progressive footage, automatic timeline makes an interlaced timeline?
Jun 27, 2011 9:54 AM
This is weird. Why does adobe premiere pro CS5.5 take my 30F footage and when I drag it into the "New Sequence" button, it creates an interlaced sequence? How do I know this? Well I am exporting it right now, H.264 Blu Ray and Adobe Media Encoder tells me the video information: NTSC, 1920X1080, 29.97fps, Upper.
Why is it upper? This footage is progressive and premiere pro should know this and not waste 19 hours of my life.
    Jun 27, 2011 10:01 AM   in reply to emin3m33
    My guess is because the recorded image actually is interlaced, it's just that each field came from the same moment in time, which makes it 'faux-progressive'.
    You may need to Interpret the footage to Progressive to get things working.  (And then create a new, correct sequence and Copy/Paste the clips into it.)
    Jun 27, 2011 11:16 AM   in reply to emin3m33
    Well, like I said. it's a guess.  For whatever reason, PP seems to be seeing it as Interlaced.
    The solution remains the same.  Give it a whirl and see what happens.
    Jun 27, 2011 1:08 PM   in reply to emin3m33
    If i am not mistaken Canon's 30F is in fact filmed in progressive and stored as interlaced (60i). That's why its called 30F and not 30p.
    Jun 27, 2011 3:34 PM   in reply to emin3m33
    No.  It's just stored as interlaced.  But each field is still from the same instant in time, so when you combine the fields, you end up with a whole progressive frame.
    Jun 28, 2011 9:12 AM   in reply to emin3m33
    I said that in post 3.
    Aug 18, 2011 11:09 PM   in reply to emin3m33
    > so does any employee have an "official answer" for me?
    The official answer is that this is a user-to-user forum, not a place for guaranteed answers from Adobe employees.
    If you think that a behavior is a bug, you can submit a bug report.
    If you want a guaranteed answer from an Adobe employee, you can contact Adobe Technical Support:
    http://www.adobe.com/support/contact
    FWIW, Jim and Ann are giving you good answers.
  • joe bloe premiere
    Dec 6, 2009
    Aug 19, 2011 8:44 AM   in reply to emin3m33
    The 'drag and drop' method of creating a sequence
    that matches your footage is merely a handy shortcut.
    In order to be absolutely certain of creating sequence settings
    that are exactly what you require, you should not use the
    'quickie shortcut', but create your sequence manually.
    Drag and drop media shortcut caveat.
    Aug 19, 2011 10:19 AM   in reply to emin3m33
    function(){return A.apply(null,[this].concat($A(arguments)))}
    I had this same problem with some footage from my HV40.
    I dropped different clips from the same camera on the make new sequence icon and Premiere would read it correctly and sometimes it wouldn't.
    It was the strangest thing.  The camera never changed settings and I would also try dropping the same clip multiple times and Premiere would read it differently each time.  It made me watch my setting more closely.
