conditional compilation and import statements
Jun 10, 2011 11:30 AM
I have a web application written in Flex and I'm trying  to build an AIR application from the same code base using conditional  compilation.
In the AIR application, I need to have import statements  such as the following:
import flash.data.SQLConnection;
import  flash.filesystem.File;
but I cannot have these import statements in the web  application because they are AIR only classes.
I thought I could use conditional compilation to  overcome this issue but then I read the following on page http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf 69084-7abd.html:
"You cannot use constant Boolean values to conditionalize metadata or import statements."
If that's the case, how can I have common codebase for Flex based web as well as desktop applications? Has anyone solved this conundrum?
Dilip
    Jun 10, 2011 11:05 PM   in reply to DilipShah
    If the import is resolvable, but not used, I think you will be ok.  So
    conditionalize the use of the classes, leave the imports in and use the AIR
    config and see if it runs on the web.
    Apr 2, 2013 9:05 AM   in reply to DilipShah
    DilipShah, as far as I see the classes are still included if referenced by import.
    Example:
    I have this statement in my class A
    if(CONFIG::platform == "ios") {
                        import B;
    I can see in linkreport that class B is still included and is included because A is referencing it.
    Flex harUI, classes are included into final swf file if any other class is referencing it through import even though not using it. I've experimented with it quiet a bit.
    Apr 2, 2013 11:25 AM   in reply to CyberProdigy
    CyberProdigy, the if statement is a run-time construct, not compile time, you can't use it for conditional assembly of the code.
    DilipShah has the right idea, I think, but you'll have to use the same technique to eradicate all trace of the use of B for it not to be included.
