anonym0u5
Cannot submit web filing form using acroread version 9.4.2 02/11/2011
May 31, 2011 7:53 AM
Hello there.
I am running Fedora14 fully updated.
If I complete the interactive pdf form supplied by  Companies House in the United Kingdom I get the following error message.
SSL Error!!!. Please install the CA certificate(s) for SSL communication.
If certificate resides on local disk, try "acroread -installCertificate [-PEM|
-DER] [pathname]" on tyhe command line.
If certificate resides on the server, try "acroread -installCertificate ewf.companieshouse.gov.uk 443" on command line.
So checked I the firewall settings.
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     udp  --  anywhere             anywhere            udp dpt:domain
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:domain
ACCEPT     udp  --  anywhere             anywhere            udp dpt:bootps
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:bootps
ACCEPT     all  --  anywhere             anywhere            state RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:ssh
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:http
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:https
ACCEPT     udp  --  anywhere             anywhere            state NEW udp dpt:ipp
ACCEPT     udp  --  anywhere             224.0.0.251         state NEW udp dpt:mdns
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:ipp
ACCEPT     udp  --  anywhere             anywhere            state NEW udp dpts:6881:6889
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpts:6881:6889
ACCEPT     udp  --  anywhere             anywhere            state NEW udp dpt:56849
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:56849
ACCEPT     udp  --  anywhere             anywhere            state NEW udp dpt:snmp
REJECT     all  --  anywhere             anywhere            reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
ACCEPT     all  --  anywhere             192.168.122.0/24    state RELATED,ESTABLISHED
ACCEPT     all  --  192.168.122.0/24     anywhere
REJECT     all  --  anywhere             anywhere            reject-with icmp-port-unreachable
ACCEPT     all  --  anywhere             anywhere            PHYSDEV match --physdev-is-bridged
Chain OUTPUT (policy ACCEPT)
Which looks ok to me.
[user@k8 tv]$ acroread -installCertificate ewf.companieshouse.gov.uk 443
Fetching certificate from website....
depth=2 C = US, ST = UT, L = Salt Lake City, O = The USERTRUST Network, OU = http://www.usertrust.com, CN = UTN-USERFirst-Hardware
verify return:1
depth=1 C = IE, ST = Dublin, L = Dublin, O = Digi-Sign Limited, OU = Terms and Conditions of use: http://www.digi-sign.com/repository, CN = Digi-Sign CA Digi-SSL Xp
verify return:1
depth=0 C = GB, ST = Wales, L = Cardiff, O = Companies House, OU = Web Filing, OU = Provided by Digi-Sign Limited, OU = Digi-SSL Xp, CN = ewf.companieshouse.gov.uk
verify return:1
DONE
Processing ....
The website presented the following Certificate
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            07:a4:23:f4:cc:ef:4e:e9:d5:89:76:b4:ee:2f:4c:4b
        Signature Algorithm: sha1WithRSAEncryption
        Issuer: C=IE, ST=Dublin, L=Dublin, O=Digi-Sign Limited, OU=Terms and Conditions of use: http://www.digi-sign.com/reposi
tory, CN=Digi-Sign CA Digi-SSL Xp
        Validity
            Not Before: Jul 26 00:00:00 2009 GMT
            Not After : Jul 26 23:59:59 2011 GMT
        Subject: C=GB, ST=Wales, L=Cardiff, O=Companies House, OU=Web Filing, OU=Provided by Digi-Sign Limited, OU=Digi-SSL Xp,
CN=ewf.companieshouse.gov.uk
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (1024 bit)
                Modulus:
                    00:e8:68:c9:f7:4f:c5:98:18:5f:d6:34:d0:2a:3d:
                    53:f8:40:6f:4b:0a:ad:7b:d1:5c:99:85:8a:dd:19:
                    70:9d:9a:03:95:20:1d:a1:c3:9d:a9:cf:4f:10:97:
                    dc:5e:1e:c8:c0:d7:50:09:7c:e3:a5:df:48:3d:4e:
                    09:06:49:1b:ad:dc:b9:f4:42:35:ea:fd:14:e6:c9:
                    7d:2a:ef:1e:80:3f:26:cd:8e:2f:56:be:13:3c:3e:
                    f0:62:47:e2:ca:53:f8:8d:57:e7:5d:17:81:b6:1a:
                    f1:fd:1b:4a:e6:43:83:05:8a:02:92:a4:2d:57:07:
                    b8:f8:7c:8c:93:a1:09:ad:6f
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Authority Key Identifier:
                keyid:33:5A:0B:4E:35:DA:B8:8E:87:05:64:5F:D8:EC:7D:25:98:DA:BA:3F
            X509v3 Subject Key Identifier:
                24:CB:12:A4:AA:53:7E:96:83:80:ED:48:FB:D1:6D:CD:B8:3C:1B:BA
            X509v3 Key Usage: critical
                Digital Signature, Key Encipherment
            X509v3 Basic Constraints: critical
