Media Encoder Stops Encoding with the New CS5.5
May 24, 2011 9:57 AM
  Latest reply: dspinell, Feb 1, 2013 12:29 AM
Replies 1 ... 3 4 5 6 7 Previous Next
    Dec 11, 2011 9:22 PM   in reply to Louis_fre
    Louis_fre wrote:
    Just to refresh my facts again:
    AME works fine in a CS 5 environment.
    It freezes randomly in a CS 5.5 environment with no errors, just simply stops working.
    My system specs:
    Windows 7,  64 bit, SP1, with the latest updates and drivers
    16GB RAM
    CPU: i7-2600K @ 3.4 GHZ, running overclocked @ 4.4 GHZ  with special heatsink
    (the symptoms happen without overclocking as well)
    GPU: Gigabyte made Nvidia GeForce GTX 580
    1 x 2TB HDD partitioned into 2 x 1 TB
    2 x 2 TB on RAID1
    Greetings;
    Running almost identical system with Z68 Pro Motherboard,  accept for EVGA GTX570 card on mine.
    I don't believe this is a graphics card issue as you have gigabyte, I have EVGA and we both have the problem.
    Was having same issues. CS5 AME works fine, First install of CS55 caused stalled rendering without warning.
    I uninstalled and since reinstalled.  Now CS55  AME kinks as soon as it starts from a Premiere sequence export and brings up white box/red border warning O/S doesn't like what AME is trying to do and asking if I want to go to Graphics card driver home page. Click Yes/No AME shuts down.
    My present problem appears to be in the software handshaking between AME and Premiere Pro right when AME starts up with Premiere sequence. 32 bit vs 64 bit , Administrator rights? I don't know and it's beyond my scope. Hopefully Adobe techs can work this out.
    Until they do I'll continue with CS5. The GPU acceleration speeds things up and I'd hate to have to turn it off.
    I've joined the Improvement program  and during the Xmas break will file a bug report. Somewhere down the road this issue needs fixing.
    Regards
    JD
    P67 Z68 Pro
    16 GB Corsair Ram
    GTX 570
    Windows 7 Home Premium
    Adobe Production CS5 CS5.5
    Dec 11, 2011 11:18 PM   in reply to J Dell
    Thanks for the input JD,
    I also do not think that my GTX-580 brand is the problem, our specs are very similar, except I am running windows 7 ultimate 64bit and my RAM is Kingston.
    I can't believe that this problem is already 7 months old and not solved!
    Dec 12, 2011 4:35 AM   in reply to Pedaling Duo Productions
    GPZ Productions wrote:
    I ended up having to encode my sequences with After Effects.  That seemed to work.  I am going to wipe everything and do a new install of the operating system and the programs.  I do not know what precipitated this problem.  I did not have this trouble in the past.
    I finally got around to wiping the OS and installing EVERYTHING fresh.  That worked.  I am able to encode with AME sucessfully once again.  I have no idea why it had stopped working.  I did not change any hardware or drivers.
    Dec 12, 2011 6:43 AM   in reply to Pedaling Duo Productions
    I tried the path of reinstalling from scratch too, no change for me!
    Dec 12, 2011 7:14 AM   in reply to J Dell
    JD, I guess verify you have the most current driver for your EVGA card. Here's a screen cap of mine from mine in the device manager. I guess also you're stating that it happens as soon as AME starts to render a Premiere sequence. I think a lot of other people in this thread were saying it would happen a few minutes into the render, so it could be that yours is a different problem.
    GPZ, I think with reinstalling everything, it's the type of thing that can change a lot of variable without you knowing it. When you reinstall an OS and software you can get a lot of different drivers and updates without even knowing it, including from Windows, Nvidia, and Adobe. Also sometimes some 3rd party software and drivers can effect things sometimes. I know I had some Red Giant trial encoders one time that were messing up some things like audio.
    I think in this thread we've talked about all the possible hardware and driver issues, but we haven't really talked about our nested dynamic links set ups or output settings.
