JValero209
Flash Builder 4.5 Debugger Problem
Jun 17, 2011 1:20 PM
Hey Everyone,
I spent the better half of the last hour searching for a remedy to my situation but have not found one. I have a problem where in Flash Builder 4.5 I keep losing my debugger version of Flash Player. I download the version here http://www.adobe.com/support/flashplayer/downloads.html#fp10 and it works again. However, seemingly random it will do it again a couple of days later. So I'm trying to figure out what is causing this or how I can fix it. It is quite annoying to go to jump into a project, debug it and then have to stop everything and download it again. Anyone know how to fix this?
I am running it on Mac OSX 10.6.7 (latest).
This is the message I receive when it breaks:
"Flash Builder cannot locate the required debugger version of Adobe Flash Player. You might need to install the debugger version of the Flash Player or reinstall Flash Builder.  Do you want to try to debug with the current version?"
    Jun 18, 2011 11:17 AM   in reply to JValero209
    When I encounter that (I'm running Windows though) it's usually after I've recently changed or have leftover metadata from a different version of the SDK. You haven't recently changed SDK versions for Flex or AIR?
    Probably totally unrelated but what fixed it for me in my situation was to delete the metadata folder in the app directory and reimport given the new, clean workspace. Kind of a pain.
    Jun 21, 2011 2:51 AM   in reply to JValero209
    Are you using Chrome? If not, which browser?
    Jun 27, 2011 5:42 AM   in reply to JValero209
    Flash Builder pops up the warning by checking the contents of /Library/Internet Plug-Ins/Flash Player.plugin.
    Strange that the plugin gets overwritten every few days for you. (Flash Builder doesn't do anything there, so must be some other program.)
    -Anirudh
    Jun 27, 2011 10:51 PM   in reply to JValero209
    All I'm saying is that Flash Builder doesn't install any player or plugin after the install process is over.
    We haven't coded it in, and since I'm the engineer developing the debugger, I would know. Other CS products may install player during install time, but only if the version is lower than the one you have installed.
    That said, let us shift the focus back to solving the problem you're facing. There doesn't have to be another process running when Flash Builder is running for this issue to occur.
    The warning dialog you mentioned pops up after Flash Builder looks at the contents of /Library/Internet Plug-Ins/Flash Player.plugin/Contents/Info.plist (the bundle name will be Flash Player Debugger) followed by a final check inside Resources/Flash Player*.rsrc.
    Next time you run into the problem, the contents of Info.plist will help in narrowing this problem down.
    -Anirudh
    Jun 28, 2011 8:52 AM   in reply to Anirudh Sasikumar
    After 3 days of frustration, the solution is so simple I could cry... For anyone else who runs across this issue take a look here:http://therush.wordpress.com/2008/03/11/resolved-flex-builder-3-debugg er-stopped-working/
    I think my problem was cuased by the fact that in my hosts file I have localhost redirected to a location on the backend web server where the app is actually being deployed. I changed the setting in the Debugger dialog (right-click in the running app and select 'Debugger') from 'localhost' to 'other machine' with an ip of 127.0.0.1 . As soon as I did, flexbuilder launched the debugger and everything started working.
    Still not entirely sure why this works, but it must change a windows setting somewhere. I exited 4.5 and opened a project in 4.0 and the debugger worked there as well without having to repeat the process.
    Sorry, replied to the wrong thread.
  • rtalton
    Oct 28, 2008
    Sep 27, 2011 9:42 AM   in reply to JValero209
    My two cents on this issue & how I resolved it.
    I was getting a similar message which referenced a location in C:\Windows\System32\Macromed\Flash, and was looking for this version of the Flash Player: Flash64_10_3_162.ocx
    What I tried that did NOT help:
    Re-associating the SWF file type to open with a Flash Player debugger version downloaded from Adobe's site.