                CA:FALSE
            X509v3 Extended Key Usage:
                TLS Web Server Authentication, TLS Web Client Authentication
            X509v3 Certificate Policies:
                Policy: 1.3.6.1.4.1.6449.1.2.2.9
                  CPS: http://www.digi-sign.com/repository
            X509v3 CRL Distribution Points:
                Full Name:
                  URI:http://crl.digi-sign.com/DigiSignCADigiSSLXp.crl
                Full Name:
                  URI:http://crl2.digi-sign.com/DigiSignCADigiSSLXp.crl
            X509v3 Subject Alternative Name:
                DNS:ewf.companieshouse.gov.uk, DNS:www.ewf.companieshouse.gov.uk
        65:4d:83:e7:fa:42:f4:b2:fa:c9:bb:bb:68:56:63:39:f1:14:
        98:a8:cb:35:42:32:40:a8:4e:54:95:cd:c9:6c:31:f3:f8:74:
        00:df:80:4f:b5:61:65:06:7e:fc:a5:30:36:da:55:10:58:21:
        c6:82:ba:f0:11:42:37:5a:6e:82:16:29:be:09:d3:a6:b9:11:
        fb:f3:24:1a:ea:bb:73:ea:79:59:67:d7:bb:c8:48:51:bd:70:
        01:6e:f2:11:bd:b7:86:13:9a:e9:22:9e:3b:c1:a6:a0:78:fc:
        eb:e0:a7:2b:48:2c:26:b3:f9:f4:5b:bd:54:2f:56:83:1f:0a:
        ee:2f:50:40:7f:c7:1a:e9:07:da:cd:23:18:14:c8:46:f5:f4:
        c3:26:fa:af:12:8e:d8:ac:7a:b7:03:5c:8e:6e:23:9c:1b:ce:
        53:03:1a:8e:74:98:47:c9:c5:3a:fa:7f:d3:f6:ca:dd:a4:0b:
        50:02:40:64:cf:77:1d:72:3e:9b:4f:f9:c5:df:50:2e:90:a3:
        3d:76:62:d8:ef:99:6e:be:1a:b4:89:5e:93:89:fd:0e:f5:47:
        0b:2a:a6:08:c5:e5:6f:15:e9:82:42:ba:6a:0b:31:76:dc:d8:
        77:70:3f:0a:87:2b:b3:21:0d:4e:09:62:9f:53:14:11:b3:ec:
        0f:fb:4a:02
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Do you want to accept and install it (y|n)? [n] y
Certificate successfully installed.
Which looked ok to my inexperienced glance.
So I tried a resubmission.
I got the first error dialog again, followed by a second which said:
An error occurred during the submit process. Cannot process response due to unknown content type.
Can anybody here help me with this at all?
It would be a real boon to all of Britains UNIX users if anyone could suggest a way forward- as it would appear that the mandated web filing process
is preventing all UNIX and Linux users from filing their compulsory company returns online..
Thankyou.
    Dec 1, 2011 6:18 AM   in reply to anonym0u5
    The solution is shown at:
    http://www.olamalu.com/content/fixing-adobe-acrobat-ssl-linux
    First, save your CT600.pdf with Ctrl+S and close acroread. Go to https://ewf.companieshouse.gov.uk/ using Firefox, click on the padlock icon in the bottom right corner, click View Certificate, then the Details tab. In the Certificate Hierarchy box, click on each of the four certificate names and click Export. You should now have four certificate files (e.g. in your Downloads directory).
    Open a terminal, change to the Downloads directory or wherever you put the certificates, and import each certificate in turn (as your normal user, not root):
    $ cd ~/Downloads
    $ acroread -installCertificate -PEM AddTrustExternalCARoot
    $ acroread -installCertificate -PEM UTN-USERFirst-Hardware
    $ acroread -installCertificate -PEM Digi-SignCADigi-SSLXp
    $ acroread -installCertificate -PEM ewf.companieshouse.gov.uk
    Then re-open your CT600.pdf in acroread and click the Next button to re-submit your authentication code to Companies House.
    Thanks to Olamalu for the tip!
    Feb 15, 2012 8:13 AM   in reply to danielhjames
    I wish to reiterate anonym0u5 concerns for this problem, but it could be a problem with Companies House.
    I did
    acroread -installCertificate -PEM Digi-Sign\ CA\ Digi-SSL\ Xp
    acroread -installCertificate -PEM Builtin\ Object\ Token\:AddTrust\ External\ Root
    after having clicked the padlock at the top in Chrome and downloaded the certificates. Note the slight difference in file name.
    Screenshot at 2012-02-15 15:54:30.png
    then restarting acroread I get the above (again). So I stop it and do as it says:
    acroread -installCertificate xmlgw.companieshouse.gov.uk 443
    Unfortunately:
    The problem still persists. I have written to Companies House:
    Filling in my CT600 online and taking advantage of the ability to submit accounts to Companies House, I put in my company number and authentication code but then am presented by the following:
    so I save the file, close Acrobat and do as it says:
    nigel@p4dx2:~/Documents/accounts/nsl/certificates$ acroread -installCertificate xmlgw.companieshouse.gov.uk443
    which eventually returns
    Then I reopen the CT600 with Acrobat. But unfortunately the same thing happens. What digital certificate is needed? Where can I find it?
    I will let this forum know of any response.