    For me before I updated the GTX 570 driver which (fixed) my same problem, I was rendering sequences from premeire with 2 avchd clips and a few image and title layers, and outputting as the H.264 Blu-ray with a preset where I just set the rate to a dialed down CBR. I would like to note again my problem was happending after after queuing up any number of these from 2-30 in AME, and after rendering around 4-10 timelines worth of videos, it would stop with no indication or error message. So basically if I had 3 or more clips that were 2 minutes each, it might get through all of those and lock up on the 3rd. Or if I had one video first in the queue that was 7 minutes long, it might lock up on it 80% of the way through with just that sequence.
    Here's a few screen caps of my drivers, layers, and export settings. Ignore the fact my source media on my screen cap is missing for one layer. That's just cause I moved the project to an archive drive after I was done with it a couple months ago and I didn't bother to map up the file path right to make the screen cap. Also notice my layers are set up with an mpeg and an mts avchd file (two different cameras), I'm guessing that shouldn't matter, but it just shows its probably not a media type issue. layers.jpgrendersc.jpg
    Dec 12, 2011 2:40 PM   in reply to Pedaling Duo Productions
    Sent from DisKreet Digital iPhone
    Dec 12, 2011 4:07 PM   in reply to Paul_Duffey
    In my case, with CS4.0.2, AME was working just fine.  In the middle of editing a wedding project something happened, if I could pinpoint it I would, and then AME would crash as described here.  All of the drivers were updated when I re-loaded everything but it had worked just fine for six months prior to this re-load.(It is a new build done in May).  I suspect I had either downloaded some software that was desagreeable, but I had uninstalled several recent downloaded programs and the problem remained, or AME glitched when I was trying to render a sequence with a dynamic link to a complicated AE project.  After this attempted, and failed, rendering is when all of the headaches began.
    Who's to say that there is not more than one issue that triggers this malfunction.
    Dec 13, 2011 3:17 PM   in reply to Pedaling Duo Productions
    Update:
    I updated my BIOS on my gigabyte mainboard model: P67A-UD7-B3, now I have rendered correctly 3 projects via AME using MPE enabled, and NO FREEZES!
    Maybe it's to early to get excited, but this seems to have fixed the problem.
    I had updated the BIOS back in August and it had no effect, this latest version seems to work.
    Dec 13, 2011 9:31 PM   in reply to Louis_fre
    2 more projects rendered correctly today as well, I am begining to believe that the bios update has ironed out this problem.
    Dec 14, 2011 5:49 AM   in reply to Louis_fre
    Yeah I had to update my Gigabyte UD5 board with a bios update too when I upgraded my processor to the 6 core i7 970 around 8 months ago. But I had the problem after I did that until I updated my video cards driver around 3 months ago. Anyway, looks like a driver/bios update issue now. That's two systems counting yours and mine that were fixed with just that.
    Dec 14, 2011 1:59 PM   in reply to Paul_Duffey
    If updating graphics or BIOS drivers resolves a problem for any of you, that's fantastic. We're certainly glad to hear it. That said, there's little if any doubt that we have a bug in the PPRO/AME code base that's causing the hang that some of you are seeing. Our main CUDA/GPU developer has identified some problems and is working on fixing them. This is really complicated code, so he has to proceed very carefully to not only yield a solid fix for the problems he found but also to avoid introducing new issues.
    As GPZ Productions and others noted, the various people who have posted on this thread are likely dealing with different bugs that all manifest the same general symptom: encoding hangs. In fact, strike the "likely"--I know of at least three distinct issues:
    1. an occasional random hang encoding with GPU acceleration enabled in PPRO, which started in CS5.5. This represents the majority of those active on this thread.
    2. a hang in CS4.We don't have enough information on this one to characterize it more precisely.
    3. a regular hang that apparently resulted from RAM usage getting maxed out.
    It's also entirely possible that the following could factor in for some of you:
    • particulars about the source: if AME hangs at about the same place every time with a given sequence, then a likely culprit is an asset or effect, or combination of assets or effects, near the point of the hang. For instance, I recently documented a hang that resulted from a combination of an opacity effect set to Dissolve and a 3D motion effect on the same clip. Encoding hung several seconds beyond that point in the sequence, with the exact frame where it hung varying by more than a second.
