mjjfei
How to install several specified languages for Adobe Reader X
Jun 16, 2011 7:21 PM
Hi guys, just question that how to silencely install several specified languages for Adobe Reader X?
I know some silence switch as below:
setup.exe /sAll /rs
=>  Silencely install all supported languages
setup.exe /sAll /rs /sl "xxxx" (xxxx is LANG ID)
=>  Silencely install one specified language only (defined by LANG ID)
Question:
If I would like to silencely install several specified languages, is there any other switch to do that?
Thank you all in advance.
    Jun 16, 2011 11:41 PM   in reply to mjjfei
    I am assuming that you are trying to install Reader MUI since thats the only way you can get the Reader installed in different languages on your system.
    For the same please refer to the following link:
    http://kb2.adobe.com/cps/878/cpsid_87899.html
    Hope this helps.
    Ankit
    Jun 17, 2011 2:46 AM   in reply to mjjfei
    Can you please try following the second step on the page i.e. installing using the command:
    msiexec /i AcroRead.msi LANG_LIST=DEU
    This will install Adobe Reader in German and English languages. You can launch the preferred language(d) application by holding Control and double clicking on the Adobe Reader shortcut.
    Ankit
    Jun 17, 2011 3:53 AM   in reply to mjjfei
    Glad that it worked for you. The language codes are as below:
    LanguageCode
    EnglishENU
    FrenchFRA
    GermanDEU
    DutchNLD
    SwedishSVE
    ItalianITA
    SpanishESP
    Brazilian   PortuguesePTB
    NorwegianNOR
    FinnishSUO
    DanishDAN
    JapaneseJPN
    Chinese   SimplifiedCHS
    Chinese   TraditionalCHT
    KoreanKOR
    To set the startup langugage the same as the Operating System's, please refer to the page at:
    http://kb2.adobe.com/cps/854/cpsid_85468.html
    Ankit
    Jun 20, 2011 12:07 AM   in reply to mjjfei
    You can create the same key in HKLM and not HKCU (i.e. HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\10.0\Language\UseMUI).
    That should install Reader MUI for all users with the operating system language as the application startup language.
    Jun 21, 2011 12:24 AM   in reply to mjjfei
    Can you ensure that the registry key that you have created is a string key (REG_SZ). I tried the same thing on my 64 bit machine and it worked without any issues. I got the required language interface without any language pop up dialog.
  • waflgnog
    Oct 28, 2009
    Jul 5, 2011 2:55 AM   in reply to mjjfei
    I had the same issues, but was able to resolve it as follows:
    In the Customization Wizard change the data according to the attached images:
    Make sure "acrord32.dll" is in the Data field of both "current" keys and the "next" key.
    In Adobe Reader X the UseMUI key is a REG_DWORD
    • Data = 0 ~> Application Language = Choose at application startup
    • Data = 1 ~> Application Language = Same as the operating system
    I added the UseMUI key under the HKLM hive as well, but I'm not quite sure whether or not it's really necessary.
    To install only a limited number of languages you can go to the Direct Editor and change the value of the LANG_LIST property:
    Hope that helps. Good luck!
  • waflgnog
    Oct 28, 2009
    Jul 11, 2011 4:55 AM   in reply to mjjfei
    If you perform the installation using a custom transform file created with the Customization Wizard as described above, the appropriate registry keys will be created automatically for each user once she starts Adobe Reader for the first time. I tried it on several test clients and it worked properly, no matter whether I logged on with an existing username or a new one..
    For more detailed information, I'd like to recommend Aaron Parker's great and easy to understand deployment instructions. Please take a look at http://blog.stealthpuppy.com/deployment/deploying-adobe-reader-x/
