Lior Bruder
How to 9scale a Flex group?
May 30, 2011 7:45 AM
Hi All,
I got a graphic element from flash catalyst (that is not scalable - done with path) and i want to use 9scale in order to scale it without touching the corners.
When i use this: _com.scale9Grid = new Rectangle(20,0,100,100); i get this error:
Error: ScaleGrid properties can not be set on this Group since at least one child element is a DisplayObject.
Is there an easy way to make 9scale on spark components?
    May 30, 2011 7:42 PM   in reply to Lior Bruder
    Scale grids are only supported on Group when there is no child DisplayObjects. This means that every element in the Group must be a GraphicElement and none of those elements can have properties set on them that require its own DisplayObject (like rotation).
    From the Group documentation:
    Note: The scale grid might not function correctly when there are DisplayObject children inside of the Group, such as a component or another Group. If the children are GraphicElement objects, and they all share the Group's DisplayObject, then the scale grid works properly.
    Setting any of the following properties on a GraphicElement child requires that GraphicElement to create its own DisplayObject, thus negating the scale grid properties on the Group.
      alpha
      blendMode other than BlendMode.NORMAL or "auto"
      colorTransform
      filters
      mask
      matrix
      rotation
      scaling
      3D properties
      bounds outside the extent of the Group
    So something like this should work:
    <s:Group scaleX="2" scaleY="2" scaleGridLeft="20" scaleGridTop="20" scaleGridBottom="80" scaleGridRight="80">
        <s:Rect width="20" height="20" x="0" y="0"><s:fill><s:SolidColor color="green" /></s:fill></s:Rect>
        <s:Rect width="20" height="20" x="0" y="80"><s:fill><s:SolidColor color="green" /></s:fill></s:Rect>
        <s:Rect width="20" height="20" x="80" y="0"><s:fill><s:SolidColor color="green" /></s:fill></s:Rect>
        <s:Rect width="20" height="20" x="80" y="80"><s:fill><s:SolidColor color="green" /></s:fill></s:Rect>
        <s:Rect x="20" y="20" width="60" height="60">
            <s:fill>
                <s:SolidColor color="blue" />
            </s:fill>
        </s:Rect>
    </s:Group>
    But this won't be supported since Button extends from DisplayObject:
        <s:Button label="Is DisplayObject" />
    </s:Group>
    And Group also extends from DisplayObject so this won't work either:
        <s:Group />
    </s:Group>
    This post might be useful for learning about the difference between children and elements.
