Hello everyone,
I have some trouble with the project settings ( I hope its the right term, because my programm is in German).
I don't know which setting to use with my video files captured with fraps.
Video clip details:
I didn't find any setting fitting to my video file, and when I choose one which fits partly I can't change the settings (for instance the frame size).
In addtion to that, my video files are blurred in the prewiew and also when the file is exported....
Thank you very much for your help
Unfortunately, there are no project settings per se for this type of non-traditional video. Premiere Elements is designed primarily to interface with video from camcorders. FRAPS video is usually a pretty poor fit, and rendering problems are common. (You will definitely need to revise your video side to a more standard 855x480 or 1920x1080 at the very least.)
Bill Hunt, who writes many of the Tips & Tricks posted to the right of our forum, is sometimes aware of hybrid solutions that work in some cases. He may chime in at some point later.
You might find some tips for working with FRAPS footage in some of the links at the end of this ARTICLE.
Thanks again.
But I still don't get it, sorry if I bother you. But I'm stuck on the project presets. I know now that that should fit the best possible to the video file (btw I have 1600x900, not 1600x838). But which preset fits the best...
I'm pretty new to that software. With my ohter programs, I had to decide at the end, when I'm exporting, which frame size I want...ect...
So yeah sorry again and thanks, but I'm pretty desperate not being able to edit my fraps videos... ![]()
Well, with that odd Frame Size, about the best that you can do is to choose 1920 x 1080, Import your FRAPS footage into that Project, and then, either leave the black bars, or Scale up your Footage (Default Scale to Frame Size will do that, or you can use the Fixed Effect>Motion>Scale and possibly Motion>Position, if necessary). Scaling WILL reduce the quality, but you might be able to live with that. Only you can know.
Now, in PrPro, one CAN Customize the Frame Size to match odd footage, but that is an entirely different program, and not inexpensive.
Well, the Preset does matter, but in your case, there is not one that matches. So, you have to choose the one that works best. In your case, you will have to adjust your footage to match, or will have to live with the black bars.
As for Export/Share, yes, you can alter the settings there.
North America
Asia Pacific