    • Heat. If the position of the hang is random, and if shutting off the computer for several minutes results in successful encodes, then the CPU or some other component may be overheating.
    • Your particular CUDA card--either the make & model, or a defect in the card. For example, we have been able to reproduce a hang on one test system with a particular CUDA card, but when we run exactly the same test on the same system with a different graphics card installed: no hang. We do not yet have enough evidence to determine whether the first card is defective or if the issue is endemic to that make/model.
    Regardless of what exactly is causing AME to hang for each of you, we regret the great inconvenience to you. While we may not have been as involved in this thread as we should have been, I assure you we have been following the thread closely and, more importantly, we have spent considerable time investigating--in particular trying to reproduce the issue internally. Since we finally isolated a repro case several weeks ago, the main developer in this area finally has some leads to follow. Fixing this bug--specifically the GPU issue introduced in CS5.5--is a high priority for him. When he has a fix, we may contact some of you to give it a workout and see if it resolves your hang.
    Dec 14, 2011 3:42 PM   in reply to Mark Mapes
    Thanks Mark for the detailed reply,
    I have rendered more items since yesterday, still working ok!
    However, you are right about the bug, I know of other colleagues that still have the exact same problem (an occasional random hang encoding with GPU acceleration enabled in PPRO, which started in CS5.5)
    I hope we have a solution soon.
    Dec 14, 2011 4:18 PM   in reply to Mark Mapes
    In CS 4, I spent a lot of time trying to determine if the hang up occured at the same time in a sequence while encoding. I can tell you that it did not.  I did see a dependency on the length of the sequence.  If I cut the sequence to around two minutes it would make it through.  So I suspected heat.  I monitored the CPU and Motherboard temperatures during encoding and they were well within safe margins.  I examened the time line in minute detail and could see nothing wrong.
    I really think my problem developed when trying to render a sequence with a dynamic link to an AE comp in the sequence.  Regardless, wiping the system drive and re-install the OS, along with updating the BIOS and some drivers, fixed the problem.  In my case AME worked flawlessly since May when I first built this Intel I7 system.  It only malfunctioned, and stayed messed up, in the middle of this wedding project that I was doing.  Something triggered the malfunction and I found this thread while researching a cure for this issue.  It seems most of the people on this thread are using PPro5.5 though.
    I also experienced other glitches such as my still pictures in a sequence would turn black and/or the video would be interlaced with green screen during playback.  Rebooting almost always made this go away for a while, but the AME always crashed reboot or not.
    Thanks for chiming in on this.  I hope you guys are sucessfull in solving the issue.
    P.S.  When is CS6 coming out??
    Dec 14, 2011 5:51 PM   in reply to Pedaling Duo Productions
    @ GPZ: thanks for the additional info re: the hang you ran into w/ AME CS4.
    I'm afraid we're never at liberty to discuss release dates, new features that are coming, etc. Company policy. In fact, if you re-read my earlier post, you'll find that the two refs to the next version number have been expunged as that was dancing too close to the edge. Everybody please delete the earlier email with the original draft so that I don't get in trouble ;-)
    Dec 19, 2011 8:23 AM   in reply to Neverends Productions
    I'm new to Adobe CS5.5 and am facing a similar frustrating problem of sitting for days waiting for a short and simple 7 minute photo montage using after effects to render but it seems to hang at about 2/3 during the render. It does not specifically mentions that it hangs but the Elapsed time and Estimate remaining time hangs there. There is no way to save the painful last 2 days of rendering and I am forced to cancel and re-render again. Tried a few times but it seems only short renders (by short I mean less than 24 hours...) seem to have a higher chance of a successful render. Its like playing roulette with CS5.5 and you never know if you'll get a successful render after sitting at the pc for days and realising it hangs halfway yet again.
    My Specs are:
    GTX 560i (Have obtained latest driver updates)
    AMD phenom 1100 - 6cores
    No heat problem, sufficient power wattage
    16gb ram
    I'm just surprised a 7 minute photo montage with only 1 simple particle effect and some clouds effect could take days to render, but the render is never completed as it hangs halfway or 2/3 way. The much hyped mercury engine doesn't seem to work as fast as advertised- With Open GL enabled or disabled, my rendering speeds and ram preview speeds are horribly slow.
