Hi All, i would like to seek expert helps on Adobe Reader save location issues. After we upgrade from Adobe Reader 9 to Adobe Reader X.
There are changes on how save location works in Adobe Reader X
If save PDF via Internet Explorer – the save location will according to last save location, HOWEVER
If save PDF via Adobe Reader X – the save location will set according to location the file is being open
Let me show you what i mean over the pictures
I open a reader_X_help.pdf using Adobe Reader X and then save the file using Ctrl+Shift+S at: C:\Users\xxxx\Documents\My last location save
Now i want to save another new file back to C:\Users\xxxx\Documents\My last location save, I open the file Adobe file2.pdf located at desktop and when i do Ctrl+Shift+S, the location point to my desktop and not C:\Users\xxxx\Documents\My last location save
I have tested this features in Adobe Reader 9 and it's different whereby it's will point according to my last location save.
There is no issue with computer as i have 3 machine running different enviroment, Windows XP SP3, Windows 7 Enterprise, and all using same version of Adobe Reader X version 10.0.1.
So my questions & concern:
Is there any way to change the save location features same as Adobe Reader 9?
If YES, how to do it? By Computer Changes or Adobe Reader X packages modification using Adobe Customization tools?
If NO, Where can i find this source of documentation stated about this new changes so i can publish this information in HP website as new design changes to avoid complaint or negative feedback.
Looking forward for expert reply as soon.
Thank you very much and Have a great day.
Best Regards
Edmund Lau
[email address removed by host]
Solved it!
1-go to "edit", select Preferences.
2-select from the left pane: Security (enhanced)
3-click on "add folder path" button just below the big white box
4-pick a folder of your choice and click "ok". (your selected folder path will appear in that white box above the "add folder path" button in step 3)
5-if you want to add additional folders, just repeat steps 3 & 4
6-once you are done, click "ok" on the preferences screen and click "ok" again to accept the changes.
Yes, it seems illogical, but it worked.
I tested by closing the Reader (X), then surfed the web and did what Neher5 was explaining he/she wanted to do just after opening a pdf from a website and lo-and-behold, it worked!. No more "save to temp folder" issues.
Hope this helps.
North America
Asia Pacific
