Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Invoking a webservice when opening the PDF
Avatar
Former Community Member
Hello!
I have this webservice to generate a sequence number when the user clicks a button on the PDF form.
How do I invoke the service as soon as the form is open, instead of waiting for a click on the button?
Thank you for any ideas!
Marcos
1 Accepted Solution
Avatar
Correct answer by
1) there are a number of events that fire off when a form opens / is opening / has just opened... etc
Example events that can be used
Any field... initialize
form:ready
layout:ready
docReady (is probably the best for your purpose)
Remember each event behaves differently & at different times and some bubble - for your described application, I would use the docReady event
2)
To execute the webservice button programmatically:
btn.execEvent("click");
3)
// comment your code
View solution in original post
1 Reply
Avatar
Correct answer by
form:ready
layout:ready
2)
3)
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
