Color in lightroom different than export.
Jun 22, 2011 6:57 PM
I've noticed for some time now that I was having to adjust the white balance in almost all my photos while working in LR 3. Then when I print they were all too cool and blue. Just back from vacation and I developed my photos while gone on my laptop with LR3 and noticed I did not have that problem. I know your going to say it's my monitor. But then I imported the catalog from my laptop and the exported photos that I developed. When I opened lightroom the pictures again were very warm, almost brown in hue. When I opened the exported JPG it looked fine.
The image is a screen shot of the export on the left next to the photo in the develop module in LR.
If it was a monitor problem then both should look the same. Why am I getting such a warm photo in lightroom? I've compared the settings on my laptop and desktop and they appear to be the same. Anyone have an idea of whats happening in my desktop Lightroom?
Chris
    Jun 22, 2011 9:34 PM   in reply to savoy91
    Welcome to the fourm!
    First question I have for you:  how aer you viewing the "correct" jpg file?  with a color managed program, or what?
    Next, check your import settings, make sure when you import files you are not inadvertantly applying a preset.
    I don't think it would be in export settings, because you exported and it showed up "correctly", so either you need to calibrate your monitor (yes, quite likely)  or you have a preset set.
    The reason it could be the above is: when you imported as a catalog, it would not apply presets as it would if you imported directly.  And your catalog file was created on a different computer with a different monitor, so you could have set the color balance/etc just fine, but your local monitor is messed up and showing you wierd things.
    I'd have to see a screen grab of your develop module to get a clue as to where it is; take a look at the histogram, for example.. does it have actual white in it, or is it "warm"? If so, your screen profile is messed up!  Try setting it (temporarily) to sRGB and see what it looks like.
    Cheers!
    Jul 18, 2011 7:57 PM   in reply to savoy91
    Ah!
      Okay, that's a different issue then.  So, a couple of questions: what monitor are you using?  Is it profiled?  LR uses pro photo rgb, and by default PS uses adobe rgb, I think.  But your monitor is srgb unless you have a wide gamut display!  So many spaces.  There is an additional problem that LR is a lot more sensitive to display profiles than other programs.
    Could we see a screen grab of LR?  For example, one of the upper right corner of the develop window.. In particular, what does the historgram look like?
    You can test some of this stuff by changing your OS screen profiles temporarily to sRGB and see what it looks like.
    Cheers!
    Jul 19, 2011 12:56 AM   in reply to savoy91
    You need to calibrate your monitor using a calibration device and the software that comes with it. Then only view and judge images colour in colour managed software. Uncalibrated monitors or none colour managed software will give varying results and no judgement of colour values can be made.
    You say
    They would only look the same with a calibrated monitor viewed in colour managed software. Using an uncalibrated monitor will produce variations in colour across applications. Using none colour managed applications will produce variation across applications. Only using a correctly calibrated monitor and colour managed applications will produce consistency in colour viewing.
    Jul 19, 2011 7:07 AM   in reply to savoy91
    No, calibrating won't make other things look bad.
    Look at the histogram from the desktop. There's a distinct colour cast in the area that should be grey. That's a sure sign that your monitor profile is bad. You have to properly calibrate it. Any $100 calibration tool will be fine.
    Hal
  • John Blaustein
    Aug 11, 2002
    Jul 19, 2011 7:15 AM   in reply to Hal P Anderson
    Chris,
    Take a look at:
    Datacolor:
    http://spyder.datacolor.com/product-mc.php
    The Spyder3Express will work for you:
    http://spyder.datacolor.com/product-mc-s3express.php
    Note:  I do not have any affiation with Datacolor, but I have done beta testing for them and can highly recommend their products based on my personal use of them.
    John
    Jul 19, 2011 8:31 AM   in reply to savoy91
    That was exactly why I asked to see the historgram...  everything has a color cast (including buttons), which means your monitor is not calibrated.
    Okay, so here's the deal:  Everything is set to sRGB, _except_ LR.  Lr doesn't run in that space, you have to calibrate it to look right.
    So, best choice, pick up a calibration tool... spyder, i1, all do a fine job.   And no, it won't mess up anything else, because you won't be relying on "standard" screen definitions that aren't exactly right for anything!
    Cheers!
