Wrong page numbers on PDF export (ID CS5.5)
Jun 20, 2011 8:00 AM
  Latest reply: xSarahHx, May 9, 2012 1:13 PM
Replies 1 2 3 2 Previous Next
    Dec 4, 2011 5:47 AM   in reply to McShaman179
    Failure to set the indiviual documents to section numbering can cause problems, too.
    Dec 23, 2011 10:03 AM   in reply to Peter Spier
    I found a solution that works. The problem seems to reside on the master pages, so if you take the text block that holds the page number from the master page and paste it in place on each page (fill with paper color to block the master items), the page numbers then pdf perfectly. This saves you the trouble of having to idml and resave the files. Hope it helps!
    Dec 26, 2011 1:18 AM   in reply to macromac
    Hello,
    Got the same problem on the Middle East version 5.5, glad to see it's not an ME issue but what we call US verison.
    Obviously it's a serious bug. I have lot's of books with hunderds of pages, I will just close each file seperately.
    Hoping there is a solution.
    all the best,
    Shlomit
    Dec 28, 2011 6:31 PM   in reply to Shlomit Heymann
    Same problem here, its pretty disappointing that Adobe has regressed in such a key feature, and to let this bug drag on… I've just been exporting each document separately and then merging the .pdf files and haven't yet noticed any problems, its annoying but it should get me through until they patch the bug or release CS6.
  • prepress girl
    Feb 17, 2011
    Dec 29, 2011 11:58 AM   in reply to macromac
    Huh. If I duplicate the text box on the master page that has the page numbering in it, the DUPLICATE is fine, but the "original" page numbers still number incorrectly! Curiouser and curiouser...
    Dec 29, 2011 12:10 PM   in reply to prepress girl
    I have this problem and it HAS cost me money because I didn't find out about it until it got to the printer. Pretty soon I'll be paying more in fixes than the program actually cost me to purchase.
    In my case, I have ID CS5.5 (7.5.2) and created a book with about 30 chapters. It looked fine in ID, but exporting to PDF caused three chapters to repeat the even-numbered page numbers throughout that chapter. (Each chapter was built using the same template -- most chapters are fine, but some are not.) I fixed this by going into the Master page for that chapter, deleting the offending page number reference, copying the one that worked (on the odd-numbered side of the page), and pasting it on the even-numbered side. This seemed to fix the problem.
    But being a small press without a lot of capital, this sucks.
    Sorry, I didn't mean to imply that you duplicate the text box on the master pages, you duplicate the text boxes to each individual "live" page (you can even remove the master item if you want). I had limited success fixing this by synching the Master Pages and variables from a chapter that had working page numbers. I think the bug is either on the master page or in the variable definition, however moving the page number to the actual page clears the issue very consistently.
    Should mention that this works with the US and ME versions. We run both.
  • prepress girl
    Feb 17, 2011
    Dec 29, 2011 12:54 PM   in reply to Graphic Extensions
    No, I got that bit... was just playing about trying to "save" the Master Page numbering, since copying + pasting onto each page seems to defeat the purpose of Master Pages! LOL!
  • John Hawkinson
    Jun 25, 2009
    Dec 29, 2011 12:54 PM   in reply to RobotGod
    Some carefully hedged speculation
    If we were to imagine that, in the best of all possible worlds, Adobe has worked hard to fix this problem and it will be fixed in a future patch release of CS5.5 (I think that is a good assumption in this case), then if we look at the semi-public precursor announcements to releases, we would see that the latest CS5.5 patch release candidate was birthed on December 12, and they generally take about a month to bake before seeing public release, though everything takes longer around the holidays.
    So one might be optimistic about a potential fix for this the second week in January or so.
  • John Hawkinson
    Jun 25, 2009
    Jan 12, 2012 11:26 PM   in reply to John Hawkinson
    Unfortunately it looks like another release candidate was cut today (see above link), so please reset the optimism for the 2nd week in February.
    Jan 22, 2012 1:01 PM   in reply to John Hawkinson
    It would be fine if this bug could be fixed too
    Feb 29, 2012 10:39 AM   in reply to macromac
    I just wanted to add that no only the page number is wrong, but also section markers.
    The problem does not show up in CS5 only 5.5. I have left some jobes in this version.
    My only solution was the export each file sepreately and combine them all via acrobat pro.
    this makes me really sad
    Apr 2, 2012 7:54 AM   in reply to macromac
    I recently developed this problem, too. US InDesign 5.5 v7.5.2; Mac 10.6.8; export smallest file size; booked file of 18 documents, each with 22 pages or less. Happy to find workarounds but disappointed there is no cure yet.
  • John Hawkinson
    Jun 25, 2009
    Apr 2, 2012 7:56 AM   in reply to Liz_P
    Funny you should ask, Liz_P.
    More carefully hedged speculation
    Over in the semi-public precursor announcements to releases, this morning (Apr. 2) there was an update: "InDesign Family CS5.5 7.5.3 dot release tentatively scheduled for 4/30/2012."
    So, if we take that at face value, and again assume that the bug likely to have been fixed (something I think is likely given its severity), then we could assume that this bug fix is tentatively scheduled to be released at the end of this month.
    Apr 2, 2012 8:04 AM   in reply to John Hawkinson
    How tentatively encouraging.
    Thanks for your quick response, John!
  • John Hawkinson
    Jun 25, 2009
    May 2, 2012 11:50 PM   in reply to John Hawkinson
    A few days late, but it seems to be out! The release notes list:
    Import / Export: Wrong page number on export book to PDF [2940448]*
    May 9, 2012 1:13 PM   in reply to John Hawkinson
    I just installed the 7.5.3 update and it seems to have solved the page number issue on my problematic book from last year. Woohoo! Thanks for the info, John, and glad this issue finally made it to the top of Adobe's priority list.
Actions
