paulvmacpherson
MP4 preset
Jun 12, 2011 11:55 AM
I have a Sanyo Xacti HD camera that produces MP4 files. When trying to select an available preset in Premiere Elements 9 I'm unsure which preset to use ((I've experimented with virtually all available to me) and each time I attempt to drop a clip into my project I'm told that the file doesn't match the pre-set.
The presets I have available to me are in these NTSC folders: AVCHD, DSLR, DV, FLIP, HARD DISK/FLASH MEMORY/CAMCORDER/HDV.
Can anyone suggest a course of action?
Thanks, Paul
    Jun 12, 2011 3:13 PM   in reply to paulvmacpherson
    Unfortunately, that video isn't designed to be edited by Premiere Elements. In fact, pocket camcorder video is made pretty much to shoot and then load the video to YouTube.
    None of the project settings in Premiere Elements will interface well with that camcorder's video. Sorry.
    You may be able to make it work with one of the DSLR presets -- but there are no guarantees, since this is a hybrid solution.
    Jun 12, 2011 8:06 PM   in reply to paulvmacpherson
    Does Sanyo have any software for that camera?
    Jun 13, 2011 12:02 AM   in reply to paulvmacpherson
    Try using the HDV 720p 30 project preset.
    I can use that with my Kodak Zi8 .mov files (AVC/h.264 and AAC). No red lines.
    I can also use that preset with my Kodak PlayTouch, .mp4 files (AVC/h.264 and AAC). No red lines either.
    Jun 13, 2011 3:39 AM   in reply to paulvmacpherson
    Which exact version of the Sanyo XACTI is this?
    Jun 13, 2011 8:17 AM   in reply to paulvmacpherson
    paulvmacpherson wrote:
    Hi John,
    I don't see anything on a quick Google search. If they did have software for the Xacti, how are you thinking that would help? The clips would still all be recorded in mp4 format, right?
    I would go to the Sanyo site, for your camera, and see what is there
    IF Sanyo has any kind of editing or conversion software, it MIGHT help... because it is designed by Sanyo to work with their camera
    Jun 13, 2011 12:40 PM   in reply to paulvmacpherson
    Does the XACTI have modes of capture in it? I mean, I see that there is one version of the camera that can capture a Full HD AVCHD, that is 1920x1080 AVCHD format mp4. The same one can capture a lesser resolution. So if your camera has a "non-Full-HD" capture resolution, there is a good chance it will not be understood by Premiere Elements. Can you let me know the resolution of the files that are generated out of the camera? Resolution is the "width x height", like a "1920x1080" or a "1280x720"
    You also mentioned that "...and each time I attempt to drop a clip into my project I'm told that the file doesn't match the pre-set". What option do you select when you get such a message? I think you are selecting a "No" here, Otherwise Premiere Elements  would have taken you to the right preset all by itself. In fact the message "means" that
    1. This is not the right preset
    AND
    2. Premiere Elements 9 "knows" what is...
    I think it this is called a mismatched preset dialog. Allow it to do its stuff, and you should see no red line in the resulting project over your clip!