    Am i doing something wrong as a newbie or is there something seriously wrong with CS5.5's rendering programme? I just want to render out to a HDTV widescreen and I believe rendering a 7 minute photo montage shouldnt take days... Would appreciate any advice on which settings I should use to ensure good quality on screen without leaving the PC on for days trying to render a short 7 minute photo montage.
    Dec 19, 2011 9:26 AM   in reply to metta xu
    Hi Metta Xu,
    Sorry to hear you're having problems. You mention "using After Effects to render" (that's "AE") but make no specific reference to Adobe Media Encoder (AME), which is the topic of this thread. Please clarify which program is hanging.
    Regardless, I suggest trying three tests: render once with the particle effect removed, once with the cloud effects removed, and once with both effects out of the equation. This will determine if either effect, or the combination of them, is causing encoding to be so slow and to hang.
    Dec 19, 2011 1:59 PM   in reply to Louis_fre
    Greetings;
    Posted about a week ago on similar problems with Media Encoder stalling and in my case eventually not working at all.
    To update.
    I've got Premiere Pro and media encoder Production CS5.5 working now.
    My solution was to new install Windows 7 operating system (after serious crash), load and update all drivers and only install CS5.5 Production Premium (not CS5). The computer has been working well since. The only times it has failed is when encoding a slideshow with some oversize images. I was able to view media encoder viewer and determine which slide it had stalled on (4000 X 2500 image), after resizing 2000X1300  media encoder completed work on next pass. It would appear that AME gags on large files with transitions requiring GPU graphics acceleration.
    This episode shook my confidence in Adobe as previous CS versions have worked so well.
    However, those versions didn't have a GPU acceleration feature and another piece of hardware that Adobe CS5.5 has to play nice with.
    And now that I've noted the need for more uniform file sizes and planned workflow accordingly it appears the software/hardware works very well.
    Asus Z68 V Pro Motherboard
    i7 2600K CPU clock 3.4 ghz
    16 GB Corsair Ram
    GTX 570 video
    Lucid logic turned on / Intel Rapid Storage turned on
    Win 7 Home Premium on 120 GB SSD
    Render Export Drive/ Rapid Storage - 120 GB SSD
    2 - Western Digital 1TB Drives
    1 - Seagate 1TB Drive
    Adobe Production Premium CS5.5
    Cineform Neo
    Quicktime 7.7 something
    Pass this along as a success story on this issue, and  hope others have success with the "graphics acceleration" and get their systems working.
    Kindest Regards
    JD
    Dec 19, 2011 2:38 PM   in reply to J Dell
    All I can do is pass along my experience.  I have no fancy graphics cards.  All I know is if I export from PPro, it works everytime, so after MANY days of encoding issues with AME, I see no reason to continue
    to "test" for Adobe, I need to get work done.
    Dec 19, 2011 8:46 PM   in reply to Mark Mapes
    Sad to report here also, that after a week of bliss, and rendering a dozen items without problems, I'm back to the same problem again...(hang encoding with GPU acceleration enabled in PPRO, which started in CS5.5.)
    Disabling MPE works ok but it's so damn sloooowww.
    No software was added or removed during this period.
    HELP
    Dec 23, 2011 4:38 AM   in reply to Neverends Productions
    I too have a similar problem to those reported here.
    One hour 20 minute video comprising only two clips. Plays perfectly in PremierePro, and can export to tape back to camera.
    In PremierePro, export media, select settings, and select Queue. AME loads, click on start button, and encoding begins. Estimated time is around 8 minutes - after about 1 and a half minutes, encoding sudenly stops - no error messages, machine has not hung, task manager showing very low CPU usage. On attempting to exit AME, sometimes does so, sometimes gives "not responding" and have to crash out. Moved entire project to another hard drive in case drive is the problem. Tried encoding only the second half of the video (in case there is a fault in the source material in the first half) - behaviour is the same - hangs at between one/two minutes.
