• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ffmpeg and php video conversion
Explorer ,
Jun 02, 2011 Jun 02, 2011
Hello
I have recently been trying to covert uploaded video into flv so that its playable on a flash player. I trying to use ffmpeg which is installed
on my hosting plan server.
I have been able to grab thumbnails using ffmpeg but now need to convert the video into flv. The code I have does a conversion but the
file is 0kb when its outputted to the Videos folder;
This is the code:
$src = "Videos/robot.avi";
$output = "Videos/robot.flv";
$ffmpegPath = "ffmpeg";
$flvtool2Path = "flvtool2";
$ffmpegObj = new ffmpeg_movie($src);
$srcWidth = makeMultipleTwo($ffmpegObj->getFrameWidth());
$srcHeight = makeMultipleTwo($ffmpegObj->getFrameHeight());
$srcFPS = $ffmpegObj->getFrameRate();
$srcAB = intval($ffmpegObj->getAudioBitRate()/1000);
$srcAR = $ffmpegObj->getAudioSampleRate();
exec($ffmpegPath . " -i " . $src . " -ar " . $srcAR . " -ab " . $srcAB . " -vcodec wmv1 -acodec adpcm_ima_wav -s " . $srcWidth . "x" . $srcHeight . " " . $output. " | " . $flvtool2Path . " -U stdin " . $output);
// Make multiples function
function makeMultipleTwo ($value)
$sType = gettype($value/2);
if($sType == "integer")
return $value;
} else {
return ($value-1);
I dont have flvtools but they are not nessary as they only collect meta data.
Thank you,
TOPICS
ActionScript
Views
203.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor ,
I've got a feeling that this topic may be a little out of place here.
Have you had a look at PHPMotion, a free, open source video upload/conversion/sharing script?
http://www.phpmotion.com/
You could download and take it apart to see how it works... it's free and won't cost you anything to at least look at it.
I use it on one of my sites for file conversion and it seems to work just fine.
Best wishes,
Adninjastrator
Votes
Translate
Translate
Report
Report
Explorer ,
Hello
Thanks alot for the reply. I have check out the phpmotion it seems really good but I really need to use ffmpeg. The reason is I have a hosting plan that has ffmpeg installed on the server which works well with my exsisting code. I have already used ffmpeg to grab thumbnail every time some one uploads a file but now I just need to convert uploaded files into flv. The code I uploaded does that but the converted file for some reason is 0 kb when inside folder.
Thanks.
Votes
Translate
Translate
Report
Report
Mentor ,
PHPMotion is ffmpeg based and is open source.
My suggestion was to download the source code and see how they use it for file conversion.
Best wishes,
Adninjastrator
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 03, 2011 Jun 03, 2011
Hi
Thank again for the reply. I am trying to download php motion to check it out. I have actually made an video conversion with the
code above but for some reason the coverted file is 0KB.
Votes
Translate
Translate
Report
Report
Mentor ,
OK, Good.
Another place to check for info is:
http://www.ffmpeg.org/
and there are a number of pretty smart folks over at:
http://forum.videohelp.com/forums/11-Video-Conversion
Best of luck!
Adninjastrator
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 07, 2011 Jun 07, 2011
LATEST
Hi
Thanks for the reply. I have registers with http://forum.videohelp.com/forums/11-Video-Conversion
and have been recieving some replies.I still have not solved the problem so any help is appreciated.
Votes
Translate
Translate
Report
Report
