paula_ke
flashbuilder/php/zend partially working
Jun 9, 2011 7:23 PM
I've made a simple application that uses the php service and the zend framework on wamp
The database has three fields, one primary index.
The project creation process works fine and when I create the data service with the wizzard, I get all the CRUD
that I need.
I set up a data grid and bind it to getAll<tablename>.  I run the app and all is fine (I see an empty table)
My network monitor indicates I made a getAll query and it shows an okay result
I set up a Data>generate form wizzard and bind it to create<tablename>(item...)
I run the app and get the datagrid and the form with fields to enter my data, a button to create the item in the table and a result text box
When I enter data and press the create button, I do not get any results ( I should get a 0)  I've stepped through the program and I never get a return token.
My network monitor does not inidicate that I had any network traffic (nothing from my client to the php code on the server)
To make things more interesting, when I do a Data/Services>Test Operation on the create function, I can load a set of data, run the test and it works! Data shows up in my table and the test response code is 0
My question is, how do I debug the php service call on the client side as it does not seem to be working.
Paula
More information:
I loaded flashbuilder 4.5 on another windows system with wamp and zend and got exactly the same result.
I now have two systems that do exactly the same thing.  I have a zipped directory of the project and can send it to someone who might
be interested in this bug.
As I step through the code I reach the operationManager object and the debugger can no longer see the code (it is part of the mx libraries I guess).
At any rate, there is never a network call for the create<>(item...) operation so it must be in the mx.data.RPCDataManger, mx.data.DataManager, mx.data::ConcreteDataService/createItem
Very frustrating.
    Jul 14, 2011 6:12 PM   in reply to paula_ke
    Paula
    Thanks A LOT!!! this issue was driving me nuts, Re-cheling every thing for the past week, you really help me out
    Good bye
    Aug 16, 2011 7:43 AM   in reply to paula_ke
    Hi  Paula,
    Thanks so much for your answer and solution.
    I had the same problem/bug and couldn't resolve it till now.
    Adding the commit() function solved it.
    Thanks again for your time!!!
    Mar 27, 2012 12:25 PM   in reply to paula_ke
    Hi Paula.....
    Thank you very much paula.... It was really helpful.... Thank you again..... You saved me before getting frustrated for days......
    Aug 1, 2012 11:41 AM   in reply to paula_ke
    Hey Paula,
    Now I have the "commit();" code before the return of each function in the "Super...Service.as" file but I I still get this error and my php-mysql data connection settings are there:
    Error Dialog:
    Channel disconnected
    Channel disconnected before an acknowledgement was received
    If you have any suggestions of what can this be I would truly appreciate your help.  Thank you.
    Aug 1, 2012 2:34 PM   in reply to paula_ke
    I downloaded a program CHARLES to monitor traffic and find out what’s going on.  Could you elaborate a little bit about Python Service.  Sounds interesting enough J
    Apr 2, 2014 6:47 AM   in reply to paula_ke
    i dont understand, should I just add "commit();" before return ? i have the same problem, except mine doesnt work even when testing