    Machine is Intel i7, Windows 7 Ultimate, 12Gb memory, OCX-Vertex2 Solid State drive for System and Apps, Western Digital Caviar Black 6Gbps drive for data, Seagate Barracuda 3Gbps drive for backup. NVidia GeForce 210 video card (so rendering using software only).
    Adobe Production Premium 5.5, all latest updates downloaded and applied.
    OS fully updated.
    I bought all new hardware and the latest version of Adobe production Suite to try and eliminate the problems I was having with my aging Premiere Pro 2 system - very frustarting that things are worse than before! At least with my creaky old system I was able to get video encoded out of it!
    Any suggestions on how tests to carry out most welcome!
    Dec 23, 2011 5:06 AM   in reply to stagesound
    Welcome to the faulty AME club!
    A temporary workaround as discissed in this thread is to disable MPE in Premiere pro, before you proceed with the render...
    Dec 23, 2011 6:14 AM   in reply to Louis_fre
    Thanks for the advice and welcome! - please excuse my lack of knowledge, but isn't MPE disabled by default on my setup, since my card doesn't support it?. If i go to Project > Project Settings > General, the option to select it is greyed out.
    Dec 23, 2011 6:26 AM   in reply to stagesound
    yes it is disabled, sorry I missed that part.
    For most of us in this thread, rendering works ok once MPE is disabled in PPRO 5.5 prior to rendering.
    Dec 23, 2011 11:05 AM   in reply to stagesound
    We are all waiting for months!
    Dec 23, 2011 11:40 AM   in reply to Louis_fre
    I firmly believe that something triggers this malfunction while editing.  As I had said my system was functioning just fine and the WHAM!  Re-installing the OS has cured it, for the time being.  I hope it does not return as it has for you.
    Again, I am using CS 4.0 and not 5.5 like the rest of you and I do not have the MPE function.
    Sorry to hear that you are back in the soup again.  I really hope Adobe does something about this but I am afraid that the code is too convoluted for them to figure it out.
    Dec 24, 2011 6:24 PM   in reply to Pedaling Duo Productions
    Thanks Paul,
    Like you, I never had problems with the other suites. It's only cs5.5 that has this particular problem.
    I like to use 5.5 because it handles AVCHD coded much better!
    Jan 23, 2012 1:54 PM   in reply to Neverends Productions
    I am having the same problem. I have updated my (nvidia) video drivers to the latest version, and also the computer bios (It's  Dell Precision workstation T3400), and it is  no help. I'm trying to use AME to encode about 30 SWF videos to H.264 mp4 files, using a queue in ME, and it reaches a certain point (it varies on each video) and hangs. I have only been able to successfully encode about 1/10 of the videos.
    How can I get a "downgrade" to the CS5 version so I can get some work done?  I used AE CS5.5 to create these comps. Can I encode those in CS5? If not, I need a downgrade to AE as well. I just purchased an upgrade to the master suite for this project as I had the web suite before?
    BTW, the same comps render perfectly, with no issues using the same settings as above in AE directly.
    Jan 23, 2012 2:52 PM   in reply to mjschiff
    I hate to disappoint you, my last post here was over a month ago and you are the next person to comment.
    I think adobe has abandoned this one!
    Jan 24, 2012 12:30 PM   in reply to Louis_fre
    Thanks, I noticed that. Seems that they would want to get this fixed. Even though there are only a few vocal ones here, I'm sure their support lines are swamped with them.
    -- Martin
    Jan 24, 2012 12:44 PM   in reply to mjschiff
    We have not abandoned you.  This thread represents couple of different bugs based on various reports.  The one that most people are reporting has to do with exporting out of PPro to AME and app hanging at some point (Cuda card in system).  Or just starting AME, loading PPro project and trying to encode (Cuda card in system).  This bug has the highest priority and is still open to be fixed.  And I bring this up almost weekly with our development team.
    Unfortunately this is also not a bug that can be fixed in AME.  So a patch to AME won't solve this issue from what I have been told by development team that’s working on this issue.  I have been working closely with Premiere Pro development team and they assure me that is one of their top bugs to resolve.
    Jan 24, 2012 1:05 PM   in reply to Nariman Sodeifi
    Perhaps I have posted this in the wrong place then. My problem is with loading After Effects projects directly into AME and having them never complete rendering, even though the program does not seem to be locked up. The same projects render fine if I render them in AE directly.  If you can direct me to a better place to post this, I will be happy to go there.