    These three steps resolved the issue for me:
    1. I had installed the 64-bit version of the Flash Player a few months ago, so I uninstalled that since it cannot be used by Flash Builder as a debugger. Back in FB 4.5.1, I got another message saying Flash was not installed at all.
    2. I used Adobe's Flash uninstaller tool and then,
    3. re-installed the latest debuggers for IE & Firefox.
    I can now debug in IE or FF without any issues. FB finds the debug version of the Flash Player.
    From what I saw when researching this, there seem to be many causes for this issue so I'll give Adobe some slack here. I will point out that the post from Adobe employee Anirudh Sasikumar, above, was not helpful in my case and was in fact misleading and not specific enough as to the location of the file he referenced. I searched for that file and found dozens of them on my machine, none in any location he mentioned. I wish he would have taken a little more time to give a complete path to this file. Maybe he did, but I could not find that path, or folders, on my machine. I work in a tightly-controlled network environment so perhaps these folders are ones I cannot see due to permissions issues, but it would've saved me time to get a complete path to start with.
    For complete and full disclosure, here is my set-up; hopefully this will help others with a similar setup who are experiencing this nagging issue:
    Windows 7 Enterprise 64-bit, Service Pack 1
    Flash Builder 4.5.1.313231
    Eclipse 3.6.1r361_v20100909xxxxxxx
    Flash Debugger version (IE & FF): 10.3 r183
    Sep 28, 2011 3:30 AM   in reply to rtalton
    Thanks for explaining your solution, rtalton.
    P.S: My post was for Mac OS since the original poster had a Mac.
    -Anirudh
    May 15, 2012 3:32 AM   in reply to rtalton
    Hi
    rtalton
    thanks for your 2 cents, it was helpful. i am running Flash Builder 4.5 on a 64-bit Windows 7 Pro PC, and despite having installed
    Download the Windows Flash Player 11.2 ActiveX control content debugger (for IE) (EXE, 3.93MB)
       and the latest 64-bit version for Firefox, i kept getting notifications about not having the Flash Player debugger installed when trying to debug in all browsers - FireFox, Chrom and IE.
    SO i did as u suggested and uninstalled all Flash Players and then reinstalled the ActiveX for IE, and after that the 64-bit Flash Player for firefox, and now i can debug, but only in IE, while with Flash Builder apps in Firefox or Chrome i can only run, NOT debug. That's fine, considering that all things are working smoothly (I was  worried about installing the debugger for IE because i understand it is a 32-bit app).
    If you have any recommendations as to how i might be able to debug in Firefox and Chrome, as these are my favorite browser, particularly Firefox, plz let me know, keeping in mind i am not a programmer.
    There are additional 32-bit Flash Player apps on the Adobe website, but i dont want to push my luck...
    let me know what you think. ANyone can reply if they like.
    thanks.
  • rtalton
    Oct 28, 2008
    May 15, 2012 8:00 AM   in reply to minimalcomfort
    AFAIK, Flash Builder can't use a 64-bit debugger. I have no problems running the 32-bit debuggers, so try that for FF & Chrome.
    May 16, 2012 7:12 AM   in reply to rtalton
    ok. but do u know specifically which, and that it wont cause issues?
    Aug 2, 2012 5:42 AM   in reply to JValero209
    I had the exact same problem with Flex Builder 4.6 and I'm on Max OS X 10.8, however the problem is solved after installing the "Plugin content debugger" from http://www.adobe.com/support/flashplayer/downloads.html
    Sep 11, 2012 11:38 AM   in reply to gtan6
    For what it's worth, I was having a similar problem in OSX Lion. I could not get Firefox to connect with the debugger or even to run without it. It turns out that the way I had specified the location of Firefox (Preferences->General->Web Browser) was incorrect;
    Previous versions worked when I used this location :
    /Applications/Firefox.app/Contents/MacOS/firefox-bin
    However, Firefox 15.0.1 would not start from FlashBuilder using this (although it did in previous versions). Once I changed it to :
    Then everything started working as expected, debugger connected, etc.
