Using RoboHelp 9 trial on Windows 7 x64.
The issue:
When displaying external web pages in an AIRHelp Application the page displays correctly for
about 2 seconds and then suddenly jumps to some different styles on some elements.
This makes some of the text change size and become justified full (instead of aligned left).
Obviously this makes the pages look broken.
Example Before (on page load it looks correct for about 2 seconds)
Example After (after about 2 seconds the style jumps to justified and a bit larger)
You can see in this example that it has affected both the heading and the body text
(which are now justified and larger).
I used the Application Help template for this test project.
The default CSS has not been changed much (just some left margin).
Found no "justified" in the default CSS file.
It happens on multiple completely different website links.
Does not happen on all websites.
Above example link for testing (http://blog.nooku.org)
Happens on both Favorites Links and TOC URL links. (just add to Favorites to test)
The page zoom in AIRHelp does not seem to be related to this.
What am I missing? ![]()
Have been using H&M for years and am testing RH9 because of the advanced AIRHelp
features such as the ability to seamlessly incorporate web pages and feeds etc.
Any guidence on this would be greatly appreciated.
Thanks!
I see the problem with that feed using the correct link http://feeds.nooku.org/blog but not with other RSS feeds or sites I have tried.
What other feeds do you see it in as you say you get it "When displaying external web pages in an AIRHelp Application" implying it happens with all links?
Thanks for taking a look at this.
The issue is not with the RSS feed(s).
The feed for that blog website seems to work fine in the Favorites RSS Feeds.
The issue is with the display of the websites within the AIRHelp application.
Links entered as ToC items, or Favorites Links, or followed from a Favorites RSS Feed - same issue each time.
It only happens with some websites (but most that I have checked).
So I am assuming that the AIRHelp Webkit browser is for some reason applying the styles.
It appears that the built-in browser is the issue.
I took a look at the source code of the various pages to see if I could spot something.
Because it does not affect all websites I am guessing that there is some common thread.
To make my first test AIRHelp project I decided to try to make a sort of Resource Guide.
This would include some topics, and quite a few extenal links (and some feeds).
I really like the idea of being able to put all this in one interface, sort of like the Adobe Help application.
This blog link shows the bigger and justified issue.
Same here
Assembla.com - appears only the body text gets bigger (but not justified)
Vimeo.com - appears to show no change (appears as original page does)
On this blog one H1 gets much larger and justified - the rest of the page seems to be unaffected
GNU.org - all text gets smaller
http://www.gnu.org/licenses/quick-guide-gplv3.html
It appears that perhaps there are some issues in the browser engine in AIRHelp.
The feature which most draws me to RH9 AIRHelp does not seem to be working correctly. ![]()
Any ideas or work-arounds would be appreciated.
Thanks again.
That is an interesting idea.
Although usually the website determines the browser or user agent from the request header
and so it knows almost immediately how it wants to serve that page to that user agent.
The 2-3 second pause before the page changes appearance does not seem to fit.
If it is a website-adapting-to-the-user-agent issue, that brings up a couple questions:
- What user agent does AIRHelp send in the page request?
- Can this user agent be configured (changed)?
I just tested with a website on my local host and it appears fine.
No jumping or changing styles.
Guess I can check the local website logs to see the user agent sent by AIRHelp.
Since we have little or no control over the websites out in the wild,
I think the solution will have to come at my end (in the AIRHelp application).
As I have been testing this AIRHelp it has soooooooo many cool features,
but this is definitely going to be an issue with any management types or other reviewers.
Thanks for taking a look and for your ideas.
Sorry, don't have any idea how it's working under the hood. With my locally installed AIR Help, we don't link to any external websites because most of our users don't have internet installed on the machines that are running it. In fact, I'd like to go under the hood to disable all web access/RSS feeds entirely. I've already thrown my 2 cents worth into the feature request bucket & I'd suggest you do the same about this resizing issue. The more people that let Adobe know about issues, the more likely they will get fixed.
I think you should report this as a bug. The more people who report a bug, the more likely it is to be actioned. Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
Hi there
I'm a bit mystified as to how AIRHelp is to be blamed, given the fact that *SOME* web sites display perfectly fine and others don't. I would think if there were a problem with AIRHelp, *ALL* web sites would be affected, not just some of them.
I am aware that when folks create web pages that there are often several hoops that must be jumped through in order to accommodate different browsers. For example, sometimes pages will display fine in IE and fail miserably in Firefox or Vice-Versa. So I see this as being no different.
Just a few thoughts from the edge... Rick ![]()
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
One would think that for pages which validate for both HTML and CSS,
and that work properly in various versions of Firefox, IE, Opera, and Safari,
that the "browser" in AIRHelp could render these pages properly.
Since these pages appear to be properly constructed there is nothing we can do on this end to find a fix.
If someone from Adobe could point out a problem with those non-working pages,
we would definitely be interested the fix.
Or even a work-around.
But when multiple other browsers all work properly and the pages validate, what else do we check?
Hi there
Personally, I'd be comparing the pages that don't work with the pages that seem to. After all, you did say that some pages render fine. That means that the pages that render fine are doing SOMETHING the viewer likes, no? ![]()
And if you really want Adobe to take notice, you shouldn't expect it to happen by posting here. These are primarily user to user forums. Sure, we do see Adobe folks post here but we cannot (and should not) expect them to. You should consider filing an official Bug Report as this will end up in the database and officially on their radar. ![]()
Cheers... Rick ![]()
What, you think I spent no time analyzing the pages to try and find the issue?
I spent a lot of time trying to find the problem.
Wasted a lot of time as I found no solution.
Apparently some perfectly good web pages do not display properly in AIRHelp.
I originally posted here because as a new user of a trial version I thought other more experienced users could tell me what I was doing wrong, or the trick to get it to work, or confirm this is an issue.
I was interested in AIRHelp for a particular project because of features including incorporating outside links.
For my projects this is a killer feature which I could use a lot.
Since this did not work (and other issues) I eventually gave up and let the trial expire (and went back to Help & Manual for the project).
So I have no vested interest in filing a bug report and following the progress (if any).
If the AIRHelp display issues eventually get solved, I would be interested in taking a look again.
But frankly I do not see this happening.
Adobe does not seem to have the direct connection to the users that I am used to, and desire.
Listening and engagement are more important than requiring bug reports to get any attention.
If no one from the company reads or monitors these forums that itself points to a problem with not listening.
Consequently the product will continue to have very annoying problems in addition to this one.
Rick offered the suggestion not knowing whether or not you had looked at the pages. You had but I don't think it is necessary to be sarcastic towards Rick who was trying to help you.
Sometimes experienced users can help and sometimes they cannot. Not every problem has been seen before and not all of us who support the forum can remember every solution. I believe one person did report something similar with a couple of sites but I don't recall the outcome. Ordinarily I would try to find that post but as you have given up, that would be pointless.
Adobe does have a direct connection with users via the Technical Support. These forums are user to user as provided in the same way by other software vendors.
North America
Asia Pacific