    -- Martin
    Jan 24, 2012 3:40 PM   in reply to mjschiff
    Well, it may not be the wrong post.  Do you have a Cuda card in your system.  If that answer is yes, this is likely the same issue.  Easy way to test this is by disabling cuda in AE and on the project.  Save the AE project (with cuda disabled), then bring it to AME. Do you still have this issue?  There are instructions on earlier posts on how to do this in PPro.  I'm not sure of the steps to disable cuda in AE and AE Project.
    Jan 24, 2012 5:23 PM   in reply to Nariman Sodeifi
    Martin - please start a new thread in the forum for the problem you're experiencing with AE. Thanks.
    AE doesn't use CUDA.  What you describe is different enough behavior from the problems other people described in this thread that we should troubleshoot it separately, and also give it better visibility as a new thread.
    Jan 30, 2012 10:28 AM   in reply to Nariman Sodeifi
    Thanks for your posting that we're not forgotten.  We often wonder when there's no reply for a while.
    I am suffering this same problem, AME freezing.  It does seem to have some specific triggers, but can also happen at random in some projects.
    t's amazing how much slower performance is without CUDA.  I'll be glad when it is all working right.  In the meantime...
    Are there differences in CUDA performance and stability in Adobe Media Encoder and Premiere Pro?  There's a big difference in supported board prices.  If I knew a $1,000 board would make my AME stable, I'd get one today.
    Thanks again for the help.
    Jan 31, 2012 2:20 PM   in reply to Neverends Productions
    I used to be able to reproduce this freezing bug pretty consistently but then I downloaded the latest driver for Quadro FX4800 and now I can't repro.
    Can somebody confirm that this bug is gone after the newest Quadro FX 4800 driver is installed? http://www.nvidia.com/object/quadro-tesla-win7-winvista-64bit-276.42-w hql-driver.html
    Feb 16, 2012 10:35 AM   in reply to Dima Tikhonov
    I have the same issue.  I don't know what CUDA is, so my guess is I don't have it.  Also, I am using an NVVIDIA GeForce GTX 285. .  . though I'm not sure how that can have anything to do it.
    Feb 16, 2012 11:00 AM   in reply to EckleySP
    GTX 285 is one of the CUDA video cards supported by Adobe.
    CUDA is a parallel computing architecture which significantly speeds up scaling and some effects transformations by doing some crazy parallel matrices computations.
    EckleySP, is there any chance I could get your Premiere project?
    Feb 16, 2012 11:17 AM   in reply to Dima Tikhonov
    The problem - mine anyway - is not A Premiere Pro Project.  It is many of them.  I have a number of projects that need to be rendered out - each will take in excess of 12-15 minutes or so, so I wanted to stack them up, or batch them in AME.   It usually gets through the first one or two, but then hangs up - usually in the beginning of a project.  It does not seem to matter what format I am rendering to, or the size - it just does not handle multiple 'batched' files.  In my case, each file consists of pretty much the same content.  They begin with a 30 second WMV file, followed by a nested sequence, followed by a simple title and another nested sequence.  In whole, the projects are about 18 to 25 minutes in length.  To get this work done, I have to render from Premiere Pro - so I sit here and watch it render - then I'll get the next one started. . .  and wait again.
    Feb 16, 2012 11:23 AM   in reply to EckleySP
    Yeah that's a real pain. If you do that over and over again like I do for a living then I'd strogly consider an EVGA GTX570. I was experiencing the same problem until I bought one of those and then downloaded the most current driver for it from the EVGA site (not the disc that it came with). With most video editors time is money so you don't want to be rendering while you watch, doing 8 hrs at night, or while your running errands is going to be way more convieniant.
    Feb 16, 2012 11:25 AM   in reply to EckleySP
    I can tell you I don't have the newest driver for the GTX 285.  I had major issues with a Boris Continummimmm  plug in in After Effects and was told to back of the current driver.  I don't think it helped, so I suppose I should get current.
Actions
Bookmarked By (2)
