public $databasename = "testdrive_db";
        public $tablename = "mydb";
    amf_config.ini
    webroot = "/var/www/vhosts/mobilemenu.info/httpdocs/public"
    zend_path ="/usr/local/php/ZendFramework-1.11.4-minimal/library"
    library ="/var/www/vhosts/mydomain.com/httpdocs/library"
    services ="/var/www/vhosts/mydomain.com/httpdocs/services"
    [zendamf]
    gateway.php
    <?php
    ini_set("display_errors", 1);
    $dir = dirname(__FILE__);
    $webroot = $_SERVER['DOCUMENT_ROOT'];
    //Web Hosting Document Root: /var/www/vhosts/mydomain.com/httpdocs/public
    $zenddir = '/usr/local/php/ZendFramework-1.11.4-minimal/library';
    Jul 20, 2011 5:56 PM   in reply to davidflex
    you only need to change the amf_config.ini file
    just set the web root and the zend path
    the amf.directories[] is the folder that contains MyService.php, relative to the root
    I dont think you need services or library roots in the ini file. Just path to the zend library, path to the root, and then path from the root to the service class the gateway connects to.(amf.directories)
    You shouldnt need to mess with the generated gateway.php and I dont know what the .flexProperties file is,
    well thats what works for me. But I use FB standard and a seperate install of Eclipse for PHP. Maybe FB with PHP genaerates slightly different files
    /me shrugs
  • Chriszzzzzzzzzzzz
    Jul 7, 2011
    Jul 21, 2011 3:04 AM   in reply to davidflex
    Try pointing the webroot to your local harddrive in server settings;
    For example in project properties / flex server.
    Web root: C:\Users\Chris\Adobe Flash Builder 4.5
    Root URL: http://mydomain.co.uk/
    Myservice.php public server should point to sql
      public $server = "mydomain.co.uk.mysql";
    amf_config.ini
    Zend path should point to the ZendFramework/library directory on the remote server. if you leave ZendFramework/library at the root you wont have to put anything to do with zend.
    leave webroot as
    Jul 22, 2011 8:43 AM   in reply to Chriszzzzzzzzzzzz
    Finally, I made it working. Thank you kokorito, Chriszzzzzzzzzzzz for your help.
    As Kokorito suggested, I don't have to/ shouldn't modify the gateway.php.
    In amf_config.ini,
    for webroot, I used the document root (or server root) provided by my web hosting company.
    ;webroot = "C:/Program Files/Zend/Apache2/htdocs"
    webroot = "/var/www/vhosts/mydomain.com/httpdocs/public"
    For zend path, I specified the path of zend library located in my web hosting server:
    Gateway.php reads amf_config.ini and use zend_path, library and services defined here to make new paths:
    For amf directories, I used a full path such as:
    amf.directories[]=/var/www/vhosts/mydomain.com/httpdocs/services
    Finally, for the mysql server, I used localhost which my web hosting server points to, since gateway.php is runing on the server.
    public $server = "localhost";
    A different web hosting may use a different address.
    .flexProperties is a config file in Flash Builder 4.5 for PHP. I set such as
    Aug 9, 2011 5:38 AM   in reply to davidflex
    Happy to see that everybody has resolved their problems.
    Myself being still in front of this wall, I have a question with respect to the database itself.
    When I have created my database access in FB the first time with tye help of the Data Service wizards, I was of course on a localhost on my machine.
    The moment I want to run off a remote server, I did create the database there with the help of exported SQL files.
    Now, I still have to tell the application that my database has changed, possible user/passwords are different.
    When you guys were discussing your problems, it always turned around the gataway.php. amf.ini and the service class/Superclass files.
    But I think I need to customise my xxxService.as with mySQL database details of the production server.
    Is this correct?
    Or, can somebody explain me better the workflow of an application build on FlexBuilder, where I suppose to develop first the local version and then export it to the production server thru export release Build and some file tweaking as above
    many thanks
    Peter
    Aug 9, 2011 6:03 AM   in reply to roestigraben
    I'm afraid I've never used the wizards so dont know how or what they do
    but you will have to duplicate the local server on the remote server including the database.
    The username/password will be different on the remote server, you'll need to change that. Presumably you have them in order to import the sql files.
    Easiest way I find to do that is have a php file or class containing database connection details. Import (require) this file in your scripts. You can set the local password for testing locally and the remote password on the remote server. That way the script imports the correct details depending on where its run from.
    wont help with the database password but I made a video that might explain the original question
    http://www.youtube.com/watch?v=P333JuiX-V8
  • Chriszzzzzzzzzzzz
    Jul 7, 2011
    Aug 9, 2011 6:33 AM   in reply to roestigraben
    once you have changed server settings, amf_config.ini and other files as described above, your new database settings should be modified in the Service.php file in your services folder on remote server.
    it should read something like
    class MyService {
      var $username = "mydomain_co";
      var $password = "8hjg56hjsoi???...";
      var $server = "mydomain.co.uk.mysql";
      var $port = "3306";
      var $databasename = "mydomain_co";
      var $connection;
      public function __construct() {
        $this->connection = mysqli_connect(
                           $this->server,
                           $this->username,
                           $this->password,
                           $this->databasename,
                           $this->port
        $this->throwExceptionOnError($this->connection);
    Mar 30, 2013 3:33 PM   in reply to Chriszzzzzzzzzzzz
    Hi
    I need your help ..I followed your steps but still have errors.
    when I try to connect the app by flash builder i get this message :
    java.io.IOException: Server returned HTTP response code: 500 for URL: http://rjcsm.com/TestMySQL/gateway.php
    my app folder is under " TestMySQL" so i set the amf.directories[]=TestMySQL
    and the ZendFramework is installed as well on the server and i didn't change anything in gataway.php file
    so what's the problem ?
    My amf_config.ini file is like this :
    [zend]
    ;set the absolute location path of webroot directory, example:
    ;Windows: C:\apache\www
    ;MAC/UNIX: /user/apache/www
    webroot =/public_html
    ;set the absolute location path of zend installation directory, example:
    ;Windows: C:\apache\PHPFrameworks\ZendFramework\library
    MAC/UNIX: /user/apache/PHPFrameworks/ZendFramework/library
    zend_path =public_html/ZendFramework/library
    [zendamf]
    Mar 30, 2013 3:39 PM   in reply to kokorito
    Hi
    [zend]
    [zendamf]
